Old 11-18-2013, 08:16 PM
m8o m8o is offline
Let me buya F31 335xi BMW
Mein Auto: 09 JCW, C43/55, 560SL, TJ
Thought rotating left<->right, regardless of coupling that with front<->back, reduced tire noise?
Isn't the front<->back rotation reducing handling performance due to the way camber wears the [usually rear] tires? I've definitely noticed a lack of handling 'prowess' after a front<->rear rotation due to this. And it takes thousands of miles and hard turns scrubbing the tires to undo that.
tturedraider's Avatar
Freedom isn't free!!
Originally Posted by mr_clueless View Post
Can't speak for the new car yet...it may be different.
My E46 also came with the "do not rotate" instruction, but the tire shop (America's tire co.) said they would refuse to give me credit for premature wear (which I ALWAYS had) if the tires were not rotated regularly by them (included in the cost of tire purchase and installation). Basically, without rotation, my rear tires would wear out with about 10K miles left on the fronts. Even with rotation, the continentals which I think had a 60K warranty, would be worn by around 40-45K. So there was a significant incentive for me to rotate back then.
Virtually every tire maker that provides a mileage warranty on their tires requires evidence of regular rotation, approx. 5,000 mile intervals, to make any kind of warranty claim.
www.bmwcca.org
Old 11-18-2013, 08:30 PM
Bret_T Bret_T is offline
Mein Auto: '14 435i & '03 S2000
Originally Posted by wyaple View Post
So it sounds like you are of the belief that if you have non-directional, perfectly square tires on a BMW, you are strongly recommended NOT to rotate them? I'd love to hear from others that have a similar setup.
Again, I just checked my tires and they are the fully square Pirelli Cinturato, non-directional type. And yes, I was planning to rotate them every 5K or so to keep the wear as perfect as possible over the life of the tires.
BTW, I have also always rotated my radials (again, square setup, non-directional) in a front/rear/criss-cross pattern for over 30 years with no issues whatsoever.
+1, With every car that I've owned that has non-directional tires I've always rotated my radials fronts to back and backs to the opposite side of the front. If the tires are directional, then I just rotate front to back and back to front. It evens out the wear so I always end up replacing all the tires at once. The only exception to this is my S2000 which has different size wheels on the front and back.
Liberalism: Failure is always proof that more is needed.
Old 11-18-2013, 08:44 PM
LarryboysUDM's Avatar
LarryboysUDM LarryboysUDM is offline
Apay Kapoy
Mein Auto: 1335i 02RSX5MT 06ML350
Originally Posted by Dippydo View Post
If you go staggered, just one less thing to worry about.
+1
and if you are Not staggered, I would say you don't need tire rotation if you ensure proper tire pressure every month, then balance and align once a year.
My 1st BMW-bought fr inbound inventory: Munich '13 F30 335i, RWD, Alpine White, Black Leather, M-Sport, DHP, Prem Pkg, Tech Pkg, 403M (Potenza S001 RFT 225/40, 255/35 R19), Sport Auto w/paddle shifters, Heated front seats, Harman Kardon, Aluminum Hex Trim/EB accent, Anthracite headliner
Std: Xenon Adaptive Headlights, Sunroof, Alarm
Mods: Tint 35%, DIY lower intake grill guard, BA Standard Coding
56K mi Apr'17
Hergestellt in Deutschland
Old 11-18-2013, 09:12 PM
BentZero's Avatar
BentZero BentZero is offline
Mein Auto: M235i
I often wondered if they required "evidence" because they knew that people would be too lazy to get the tires rotated that often. Now you have cars that can go twice that distance before needing an oil change. Not many people are "type A" enough to take their car in to the shop only to get their tires rotated. #Cynic
Old 11-18-2013, 11:20 PM
namelessman namelessman is offline
Mein Auto: bimmer
My old E39 MT got tires rotated every 3k miles at America Tires which has lifetime balance and rotate. The current F30 AT has less negative camber at rear than E39 and all four corners wear evenly, so no plans to rotate for this ride.
Old 11-19-2013, 05:42 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
Check your owner's manual. Rotating between axles is not recommended.
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
Old 11-19-2013, 06:33 AM
Here's the relevant page from the 2007 Subaru WRX owners manual.
So Subaru recommends rotating tires in exactly the manner I described. Of course their assumption is that the tires on the front and back are the same. My wife's 2011 Toyota Sequoia manual says the same thing, although I couldn't find a download of it.
BTW, the Subaru owners manuals are free to download.
http://www.subaru.com/owners/resourc...ls/search.html
So there's no copyright violation for posting the image above or downloading.
Old 11-19-2013, 06:40 AM
chiefneil's Avatar
Sorry, we're on a BMW forum. I thought we were talking about BMW's.
If you check the F30 owner's manual you'll see that it recommends against rotating across axles.
Old 11-19-2013, 06:53 AM
I was thinking that we're discussing the topic in general. More to the point, why does BMW have a recommendation that seems to contradict the recommendations of other manufacturers? I'm thinking that if you can rotate the tires, you should.
I sold the WRX and will pickup my F32 on 12/3. According to the ordering guide, my F32 will come with directional 225/50 R18's on the front and directional 255/45 R18's on the rear. There's no way to rotate the tires, so I won't.
Old 11-19-2013, 08:58 AM
Mark K Mark K is offline
Mein Auto: '17 GTI '16 981 CS
Re: Dealer Said Tire Rotation Will Damage Vehicle?
That's because BMW alignment is a black art practiced on a graveyard at midnight. And even then it is very hard to get it right. The last thing BMW wants is to pay for repetitive alignment attempts in order to solve vibrations possibly caused by rotating tires.
Probably. Not 100% sure, but not far off.
_
2017 Golf GTI |Silver over tartan cloth| MT| Base S, no options. Oh, wait! ... It does have a spare tire!
2016 981 Cayman S | 6-speed MT| Active suspension | Sport Exhaust System | Torque vectoring (with LSD) | Sport seats + | Sport design steering wheel
2013 VW Golf TDI [CONFISCATED]
2011 E92 335i 6MT ZSP ZCW (ED May 17th 2010) [SOLD]
Old 11-19-2013, 11:21 AM
pointandgo's Avatar
BMW tells you to not rotate the tires and will be the first to deny you warranty satisfaction for erratically worn tires, or prematurely worn tires that can be conveniently blamed on alignment.
As stated above, every one of BMW's tire suppliers demands rotation for their tires in the replacement market...but they remain silent on the issue for their BMW original equipment tires.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 11-19-2013, 01:34 PM
donleycott donleycott is offline
Mein Auto: 328i
Smile Rotation
I rotated the tires on my E90 for 160,000 miles - never a problem, I got about 55k on each set and they wore very evenly. Discount Tire rotates for free every 5k..
Pat
Old 11-19-2013, 06:22 PM
m8o m8o is offline
...According to the ordering guide, my F32 will come with directional 225/50 R18's on the front and directional 255/45 R18's on the rear. There's no way to rotate the tires, so I won't.
In cases like this with staggered directional tires, I have the tires taken off and flipped on the rim so I can do a left<->right rotation. If the only twisties you have available to you on your daily drive is to attack clover leaf exit ramps at the controlled limit, and you do that week after week, month after month, it keeps the tires on the left from wearing out way before the tires on the right.
Old 11-19-2013, 06:46 PM
Trey100 Trey100 is offline
Mein Auto: 2007 E90 335
Pat
I don't get it. Is 11 trips to the shop worth the small savings each 55k miles? Let's say that over 160,000 miles you save one set of tires. That $1k costs you 32 trips to the shop to swap tires. That's a lot of lost time. Even worse for people paying for rotations.
Old 11-19-2013, 06:50 PM
Hopefully the tires won't wear to the inside or outside, but I'll do this if necessary.
