List Something You Discovered About Your Car AFTER You Bought It... - Page 32 - Bimmerfest - BMW Forums
Old 11-23-2013, 06:27 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Originally Posted by gmnmsclM540i View Post
Im pretty sure this is incorrect.
Sent from my DROID RAZR using BimmerApp mobile app
I THINK the late model changes can indeed play MP3's, and I am sure later MASK's and I believe all CCC's can play them
I bet they hate you back....you, sir, and your incredibly detailed & informative posts here on the 'fest have probably cost the bastards plenty!
lol, I will take that as a compliment
Old 11-23-2013, 06:28 PM
DIY'er
Originally Posted by justinb7116 View Post
Wow Dont I feel stupid. I was just doing what the battery shop told me to do. Is it too late for me to register the new battery? Hopefully I didnt do any harm yet. My battery is 2 weeks old btw
Highly, highly doubt it'll hurt anything... no worries
Old 11-23-2013, 07:45 PM
grimloktt grimloktt is offline
Mein Auto: 535xi
I also learned new batteries must be registered.
Also learned:
- You can change the oil filter from the top of the engine bay.
- The steering wheel sometimes needs reset for it to go all the way up after stopping, e.g. move it all the way out, in, up and down and then re-positions to desired position.
- Electronics in the bottom of the trunk should be manually re-positioned to the sides in order to avoid upwards of $15K in replacement electronics.
- I can set the cruise control at 100mph and expect a worry free, smooth ride.
- The windshield washer fluid reservoir is known for leaking--nothing some minor maintenance can't fix.
- That object hanging from the roof in the middle is a interior motion sensor?
Old 11-24-2013, 07:43 PM
Hypnos Hypnos is offline
Mein Auto: 2007 530i
Yup, MP3 playback off the DVD works in my 2007 530i .
In case anyone wants to know, I burned the data DVD using xfburn in Linux.
Old 11-24-2013, 07:44 PM
(double-post -- please delete)
Old 11-25-2013, 05:37 AM
wcr3d wcr3d is online now
Mein Auto: 2013 535iX M Sport
This is correct. The changer doesn't have the firmware to be capable of playing them.
Old 11-25-2013, 05:39 AM
My 06 CCC isn't capable. It can be coded for it yes. I think the standard changed on the CIC units, along with adding the usb and aux ports. Which sadly I don't have either.
Old 11-25-2013, 05:54 AM
DIY'er
How can it be coded if it isn't capable
i.e. it's capable, just isn't allowed to by default
AUX port is a very easy add-on. You should consider adding it
Old 11-25-2013, 06:01 AM
The head unit is capable. The changer is just that, a slot changer/reader which isn't. I don't know this positively but I have done heavy research as this what my intention, to the point of purchasing the changer only to find this out.
I would love the aux port but iffy about pulling my baby apart! :-) I have been debating about having the dealership do it, they wanted $250 for cable, installation and coding. Sadly, I don't have an indy in my area I trust.
Old 11-25-2013, 08:20 AM
DIY'er
Gotcha--yeah some of the plastic parts can be a little iffy on getting them out in one piece if they haven't been removed in a while. The wood trim across the dash is also tough to get started without chipping any corners or anything
I hate to say it, but if they'd come down to more like $200 I'd probably let them do it
Old 02-13-2014, 10:18 AM
Rrosol Rrosol is offline
Mein Auto: 2008 550i
The radio presets aren't just for the radio. They can be programmed to call the wife, banker, or boyfriend. Just bring up that person in iDrive, and instead of hitting Call, press and hold a preset button. I suspect this works for all kinds of iDrive functions, now that I think about it, e.g. checking oil level and other hard-to-find functions. I still need to play with it a bit.
Old 02-13-2014, 10:20 AM
The radio presets aren't just for the radio. They can be programmed to call the wife, banker, or boyfriend. Just bring up that person in iDrive, and instead of hitting Call, press and hold a preset button. I suspect this works for all kinds of iDrive functions, now that I think about it, e.g. oil level and other hard-to-find functions. I still need to play with it a bit.
Old 02-13-2014, 01:27 PM
Happywith535i Happywith535i is offline
Mein Auto: 2009 535i
That space in the trunk is for installation of the cd changer.
Old 02-13-2014, 05:44 PM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
Buyers Remorse
Old 02-13-2014, 09:09 PM
DIY'er
Originally Posted by A B Able Truck View Post
Buyers Remorse
Lol
Old 02-13-2014, 11:17 PM
ilicboris ilicboris is offline
Probably been mentioned before, but the center console arm rest on the driver side can slide forward. Much more comfortable. Thought I broke it the first time it happened about 6 months into ownership lol.
Old 02-14-2014, 01:09 PM
Marine0369 Marine0369 is offline
Mein Auto: 2001 Ram 2500 4x4 Cummins
I discovered the windshield squirters are not that great.
Mike
2009 535i X Drive Premium Monaco Blue
Old 02-16-2014, 07:50 AM
The reverse lights suck. Searching for an upgrade.
Mike
Old 02-17-2014, 02:47 AM
NedB NedB is offline
Mein Auto: 550i
I just ordered these to try to solve the poor backup light problem. I'll let you know how they work.....
Old 02-17-2014, 05:04 AM
Great! Thanks.
Sent from my KFTT using BimmerApp mobile app
Mike
Old 02-17-2014, 05:26 AM
I can't turn the outside lights completely off with the car running. Anyone know how to do that?
Mike
Old 02-23-2014, 03:45 PM
afscotch afscotch is offline
Mein Auto: 2010 535i
I learned many things:
1) I can spend most of a Sunday reading a single post (read all 32 pages today)
2) I now know several neat 'tricks' for my car, thanks!
My contribution:
I have the only BMW (per two different dealerships) WITHOUT the rack mounting things on the roof. Every other BMW I've seen has the four little pre-made cutouts you can screw a rack into. I asked two dealerships why I don't have those and both said they didn't know and they hadn't seen a car without them before.
Old 02-23-2014, 03:52 PM
flipwils11 flipwils11 is offline
Mein Auto: '80 M535i, '12 M3, '04 xi
I read your post and and it made me wonder about the 550i I bought about a week ago. Ran out to the garage, wtf, I don't have them either. My e39 540i had them!?
So much for my Thule roof rack from the 540i...
Old 02-23-2014, 04:37 PM
Straight 6 Straight 6 is offline
Mein Auto: 06 530xit
How about having the wide band weather channels? Came in real handy while I was navigating ice and snow storms in the Carolinas with my 06 530xit.
Old 02-23-2014, 04:51 PM
jeffbtx jeffbtx is offline
Mein Auto: 2008 M5
The weather band was coded in on my 2012 E92.
