Old 11-06-2013, 04:59 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: Ford Pinto
Originally Posted by BMW_745Li View Post
Hi Papper...
Im interested in purchasing the facelift MMI and facelift ASK unit
Can you please provide me with prices also if you plese make it clear for me wich kinds of those modules are good to go with for example ASK unit manufactured 13-06 is good while 02-06 is not.
I sent you a PM on this site so check your PM box .
Old 11-06-2013, 11:00 PM
BMW_745Li BMW_745Li is offline
Mein Auto: 2003 745Li
By the way Papper...
What is the program you use to change the ASK unit firmware so it can communicate with the FM tuner after replacing to a newer ASK?
Old 11-25-2013, 07:04 AM
louis maeshiro louis maeshiro is offline
Mein Auto: 05.E66 760Li
Old 03-04-2014, 04:44 PM
Cummins_12v Cummins_12v is offline
Mein Auto: E65 04 730D
I have a 11/2003 mod e65 730D, i think its not a feclifted ask and mmi, can bmw dealer program the unit to work With this oem aux cable or do i need to get the dension module?
Old 03-04-2014, 07:06 PM
PAPER's Avatar
CRISP & CLEAN
It is clearly stated in this topic & in the videos & there description ,
That you need the FaceLift parts ...
Old 03-04-2014, 10:29 PM
Can bmw update software?
Old 03-05-2014, 01:18 AM
PAPER's Avatar
CRISP & CLEAN
Old 03-05-2014, 01:37 AM
Ok, thanks for tge info then i need to buy a dension gateway
Old 03-17-2014, 07:30 PM
andinoj andinoj is offline
Mein Auto: 2006 BMW 750LI
hello paper do you remember what is the color code for the pins in those numbers
Old 03-17-2014, 07:33 PM
If any 1 needs any info on the Aux input's they are 2 = right , 7 = left , 8 = ground
feel free to PM me ...
Old 03-24-2014, 02:19 PM
rbhaynes rbhaynes is offline
Mein Auto: 2006 BMW 760 Li
Can I install the Aux in my 2006 760 LI? not sure if I have the facelift ask and mmi? how do I tell?
Old 04-09-2014, 09:43 AM
Mike170 Mike170 is offline
Mein Auto: 2004 Bmw 745li, 2013 S550
Hey paper
I followed your instructions and i canít seem to get this to work.
I have an 04 745li. i upgraded the following to the facelift model, Ask unit, mmi, Tcu, Navigation,and Tuner. The mmi already had the aux when i bought it, it came off a 2007 bmw 750i, the ask came off a 2006 750i with a manufactured date of 20051104 which Iím assuming is november,4,2005 . everything works eccept the mode button, when i press it its like it goes into a unknown mode than i have to manually put it into another mode, fm and am works fine. when i plug the aux cable in it does not give me the option to adjust aux volume and i do not have any sound coming from aux.. do you think its a coding issue or ask unit issue? Thanks in advance and sorry for the long story .
Old 04-09-2014, 10:27 AM
blue is left red is right and brown is ground
Old 04-09-2014, 03:12 PM
PAPER's Avatar
CRISP & CLEAN
Originally Posted by Mike170 View Post
Hey paper
before you plugged the cable in , Did you get the volume option from Aux
setting on your MMI screen ???
As for your mode button . You either did not upgrade the AT Tuner , or the 1
you bought is not from a FaceLift vehicle .
Old 04-09-2014, 03:16 PM
no volume option ever for the aux.... radio and all others work. i got the tcu from the same car i got the ask unit and navigation from, which was a 2006 750i.
Old 04-09-2014, 03:23 PM
is the ask unit facelift with that date?
Old 04-09-2014, 03:25 PM
PAPER's Avatar
CRISP & CLEAN
ok not sure why your talking about TCU when I mention AT TUNER ???
As for the AUX , you have the wrong Ask unit that is not capable of
working with the Aux cable . May I suggest you get an Ask unit from
a late build 07 or 08 .
Old 04-09-2014, 03:34 PM
yea i ment to say tuner typing to fast. yea i figured that i needed a later one, at 1st i was told that i had to get the ask unit with mode and am/fm on the front but i found out after researching that it had to be after a curtain date. so that was a $1500 well spent.., i thought maybe it was just a coding issue i was having for the aux. Thanx for the quick response Paper.
Old 04-09-2014, 04:17 PM
PAPER's Avatar
CRISP & CLEAN
Old 04-14-2014, 06:20 PM
Allwhite750i Allwhite750i is offline
Mein Auto: 06 750i
Ok so my door speakers on the driver side has no sound at all. Paper I remember saying in a past thread that it was the ask unit. My driver door speakers and my driver side sub has no sound AT ALL. paper my question is if I replace the ask unit should it be a facelifted one so I can install my aux cable to it? If so should that also be from a late 07/08 model as well. If so would I still have to get it coded to work?
Old 04-14-2014, 06:40 PM
PAPER's Avatar
CRISP & CLEAN
If you read this topic , or even watched the
Videos . You would not be asking me these
Questions .
If your car does not have the Aux feature
Then of course it needs to be coded .
As for should you replace your unit with
A Facelift unit . well that's your decision to
Make . & if you do decide to upgrade it you
Should buy definitely get a late 07 or 08 unit
Old 04-14-2014, 06:46 PM
Mein Auto: 06 750i
Well paper in your video u did not mention anything about speakers. It was all on the aux mod. Let's just assume I'm not tech savy, and have no idea of what your talking about. In layman terms....I have to upgrade my ask for my aux to work...correct? I need a new ask anyway because my speakers aren't working...correct? U shouldn't try to make people feel stupid when they ask you questions about something your obviously experienced in.
Old 04-14-2014, 08:30 PM
PAPER's Avatar
CRISP & CLEAN
Ok let's see , You made some STATEMENTS about your speakers not working ...
Then you asked some QUESTIONS .
Here let me post up your questions , I will even quote them ===
" paper my question is if I replace the ask unit should it be a facelifted one so I can install my aux cable to it?
If so would I still have to get it coded to work? "
Now I was not trying to make you nor anyone look stupid with my reply .
I was simply stating , That had you read the topic or even watched the video's
You would not have had to get in here & ask any questions , As the answer are
already posted in this topic / video's & a hundred other topics on this site in this section .
Also in my reply I gave you the answers to your questions .
" of course it needs to be coded "
" should you replace your unit with
Make "
" definitely get a late 07 or 08 unit "
So let me ask you , why are you asking again ???
Old 04-14-2014, 08:36 PM
Mein Auto: 06 750i
For your expertise Paper. Don't want to get something I don't need.
Old 04-17-2014, 01:43 AM
sI--Iark sI--Iark is offline
Mein Auto: 750 Li 2006
Dear Paper,
I like your way in explanation and questionís answering , I need your support if possible I have BMW 750 IL 2006 individual , I want to connect either the I phone and/or iPod (Bluetooth) to have my music box inside the car , which parts should buy ? and did you know about the possibility of install USB connection ?
And it is possible to deliver it to Saudi Arabia
Thanks on advanced
M. Matar
