Engine Surging - Bimmerfest - BMW Forums
E28 (1982 - 1988)
Old 06-29-2012, 04:44 AM
madde889 madde889 is offline
Mein Auto: 1986 528e
Engine Surging
My '86 528e has been running perfectly for 7 years until a few months ago. I turned it on and it revved itself to 4000rpm (straight 6... it tops out at 5k). After a while it levels back to normal idle rpms but it surges up to 2500rpm. When driving it, it automatically accelerates itself to these rpms.
I checked a bunch of the hoses but stopped once I started contorting my body. I tried to unplug the cold start plug last night but it didn't make a difference.
What is going on!!
Old 06-29-2012, 11:17 AM
south26 south26 is offline
Mein Auto: 535i 1989
Most likely it either has a bad icm which is the green box next to the ecu or the icv. You can try cleaning the icv out with wd40. Take it off and spray it with wd40 until it runs out clean.. with both I have good ones. 15 for the icv and 25 for the icm. Plus shipping.
Andy
Old 06-29-2012, 04:27 PM
Thanks, I'll try that!
Old 12-05-2013, 04:06 AM
gb87528 gb87528 is offline
Mein Auto: 87 528e
surging
crank up cold idles at 800 for about 30 seconds surges from 400 to 1000 until engine warms up then idles perfect at about 650 any ideas ICV oms out perfectly cleaned and replaced the icm with a suppose to be good one.
Old 12-30-2014, 02:18 PM
For anyone who reads this thread: This particular surging problem was caused by an item in my glove box pushing against the computer that lives behind it! Open glove box, shift around items, close box.
Sometimes BMW does weird things.
Old 12-31-2014, 10:32 AM
catso's Avatar
catso catso is offline
catso
Sounds like either the ECM or ICM connector is loose or not making good electrical contact. Older vehicles tend to have alot of electrical issues.
![/I][/FONT]
Old 01-12-2015, 01:18 PM
BMWFatherFigure's Avatar
Old School
They sure do.
Current:
E38 Parts Car
Previous:
