my idle keeps climbing. - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 12-05-2013, 02:06 PM
rustyroots rustyroots is offline
Mein Auto: 1986 bmw 325 es
So i have a 1986 325es i recently took off the valve cover to adjust my valves but i didn't have the right box end wrench, but ever since i put the cover back on my car is idling really high until i put it in gear and when i decelerate the car bogs down, I'm thinking it's the idle air control but it still acts almost the same when unplugged any suggestions?
Old 12-06-2013, 01:29 AM
Billwill Billwill is offline
Mein Auto: BMW E30 318i 1991
Is the valve cover seating firmly? You need a good gasket or RTV silicone to stop vacuum leaks there.
Old 12-06-2013, 04:13 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
Or you could buy a valve cover gasket and torque it down properly .Also you might want to check your oil cap seal and make sure you didn't pull one of the U shaped seals (rocker arm shaft plug) up and forget to put it back (in the back by the fire wall most likely). Also since you had to remove your ICV to get the valve cover off you should check the hoses carefully to make sure they didn't crack and cause a leak.
Old 12-06-2013, 09:49 AM
Re: my idle keeps climbing.
I have new gasket on order and I already replaced the icv hose so I'm hoping the new gasket works will update.
Old 12-06-2013, 08:43 PM
As silly as it sounds my little bullet connector to the idle air control had a broken connection.
Sent from my SGH-T769 using BimmerApp mobile app
Old 12-07-2013, 01:13 AM
Not silly at all....little problems like this on an old car will always happen and grind things to a halt!
Old 12-07-2013, 02:41 AM
2002-530I 2002-530I is offline
Mein Auto: 2002 BMW 530I Sport
Sounds like you have a leaky valve cover gasket.
I'd try eliminating it by using a pair of smooth pliers such as needle nose that lock and pinch off the CCV/PCV that goes to the intake. If the idle drops while you plug it the problem is the valve cover...
Old 12-07-2013, 09:20 AM
toybuilder's Avatar
I wouldn't do that unless you have another hose they usually get brittle from being under the intake and will crack if you try to pinch it off. It's not regular hose it's heavy vacuum hose and can't be replaced with just any old hose .Once it gets oil in it and gets hot it will collapse and stop working ,making a big mess under your hood not to mention the leak.Did you replace the connector on the IAV man those things can be really sensitive, they need to be dead on or they just don't work worth a damn .
Old 12-07-2013, 08:05 PM
I didn't realize they were not made of regular fuel vapor hose. How about disconnecting it from the intake and plugging it?
Old 12-08-2013, 05:26 AM
BMWFatherFigure's Avatar
Old School
That would work as a test. Check all the hoses for splits and cracks. If you were that bad at putting the top back on you would have an oil leak too. Does it leak oil?
Current:
E38 Parts Car
Previous:
