E36 (1991 - 1999)
Old 12-05-2013, 11:03 AM
Norcal325 Norcal325 is offline
Padawan
Mein Auto: 325is
New E36
http://imgur.com/1MX96Yq,48f5Bu4
http://imgur.com/ZiWca2o
http://imgur.com/b6wuBUW
Hey guys, so after a brief love affair with a Civic Hatch I'm back in an e36. Its got 250k on the clock and is full stock. It handles like a Cadillac right now, but the engine feels super smooth, and pulls strong. No chain slap or vanos noise or anything which really surprised me. The PO used Rotella T-6 diesel oil so maybe that's one factor that helped.
I was wondering in terms of performance what are the Cons and Pros (if any) to running 15 inch rims? Could I run 15" wheels with spacers and some camber for better contact patch? There's just so many more wheel and tire options in 15", and more affordable as well. I do have a set of 16" 325is sport rims which I will probably bust out, but I'm not a fan of how they look.
Old 12-05-2013, 11:46 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Pros of 15" wheels:
- Quieter interior
- Smoother ride
- More durable/resistant to bending/cracking due to additional tire sidewall.
Cons of 15" wheels:
- Unresponsive handling
- Lower grip levels on dry pavement (because smaller diameter wheels tend to be narrower as well)
- Visually unappealing - 15s look quite small on the E36 body
I definitely recommend saving up your money and getting a proper set of 17" wheels & tires. 17x8.5" really is the perfect size for the E36. Not too big, not too small - perfect!
1998 BMW 328is
1966 Pontiac GTO
Old 12-05-2013, 12:18 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
I agree with this...."I definitely recommend saving up your money and getting a proper set of 17" wheels & tires. 17x8.5" really is the perfect size for the E36. Not too big, not too small - perfect! "
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 12-05-2013, 03:15 PM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
a set of 13x8's tucked and streched looks bitching...
15486372<-----
Old 12-05-2013, 07:21 PM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
LOOOL!!! NO!! Do not listen to this guy!!
By the way, diesel oil is fine and all, but it turns the inside of your engine black. The high phosphorus content in the oil also clogs up your cadillac converters, mess up your O2 sensors, clog up your muffler, and that's about it. Other than that, with the high calcium count that diesel oil has, especially with Rotella T6, it is very good for the cylinder walls.
I remember Bob is the oil guy did a nice review about using diesel oil when going racing. Even provided some samples from Blackstone labs.
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 12-06-2013, 06:15 AM
Burning2nd's Avatar
Under the lift arms
hahnz doesnt approve of my go cart wheel look lol
15486372<-----
Old 12-06-2013, 02:00 PM
Padawan
Mein Auto: 325is
Yea I guess I'll save up for some m3 wheels or some sort of 17's.
Hmm actually the car did just fail smog. It was running rich and had high NOx. My mechanic friend ran his OBD computer and said my o2 sensor wasn't "cycling". I have till Feb to pass smog so maybe I'll switch oils before my next smog, in addition to trying a working o2 sensor.
Old 12-06-2013, 06:28 PM
hnaz's Avatar
BMW CCA Member
Get some sea foam and drive like mad. Then drain the oil. You may need to replace your O2 sensors as well.
I remember there was a liquid you can use in your gas that would burn hot enough to start melting the crud on your cadillac converters. Or just take it to a Dyno and drive it hard. The key is heat to melt the crud off your exhaust.
My Previous Work:
Old 12-06-2013, 11:35 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
That reminds me of a thread I saw on the Toyota forums. I think it might be relevant to the conversation http://www.toyotanation.com/forum/10...h-me-luck.html.
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 12-07-2013, 12:58 AM
Eight Thirty Eight Thirty is offline
Hellawut??
Mein Auto: who knows?
will 13" even clear the brake calipers??
Serious question. :serious:
-Franklyn
Old 12-08-2013, 04:29 AM
Burning2nd's Avatar
Under the lift arms
No.... I dont think so ..
I was joking about a track car we has back in the day.. It was accutlly on a set of rims from a e30 M3 (bbs's) But they were stretched walls... so it looked like 13"stretched
15486372<-----
Old 12-08-2013, 12:25 PM
dc_wright's Avatar
13s will barely clear the rotors let alone the caliper. Front rotor diameter is 11.26". ID of a 13" cast alloy wheel is probably around 12", maybe less.....
Old 12-11-2013, 10:33 PM
gbundle gbundle is offline
Mein Auto: 1997 328i Convertible
What happened to Marie?
I saw the R.I.P. What happened to Marie?
Old 12-11-2013, 11:44 PM
hornhospital's Avatar
D'oh, You Kids!
Got rear-ended. He's still waiting for the insurance to decide if she's totaled or not.
Quotes to live by:
