Water Pump Average Longevity - Page 2 - Bimmerfest - BMW Forums
Old 05-18-2013, 03:16 PM
ddeliber ddeliber is offline
Loving my d
Mein Auto: E350 & 2011 335d
Woke up this morning to this (see first attached pic - inside and just in front of the driver's side front wheel).
Haven't even started it up yet, it wasn't overheating yesterday so I don't know the cause. I just went on parts.com and was pleasantly surprised by the price of the water pump $141.25 (mine is a diesel) even though I doubt that this is the problem - small leak (it is water though) and only 25k miles on my 2011. I am dreading diagnosing this though, hopefully it is just condensation or something. Anyone have any thoughts.
Old 05-18-2013, 03:44 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
You smell antifreeze in that water?
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 05-18-2013, 03:45 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 17Outback
Sounds like you have a mechanically driven water pump not electric.
BMW has a good idea with the electric but should would be nice to be at least a 100K mile pump...
Old 05-18-2013, 04:13 PM
Loving my d
No, but I can't be sure. I gave it a good sniff on my fingers, but waaaay too much pollen in the air for my nose to be working properly.
Old 05-18-2013, 04:14 PM
Loving my d
Yep. Not sure if this is a good thing or not though.
Old 05-18-2013, 04:23 PM
thekurgan's Avatar
thekurgan thekurgan is offline
Bad Lieutenant
Mein Auto: S62B50 Powered
Attachment 377206
Attachment 377207
Attachment 377208
I don't think a failed pump is going to leak like that, it looks more like the expansion tank or hose related. It is a mechanical pump in the diesel, however.
Name:	Screen Shot 2013-05-18 at 4.25.03 PM.png
Ilse
2002 E39 M5 / TiAg / Tubi Rumore / E60 SSK / Blanton 3.45:1 7 disc 40/100% locking diff / NCS Coding / Coby Alcantara / StrongStrut STB
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 05-18-2013, 04:43 PM
Leekay07 Leekay07 is offline
Mein Auto: MY12 550I,MY09 X5.
the dealer charges less than 1200 for the pump and thermostat replaced and full coolant drain. It comes with 2 years unlimited mile warranty which can't be beaten. My last pump lasted 4 years 2 months from in service date and 127,000
If you like customer service. Don't look beyond a BMW.
Old 05-18-2013, 04:48 PM
Loving my d
I did check the reservoir and it is full, the float is all the way to the top. Is there any way this is not coolant?
Old 05-18-2013, 04:54 PM
thekurgan's Avatar
Bad Lieutenant
Coolant has a unique sweet smell, if you have a cat, make sure that puddle is cleaned up. The best way is to examine from underneath and trace fluid drippings. Did you run the A/C before this happened? Could be water.
Ilse
Bruna
BMWCCA #453648
Old 05-18-2013, 05:00 PM
Loving my d
I do know what coolant smells like I just can't smell anything right now. I did run the ac for the first time in a while yesterday. But hat was at about 6 pm. I found the puddle this morning at around 11 and it was still slowly dripping. Doesn't 17 hrs seem like a long time here?
Old 05-18-2013, 05:09 PM
galahad05's Avatar
Better with Butter
I think you'll just have to monitor things and try out AC-on/AC-off runs over a few days.
-- Irish Proverb
Old 05-18-2013, 06:05 PM
thekurgan's Avatar
Bad Lieutenant
There aren't any thin fluids within the bay, if it's not water, it's most likely coolant, it doesn't smell like water and is colored.
Ilse
Bruna
BMWCCA #453648
Old 05-19-2013, 05:24 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
Mike Miller tech expert for the BMW car club used to recommend replacing all BMW water pumps at 60k miles due to their high failure rate beyond that point. His maintenance guidelines dropped that recommendation a few years ago for the e9x cars because he said the cost for replacement of the electric fuel pump is high, and the sensors and controls in the engine will keep the engine from overheating and damaging the motor. If the DME senses the engine is starting to overheat, it will put the car in limp home mode or shut it down. The problem some BMW owners report is that the DME makes these changes while the car is being driven without any warning. Going into limp home at speed on a highway is dangerous. I will probably change mine before it breaks just to avoid being stuck on the side of the road with a car that can't be driven.
Old 05-19-2013, 05:37 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
Originally Posted by bbbuzzy View Post
I also have an '06 330i ZSP. My water pump never died but was replaced at 139K at the same time as the thermostat, after the T-stat threw a code on the way to a track inspection, prompting me to deal with it right away.
That's what I gathered from bimmerpost.
Some people said that before failing, the WP¨issued a few low speed codes months ahead. So I check it every 2-3 months.
Old 05-19-2013, 05:55 AM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
I have the OBD2 reader, would that pick up this code?
When this t-stat code showed up did it have a check engine light on? Or you just plug OBD2 in every 2-3 months to see if it pops up anything?
142k miles original pump/thermostat. I was at dealer for service a month ago and they did the read in general but didn't say anything about this.
Old 12-21-2013, 07:09 AM
Boraxo Boraxo is offline
Mein Auto: ED 330i
Just reached 92k miles (almost 8 years) and I got the dreaded temperature light on my 330i after about 15 minutes of driving. Thankfully was able to pull off the freeway in one of the few decent neighborhoods in Oakland and call for a tow. Hoping it is just the water pump though I had noticed a high pitch whine when I started it up. Some coolant bubbled off when I opened the lid so maybe a leak?
My indy shop is quoting $1000 to replace the pump, hoses and thermostat, the local stealerships in the East Bay want $1300-1500.
1993 325i - gone!
1997 328i - gone!
Old 12-21-2013, 10:50 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Originally Posted by boramkiv View Post
122,000 miles and still on original water pump with N52. It's had three coolant flushes, and two battery changes. The electric pump can last some time if taken care of.
Of course as I'm typing this the pump will go out tomorrow afternoon at 3:53 PM EST.
I do plan and changing it out along with a few other parts here in a few weeks though.
That is why you are still in good shape. Regular coolant changes definitely extend the life of the pump. I plan on doing the same and proving myself right. Corrossion is definitely the enemy of passages and electronics if infiltrated.
Old 12-21-2013, 10:53 PM
sptt144's Avatar
That is why you are still in good shape. Regular coolant changes definitely extend the life of the pump. I plan on doing the same and proving myself right. Corrossion is definitely the enemy of clogging coolant passages and infiltrating electronics that fritz out!
