Intake hose popped off, any damage possible? - Bimmerfest - BMW Forums
Old 12-21-2013, 05:11 PM
Mk23's Avatar
Mk23 Mk23 is offline
Corner Carving Addict
Mein Auto: 09 - 335i E92
I got my car back after getting a HPFP put in my car (long story, not really the HPFP that was the culprit, so wasted money there...) and was at a light and accelerated away hard when I heard a loud pop and then weird and loud turbo sounding noises after going over 2k RPMs. I thought it was a backfire at first since I was having emission issues. I also had a huge loss of acceleration after you got to 2k RPMs. I drove for awhile like this trying to keep it in Drive and under 2K RPMs since that's when I would hear the noise. I got home tonight and thought I would take a look under the hood and visually inspect things and I notice the picture below.
I let the car cool down and then put it back on and tightened the hose clamp and everything runs fine now. My question is if any damage could have been done to my turbos or engine because of this. I have to talk to the shop that forgot to tighten the clamp and want to make sure there is no way any damage could have been done.
Any help is appreciated. -Thanks
Old 12-21-2013, 09:17 PM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
I believe that is your charge pipe.
As long as you didn't drive an extended period with it off, you're fine. It will only allow unfiltered air into the engine. That will only damage something if you do it for tens of thousands of miles.
So basically, you were creating no boost and thus the reduced power.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
Old 12-22-2013, 01:26 AM
Mk23's Avatar
Thank you for the reply. Yeah it was only for about 10-15 miles. Appreciate the help.
Old 12-22-2013, 04:01 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
It is not Love Bug season, and you may thank God for that. But your cyl intake was open to the environment, Hoovering all. We cannot know the result.
Old 12-22-2013, 09:25 AM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2018 440M-Sport MPPSK/THP
Mein Auto: 2018 440M-Sport/MPPSK/THP
You might want to think about a metal charge pipe to replace the plastic factory one.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/THP 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 12-22-2013, 09:31 AM
White94RX White94RX is offline
Mein Auto: E39 540
Re: Intake hose popped off, any damage possible?
No, you don't have anything to worry about
Sent from my DROID RAZR using BimmerApp mobile app
BMW Level 1 Master Certified
2001 BMW 540i
