Old 12-21-2013, 09:30 PM
nhe666 nhe666 is offline
Mein Auto: 2002 325ci stick
Wink Manual Trans, why sometimes only one wheel spins while doing burn out
i have a 2002 325ci with 18inch 5 series rims, i was wondering why on dry pavement sometimes when i do a burnout both wheel s spin and sometimes only one?
Old 12-21-2013, 09:36 PM
traction control
i do this obviously with the traction control completely off (triangle and yellow brake light come on)
Old 12-21-2013, 10:13 PM
Fast Bob's Avatar
Keeping it surreal
Because like ALL non-M BMWs, your car has an open rear, hence the "pegleg burnout". (You can cure that for around $2500 or so).
The road goes ever onward....
(R.I.P. Jever)
Old 12-22-2013, 12:31 AM
but sometimes they both spin? can you put a diff. from an e46 m3 in the car, would they both spin all the time then?
Old 12-22-2013, 01:08 AM
lgr122 lgr122 is offline
For example this would do it i believe.
http://www.turnermotorsport.com/p-13...tial-unit.aspx
Can be some other brands and companies available as well.
If pile of money is ready in your pocket, you can find whole pile of goodies up there where it says "Site Sponsors"
Old 12-22-2013, 02:57 AM
OlgaMPM OlgaMPM is offline
Mein Auto: E46
No LSD. Cheapskate BMW AG
Old 12-22-2013, 03:12 AM
True.
Burning rubber is waste of BMW.
Should learn to drive it for real.
Old 12-22-2013, 05:53 AM
well its a brake assisted lsd whatever the hell that means. so no its not a true one, and your right about saving the rubber but it occurred when i was getting new tires i noticed it
Old 12-22-2013, 08:18 AM
Fast Bob's Avatar
Keeping it surreal
You are correct in your assumption that this is a pseudo/electro/semi/imitation LSD that is nothing like the real thing. And yes, every once in a while , you can get both wheels to spin, but only when all the planets are in proper alignment (and you can`t do it on demand).
(R.I.P. Jever)
Old 12-22-2013, 08:40 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I remember one time someone asked me how long of a number 11 I could make in rubber. I said "I can't, but I can leave a nice long lower case i"
Old 12-22-2013, 10:04 AM
tmba2002's Avatar
tmba2002 tmba2002 is offline
Professional Amateur
Mein Auto: 2005 330CI ZHP
With the price of tires for these cars....why???
Follow me once, follow me twice, follow me on Twitter
Old 12-22-2013, 12:33 PM
FredoinSF FredoinSF is online now
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
My guess is age - young age. This is the kind of stuff I used to do when all I had to worry about was my own college tuition. I baby the cars now compared to those days.
Old 12-22-2013, 12:46 PM
no im not young, i just wanted to see because i was getting new tires that day, it was just curiosity
Old 12-22-2013, 12:50 PM
davidmaria1 davidmaria1 is offline
Mein Auto: 2011 X5 3.0 Gasser
Youth. 20 some odd years ago, I would bang 2nd gear in my Chevelle (a real 69 396 SS) and "lay a stretch". It was fun. A lotta fun! Now, I savor and hoard any and all remaining testosterone.
THINGS I'VE DONE: Cooling system refresh with radiator, key fob surgery, pulleys and tensioners, CCV cold weather, DISA gasket, OFHG, Fuel pump/filter PM, ZF auto trans fluid/filter, motor mounts, fcabs, trans fluid change, steering guibo, rear wheel bearings and hubs,
2001 330 has left the building
X5 fun includes: Battery. Trans fluid change. Nav update. Idler pulley replacement. Steering fluid flush. Tension struts. Pressure lip seal. TCS fluid flush.
Old 12-22-2013, 01:05 PM
Fast Bob's Avatar
Keeping it surreal
"Getting rubber in all four gears" was a trademark of those old torque-monsters
In my heyday, Sunoco 260 (leaded 104 Octane) was 38 cents a gallon....
(R.I.P. Jever)
Old 12-22-2013, 01:58 PM
I never saw that. I used Sunoco 94, a can of 104+ octane boost, and occasional cans of lead additive. And a Jim Beam sour.
I only spun the tires a couple times going into 3rd. It was easy to miss that shift, and over-revving a big block was heart stopping.
Old 12-22-2013, 02:44 PM
smolck's Avatar
ROLL TIDE!
Re: Manual Trans, why sometimes only one wheel spins while doing burn out
I used to launch my 5.0 mustangs in 2nd gear for a very large cloud of smoke. Torque, it is a blast!
Sent from my HTC One X using BimmerApp mobile app
Old 12-22-2013, 03:28 PM
EdCT's Avatar
EdCT EdCT is offline
zeddy
Mein Auto: '06 330cic ZHP / '07 M35x
Look up "open differential".
2000 Mercedes Benz E320 (daily driver)
2007 Infiniti M35x (wife's)
2006 330 cic ZHP 6sp (current)
2005 Z4 3.0 sp nav x-leather (retired)
2000 323i PP (best car, ever - retired)
Old 12-22-2013, 04:09 PM
Chris90's Avatar
Chris90 Chris90 is offline
Mein Auto: '04 330i
My biggest regret with my E46 was not buying an LSD years ago. Too late now, don't want to blow $2500 at this point.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression
Old 12-22-2013, 04:25 PM
Fast Bob's Avatar
Keeping it surreal
I was quite disappointed to find out (after taking delivery of my car) that LSD was not a standard part of the Performance Package....that revelation failed my "Common Sense Test"....
(R.I.P. Jever)
Old 12-22-2013, 08:33 PM
tmba2002's Avatar
We used to mix aviation gas with premium, I think the stuff we would get was 115/135 octane. Its a lean/rich octane rating for piston plane engines. A friend's father would buy it by the 55-gallon drum.
Oh the good o'l days...
Old 12-22-2013, 10:59 PM
Mein Auto: ///M
u can only drift for so long as long as both wheels have 0 grip on the road (dirty roads) which will be for 1 donut or 1 power slide at a time. any more than that and u'll under-steer, or go straight since the power is distributed to tire that has more grip.
this is where the LSD comes in, which u guys don't have sorry couldn't help it
i wonder whatever happened with Mal and his diff build
Old 12-22-2013, 11:11 PM
Fast Bob's Avatar
Keeping it surreal
Correctomundo....with an LSD, and enough horsepower (or a loose-enough road surface) to create "Oversteer On Demand", you can steer the car with all 4 wheels until the cows come home....
(R.I.P. Jever)
Old 12-22-2013, 11:46 PM
3star 3star is offline
Mein Auto: 89 E30 Cabrio
because you have an open diff aka one wheel drive lol
Old 12-23-2013, 10:31 AM
smolck's Avatar
ROLL TIDE!
What is funny to me is when I had my Mustangs with LSD we always thought it sucked compared to a spool. But those were drag racing days.
burnout, burnout control, one wheel spins, posi rear, posi traction, two wheels spin
