Old 01-14-2014, 06:51 AM
davewoolley davewoolley is offline
D Woolley
Mein Auto: 05-645 / 14 435I
Coolant pipe
I had a little green fluid under my car yesturday , have any of you all had to replace ?if so what kind of cost is this?
Old 01-14-2014, 12:37 PM
coug60's Avatar
coug60 coug60 is offline
06 BMW 650i Sprt/Prem Pkg
Mein Auto: 2006 BMW 650i e64
More information...
Where ie front, back, right-side, left-side...
Is it green or actually got a little blue tint to it and seems oily?
2006 BMW 650i Sport/Premium Package
+ Various Mods & Upgrades
Old 01-14-2014, 12:38 PM
645/333's Avatar
645/333 645/333 is offline
Michael
Hi! you need to find the source of the leak before you can ask the question!! I say this because if it is a simple leak ie one of the hoses, expansion tank fine !!!! The true coolant pipe leak is where the fluid leaks out of a weep hole at the front of the engine block, this is the tell-tale sign that the internal coolant pipe seal has corroded....If you look at the TIS you will see the location.
In the UK this will cost between 7k-9k to repair the one problem...... The threat of this leak is why I sold my 645 (N62 engine). I will never have a BMW with the N62 engine, I personally feel this problem totally undermines one of the best cars BMW have ever put on the road!!!!!
Old 01-14-2014, 01:50 PM
D Woolley
Left side as you're facing the car, green with a little blue to it and oily.
I haven't found the source yet was just asking a question.
Old 01-14-2014, 02:23 PM
645/333's Avatar
Michael
Hi! hopefully you can find the source and it is an easy fix, one of the pipes that does go is across the top of the radiator the small pipe. As you know a picture always helps many of the guys to help you ........ At least you have an idea of the implications of the coolant pipe leak. there are a number of kits on the market to fix it, the problem is not the fix that is very easy, the issue is the amount of work dismantling everything to get to the pipe in question, there are some excellent threads on the issue....
Old 01-14-2014, 02:47 PM
tampamark tampamark is online now
You could have several sources. Here are the common things to look for:
1. Expansion tank leak, left side of engine as you are looking at it.
2. Small plastic pipe that runs across the top of the radiator. Some folks have replaced this with copper tube like is used under your sink or to the back of your fridge.
3. Valley Pipe, this is the worst one obviously, it comes out of the weep hole in the front of the engine. Yorgi recently put a picture in for someone else so search "weep hole".
4. Leaky temperature sensor on the lower radiator hose. You would need to jack the car up and remove the bottom shroud, then you can get a good look at it. If this is it then you can DIY with a new O-Ring from Home Depot made by Danko (#31 I think???).
Old 01-14-2014, 07:23 PM
coug60's Avatar
Check sensor on radiator hose left side, front towards bottom
Check sensor and area around expansion tank. There is actually a seam there you can barley see, but will leak under pressure.
Also when you say coolant pipe. There is one internal to the engine (intake manifold area I believe), it leaks sometimes and when it does you'll have a different set of observations then a little puddle under the car..
So when you say coolant pipe most will think your talking about that one.
Old 01-15-2014, 01:58 AM
645/333's Avatar
Michael
Hi ! Been thinking about your leak, do you know the colour of your power steering fluid?? Some of them are green, you may have a leak on the power steering rack if it was oily!!!!!!
Old 01-15-2014, 03:48 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
BTW - that $7k to $9k price tag on the coolant pipe is if you have a dealer do it. They pull the engine to do the replacement.
An indy will use one of the kits and it will cost MUCH LESS. I've heard 3 to 5K. If you do the work, it's less than a grand. I plan to do it myself if I ever come to the problem.
Get a flashlight in there. It should be easy to find because of the white trace the coolant will leave.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 01-25-2014, 03:31 PM
D Woolley
Ok I drove my car for 30 min today but I haven't driven it for a week so when I left this morning the car left a trail of fluid it looks like green with light blue tint. I locked under hood before I left and found some fluid around that sensor in the front left where you all told me to look. I let the car cool down jacked it up and took off under carriage it was a mess. It's been jacked up sitting for about 2 hrs and I get a drip from this area. Any thoughts?Click image for larger version
Old 01-25-2014, 03:40 PM
HerbP HerbP is offline
I would look at the sensor 1st. Press the 2 tab on sensor in, & pull the sensor straight up. Make sure to have some ready to catch the coolant. If you have the front of the car jacked up, the coolant might be running down hill.
Old 01-25-2014, 03:47 PM
D Woolley
Ok I will check now, how do I tell if sensor is bad?
Old 01-25-2014, 03:59 PM
D Woolley
Herb there is a lot of pressure on that, am I assuming correct that when I pull it off all the coolant will drain out?
Old 01-25-2014, 04:19 PM
It will run out, but remove the cap on the expansion tank to remove the pressure. This is a quick fix that happens a lot. You can put a catch pan under that hose to catch the coolant. As long as it is clean, you can put it back in. If you crank the engine & build some pressure, you can watch it with a flash light.
Old 01-25-2014, 04:47 PM
D Woolley
Thanks, I will wait till Monday so I will have a replacement sensor.
Old 01-25-2014, 06:53 PM
maybellineo maybellineo is offline
Mein Auto: 2005 645 Coupe
Gee Mulch:
If you think 3-5K is not a lot of money, you can be my SugarDaddy!!!!! I am female by BTW.
Maybellineo
Old 01-26-2014, 03:44 AM
645/333's Avatar
Michael
Ok I drove my car for 30 min today but I haven't driven it for a week so when I left this morning the car left a trail of fluid it looks like green with light blue tint. I locked under hood before I left and found some fluid around that sensor in the front left where you all told me to look. I let the car cool down jacked it up and took off under carriage it was a mess. It's been jacked up sitting for about 2 hrs and I get a drip from this area. Any thoughts?Attachment 418897
That is clearly at the back of the engine, (provided it has not come from blow back when you have been driving). I know the coolant pipe weep hole is at the front of the engine, but unless anyone can add, it could be the rear seal on the coolant pipe at the back of the engine. I do not know if there is a weep hole there??? What you could do is look at the DIY's that guys have done, so you can see it stripped down it may give you more of an idea ???
IT is so hard to believe that BMW could design an engine with such an inherent weakness, that causes so much cost and distress to its car owners. 2 shabby little rubber seals costing no more than $10 can be the source of all of this......disgraceful really !!! What has made it worse is BMW's attitude to customers when this first started to happen across a range of cars. They never even fixed it in later models using the same engine N62.... You can understand failures occurring but this was going on for years on the V8 N62 engines. No wonder they have gone back to mostly 6 cylinders. one has to say that glorious straight 6>>>>>>>
Old 02-04-2014, 05:58 AM
D Woolley
Y'all are not going to believe this....
I took my car to bmw SA ( I'm in Port Saint Lucie and can't find a good Indy) they changed the oil and told me coolant sensor was leaking so I bought another one but they called and said the flat tire sign came up and they filled the tire but because I don't have the original rims they can't re set????? I told him he was full of it. So I went there and I guess the dumb ass didn't know you had to move the car for it to re set!!!
Old 02-04-2014, 08:08 AM
Hey Dave:
I believe it. The dealer here in New Orleans hires high school dropouts to work on these expensive cars. By the way, how much was the coolant sensor. Do you know where it was leaking, I mean was it leaking on your garage floor. I have so far spent $1800 & my car is still linking on the passenger side right behind the tire. It stopped for a couple of days when I picked up the car & thought it was fixed, nope. I think I am looking at another $2000.
Maybellineo
Old 02-04-2014, 01:45 PM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2014 BMW ///M6 vert
I recently had a coolant leak on the front passenger side... took it to my indy and he replaced the expansion tank, sensor (and I think the hose(s)) for under $300. Assuming its not the infamous weep hole leak, it shouldn't be very expensive.
Regards, Greg
'14 M6 vert, san marino blue on amaro brown full merino leather, drivers' assistance, exec package, B&O sound system, CCB package, akra exhaust, tint, windscreen, etc.
'07 650i vert, beige/jet black, sports & cold weather pkgs, comfort access, etc.
'11 Acura MDX Advance with Entertainment pkg for wife - no mod's '04 Acura TSX (daughter) and '12 VW GTI - Autobahn (son)
Old 02-04-2014, 02:36 PM
I already had that repair done but it wasn't leaking out @ the bottom though. I kept getting the add coolant. I know they changed the expansion tank & the hoses. Not sure about the
sensor though. I can check on the repair invoice though. With this leak I have checked the coolant tank & the stick is way high up so I think it is ok. What was the color of the leak. Mine looked kinda orange-yellow.
Maybellineo
Old 02-04-2014, 03:36 PM
Angel2 Angel2 is offline
Mein Auto: 2006 650i Conv
i live in miami and some shop did the coolant pipe replacement in my 650i for $1800
of course if you go to the dealer gonna cost way more
good luck
Old 02-04-2014, 03:39 PM
good luck
Would an after market extended warranty like Autopom pay for the cool any pipe replacement?
Maybellineo
Old 02-04-2014, 05:59 PM
D Woolley
Maybellineo
They replaced the coolant sensor and the hose that is under it, for 375.00
Also they replaced an oil pressure switch for 150.00
The coolant was leaking from the coolant sensor but when I parked the car over night there would be coolant on the floor underneath the sensor which was in line with the tire and about 12 inches from the tire, there was also some leaking on the floor about the middle of the car, I believe ( hope) that is just blow back from it leaking as I was driving, I will know for sure Tommorow morning.
Old 02-04-2014, 06:01 PM
D Woolley
Angel2
What is the name of your shop in Miami.
