Old 01-26-2014, 11:31 PM
DJ63's Avatar
DJ63 DJ63 is offline
Mein Auto: 2001 540/6 2014 328xdT
So thats what blew my CV and Diff seal, it was the altitude! Now I'm digging it in my Holiday Express room
Old 03-03-2014, 02:39 PM
Bimmerman4ever Bimmerman4ever is offline
Mein Auto: 97 740iL
Interesting read. I live in the high desert (above 4k feet) and my 97 328i has pretty good power at lower speeds (up to 50 mph).
I recently did a trip to the California bay area.
Below 2k feet elevation it felt like it added another 40 HP especially on the crazy freeways down there where 80+ mph speeds are common.
The car pulled hard all the way past the triple digits mph range. I was surprised. Once I got back home I was disappointed to lose so much performance due to the elevation increase.
Is there any work around to have the ECU/DME reprogrammed/mapped for better performance at higher elevations?
Or am I pretty much stuck with the dismal performance because of the thinner air?
From reading, unfortunately the later seems the case
Old 03-03-2014, 04:05 PM
HTK12 HTK12 is offline
Mein Auto: E39 540i
You need more oxygen in the engine. The only way would be go to FI.
Old 03-03-2014, 04:11 PM
Mein Auto: 97 740iL
"FI", you mean changing the fuel injector size or something else?
Old 03-03-2014, 04:12 PM
BioGuy BioGuy is offline
****ie
Mein Auto: 540i
FI= forced induction; ie- turbo or supercharger.
2006 Audi A8L
Old 03-03-2014, 04:17 PM
Mein Auto: 97 740iL
OK
Yes I've considered going with a SC. Just have to see what deals are out there.
I'm working on a Porsche 968 for a customer, brakes, HU, dynamat, etc..
when I'm done with it he's getting a SC installed in southern Cal'
It's a 3.0 liter 4 banger with a 6 speed manual
236Hp rated
Not bad the way it is now, but with a SC that would be great
Old 07-04-2014, 12:17 PM
A question was asked about learning today ...
> E39 (1997 - 2003) > E39 ECU "Learning"??
Originally Posted by HighAltitude View Post
Here's one for the BMW experts! I've been told that the 97/98 540i ECU has some kind of learning function in it to develop trim values for fuel. Over time, it will continue to refine these values. A reset can be done to clear them and start the process over. This was referred to as "adaptation" by someone on an older post on this forum, as well.
So, what's the deal? Does this ECU actually do that? And if it does, why? Any closed loop system with O2 sensors will continuously adjust the air-fuel ratio so I'm not sure i see the need for trim values.
That said, do all BMW models have this style of fuel control, or only certain models? I noticed on the later E39 models they went to one O2 (either before of after the Cat) instead on 2 (one before, one after the Cat). I wonder if that signifies a different control strategy.
Thanks for any intel!
air metering, altitude, ccv, diagnostic repair, dme, engine management, icv, maf
