Old 01-27-2014, 05:56 AM
zersys zersys is offline
Mein Auto: 02' E39 530i Executive HL
FSU battery drain - temporary solution?
Hi all,
Pretty sure my fsu is going bad, my fan blower comes on every couple of minutes to twenty seconds for about five seconds after the car is turned off, locked, and continues to do so in sleep mode.
Anyway, I refuse to pay Aussie prices for a new one. But I won't be able to get a new one from the USA soon, so I would like to know if there is a temp solution like pulling a fuse or something to stop it from draining the battery while it's parked at night. The solution has to be a two minute job though so that I can do each morning before going to work so that I can actually use the blower when the car is operational.
Cheers.
Old 01-27-2014, 06:11 AM
mjalloul11's Avatar
BMW forever
Mein Auto: 1996 528i 1999 MB C240
Remove the connection to the FSU . The main fuse is behind the glove box.
Old 01-27-2014, 06:13 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
If it is in fact a bad FSU you can disconnect the negative battery terminal, it's much easier to get to.
If its a bad HVAC control panel there are 2 fuses that supply power to it. This panel sends a control voltage to the FSU to tell the blower motor how fast to spin. With the fuses out there will be no control power going to the FSU.
Disconnecting the battery would probably be the quickest and easiest.
Old 01-28-2014, 07:45 PM
It seems you guys are right, so that's what I've been doing. FSU should hopefully come in next week or Friday.
Thanks for the advice!
Old 01-29-2014, 06:42 AM
- How to troubleshoot a bad FSU final stage unit (1) and how to build a test jig for your FSR final stage resistor (1) & how to autopsy or repair solder cracks in your blower motor resistor (1) & how to replace your HVAC blower resistor (1) (E46) & what FSU is the right one to buy (1)
