Old 01-27-2014, 05:14 AM
Neils528iM5's Avatar
Neils528iM5 Neils528iM5 is offline
Send a message via AIM to Neils528iM5
Mein Auto: 2001 BMW 530i M-Sport
Another Wiper Post... seems different.
On my 2001 530i, I used the wipers when it snowed and on the intermittent mode it's working continuously and then stops anywhere in the windshield. Also the washer spray stops working when this is happening. If you shut off the car and restart the wipes come on automatically because they had previously stopped in the middle somewhere and does the same thing again. Occasionally the wipers and spray go back to working normal.
Relay, Fuse?
Sold - 01/05/2010.....
Old 01-27-2014, 03:53 PM
JaxPlanet JaxPlanet is offline
Mein Auto: 2000 528iAT
My 2000 540's wipers started stopping right before the correct, "parked" position at the bottom of the windshield. This got worse until they were stopping in the middle of the windshield. Replacing the wiper relay fixed the problem. Something about moving parts and metal corrosion...blah, blah, blah.
Sorry to say I used a write-up from another forum to get me through this, search the net for > e39 wiper relay < It will be one of your first hits.
My notes on the job:
The housing bolts go into metal threaded inserts in the housing. Be careful not to tear the inserts out. If a bolt is stubborn, PB blast it and let it is sit a while. Be very careful not to drop anything in or around the relay housing. You definitely do not want to have to remove the housing to dig out a part or replace it. If the bolts are friendly and you don't drop anything, the job should take less than 15 minutes.
I hope this helps.
Old 01-28-2014, 05:11 AM
Thx.
Thx.. I'm going to head towards the relay first. But like i said, the thing that's odd about mine is that it stops anywhere on the windshield and sometimes goes back to working normal. Plus when this happens the washers stop working as well and also goes back to normal.
