DIY Coding your BMW...so simple it is available to all! - Page 11 - Bimmerfest - BMW Forums
Old 01-04-2014, 08:22 AM
HerbP HerbP is online now
Originally Posted by saquibmiah View Post
i did not take the bumper off. the pdc is working on the front i can see the on the i drive display just no sound coming from it. the radar screen on idrive works just no sound this is only t6he front pdc btw.
many thanks
There is a setting in the IDrive that turns the beeping off, or you possibly changed the coding on the updated system? The beeping should be for both front & rear in the IDrive, so a coding issue might be disabling the front PDC system.
Old 01-04-2014, 10:53 AM
rebel.ranter rebel.ranter is offline
Mein Auto: M6, 630i, 320iC
I have added 609 to CAS and NFRM I defaulted the cappl module
Can I ask if I do all that will my CD player start working again thanks also I read somewhere that u mean need to default kombi module
Any help your may provide me with will be of great help
Many thanks in advance
Apologies, I forgot you had an e92, NFRM instead of LMA. You still need to default code the other 4: CGATE, CHOST, CTUNE, CAUD. I would say your PDC no sound issue is related to the fact that these have not been coded.
Old 01-04-2014, 04:43 PM
saquibmiah saquibmiah is offline
Mein Auto: bmw 325 convertible e36
do you think once i default those 4 modules the cd player will reorganize my cds aswell
just like to thank you for helping me out. i will try this on sunday and will let you know the outcome.
thanks again
Old 01-04-2014, 05:17 PM
thanks again
Yep, all sorts of strange things can happen if a unit is installed & not coded properly. I retrofitted $609 to my e63 & prior to,coding the thing was in Polish not English!
Old 01-05-2014, 03:41 PM
RooK77 RooK77 is offline
Mein Auto: 645i
I registered a new OEM battery using ToolSet 32. I run the "steuern_batterietausch_registrieren" job for my "N62_tue".
Clicked "wun job just once" and almost instantly i got an "okay" message (see picture). Is this normal? I expected some delay in the process.
Old 01-05-2014, 05:04 PM
Most people use INPA or DIS. It usually takes around 2 minutes best I remember? Here is a DIS pdf to take a look.
Old 01-06-2014, 03:36 AM
Mein Auto: 645i
I will try it thank you.
Old 01-06-2014, 05:46 AM
would just like to shout out a big thanks to yourself you are a star. your advise worked great.
thanks again.
do you happen to know anything about cic retrofit. i was doing my friends one last night we defaulted the cic but know no dvd accept it says unknown region. is there something i need to change in the cic module to play dvd again. i spent nearly 4 hours before i gave up. any advise you give me will be of great help.
thanks again
saquib
Old 01-06-2014, 06:10 PM
just a quick update i,v been trig to change AREA_CODE_DVD setting with alle_anderen i,m tring to change it to area_code_2 but it come out with error coapi 1043 i am using daten 50.2. ANY IDEA ANYONE PLEASE HELP
Old 01-06-2014, 07:17 PM
My VO reads like this, this is for US.
DVD_AREA_CODE_1
Good Luck!
Old 01-07-2014, 06:54 AM
DVD_AREA_CODE_1
Good Luck!
thanks that did not work for me any more ideas do you think i should update my daten
Old 01-07-2014, 02:37 PM
What changes did you make to the VO?
Remove #303
Add #909
Add $6VA
Also did you buy an FSC code to activate the maps?
Old 01-07-2014, 03:05 PM
Remove #303
Add #909
Add $6VA
what i did was add #0909 $6VA fa write to cas/nfrm defaulted cic module and tried to change area_code_dvd from alle_anderen to area_code_2. but this did not work at all i can read it but can,t wright error coapi 1043 cic.c16 error. if i change anything esle on the module it changes fine. no one seem to know what the problem is. please help
what are #303 and #909?
many thanks in advance for helping me to try and solve this problem i am having.
p.s i used the emulator to activate the maps
Old 01-28-2014, 04:48 PM
Sup3rcool Sup3rcool is offline
Mein Auto:
Hello everyone,
My name is Steve I own a 2006 BMW 530 and I have a problem with my car that I just can't figure out. I'm hoping you can share some advice to help me out. Ok here is what I did, when I got my vehicle I was very upset to find out that my car did not have a aux input so I did a research and brought a aux cable, then I had a hard time trying to install it. BMW wanted to charge me $400 + to install and program my radio. So then I decided to change out my unit and I brought a whole different unit on eBay with an 8inch screen CD DVD combo with the aux software already installed, so now I was able to install it myself and not have to pay a lot $$$$ at BMW. Everything works perfectly fine except my idrive button. When I try to switch through the menu on the right I have to spin the button really really fast to get to the next option. It's weird ! Sometime I spin the button till my finger goes numb just to get to the option I want. I brought another I drive button and it does the same thing. Please tell me what can I do to fix this. Recently someone told me that I have to code the vehicle, so I brought the cable along with the softwares. Can anyone pls provide me with the steps on how to code the ccc or idrive button.
Old 01-28-2014, 08:07 PM
roseng's Avatar
roseng roseng is online now
Mein Auto: 2016 528i + 2007 650 Vert
Originally Posted by Sup3rcool View Post
Hello everyone,
This is a coding issue and it's a bit tricky.
The new unit is looking for the newer style iDrive controller. They are electrically compatible but different coding. You could buy a newer iDrive controller, and it will work but it is a different size than the one you have now and will not simply fit in the old hole.
You need to program the car computer (CIC) to the older style controller.
If you search for old idrive controller coding you may find it. I'll see if I can come up with a link.
07' E64/Black....14' F10/M-Sport White
Old 01-28-2014, 08:33 PM
Mein Auto:
Ok thank you
Old 01-28-2014, 09:24 PM
roseng's Avatar
Ok thank you
Have a look here
http://www.bmwcoding.com/showthread....ms-help-please
Old 02-02-2014, 06:25 PM
daf290 daf290 is offline
Mein Auto: 2007 650 I
Help for Struggling Near Newbie....
I got a dedicated laptop for programming for Christmas from my daughter and am haveing real difficulty getting it up and running.
I believe that I have successfully installed all of the software programs but cannot get the car to communicate with the program properly.
I had it working on my other laptop (company laptop) so I know that I have a good cable. When I plug in the cable from the car to the laptop, it instantly shows up on Com 1, but no luck communicating. I have attached a couple of screen shots. I have struggled with this on and off for a month and am quite frustrated. Any ideas?
Name:	error of BMW.PNG
ID:	420544   Click image for larger version
Old 02-06-2014, 01:26 PM
Please disregard my prior post, I got it.
Old 02-16-2014, 10:54 AM
75fusca 75fusca is offline
Mein Auto: 1975 VW 1303S Atlasweiss
WINDOWS CODING?
Hi Guys, I have a question on coding that I would like to have your advice on: Is it possible to have all 4 windows open at 25% simultaneously at the touch of a button?
If it is, I assume this cannot be one of the 4 wondows buttons. Could one of the memory buttons on the radio be programmed to that effect?
Thank you for any info you can provide me with. I like to drive in the summer with all windows in that position and but it takes time to do it ensuring they are all even.
Cheers,
Martin
Old 02-16-2014, 02:52 PM
roseng's Avatar
Originally Posted by 75fusca View Post
WINDOWS CODING?
Cheers,
Martin
Sorry, not from coding. Do you have a coupe or vert?
Old 02-16-2014, 07:00 PM
Thanks Rosend. I drive a 4 door 320i sedan.
Old 02-20-2014, 04:38 AM
tizre1 tizre1 is offline
Mein Auto:
Hi I've seen these USB cables on eBay for 25
So basically I could code my car up myself ? Good news !!
I'll follow your great guidelines and give it a go
Terry from Weybridge, Surrey. UK
Old 02-24-2014, 01:27 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & ST 335i
Any OBD2 cable will work. It's just a matter of finding the right software.....
Maybe some here can shed some light as to where some good software can be found at to do all of this.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 02-24-2014, 01:37 PM
Try bmcables.com or cable-shack.co.UK
