Old 02-03-2014, 05:07 PM
spydrz's Avatar
spydrz spydrz is offline
Sandlapper Chapter
Mein Auto: 2013 X1 xDrive35i
Finally lost the red turn signals.
Pet peeve of mine. I had the Blacklines on my E90 and tracked down the same for the X.
Nice.
ID:	420704   Click image for larger version
ID:	420705   Click image for larger version
1984 318i/man./Tornadorot*
1990 525i/man./Alpinweiß*
2001 525i/man./SP/PP/Cosmosschwarz/Sandbeige*
2002 X5 3.0i/man./SP/PP/Sirius/BT/Titansilber/Sandbeige*
2006 330i/man./SP/PP/CWP/Sirius/Blackline/Rear Fogs/Arktis/Grau*
2001 525i/step./SP/PP/CP/CWP/Xenons/Rear Shade/OEM Sirius/OEM BT/OEM AUX/M5 Rear Sway/Bilstein HDs/Beisan Vanos/Rear Fogs/Schiefergrün/Sandbeige*
2012 VW Golf R/Rising Blue*
2013 X1 xDrive35i Alpinweiß/Schwarz/M Sport/Premium/Tech/Dinan Stage 2
*retired
Old 02-04-2014, 09:37 AM
randl randl is offline
Mein Auto: X1 35i M-Sport
Can you show some more pics installed? Is this a new rear tail light cover that whites out the top corner? Please clarify, thanks for sharing.
Old 02-04-2014, 10:50 AM
spydrz's Avatar
Sandlapper Chapter
They're factory taillights, the entire unit. I'll take some when I can get outside to grab one.
*retired
Old 02-04-2014, 10:54 AM
spydrz's Avatar
Sandlapper Chapter
Best I can do from the office loading bay door. I'll get some more up once it's washed and shiny!
*retired
Old 02-14-2014, 01:36 PM
spydrz's Avatar
Sandlapper Chapter
Used the good weather today to finally get the tailgate lights in.
*retired
Old 02-14-2014, 03:44 PM
mickkassem mickkassem is offline
Mein Auto: BMW X1 - Volvo XC60
Taillights
Has anyone seen a replacement for the red lights on the tailgate that would continue the "white" reflector into the tailgate lights. Seems to me that it looks like there should have been the white reflector on this light.
Old 02-15-2014, 07:25 AM
spydrz's Avatar
Sandlapper Chapter
Maybe something aftermarket...
*retired
Old 02-15-2014, 09:33 AM
Pat_X5's Avatar
Pat_X5 Pat_X5 is offline
Mein Auto: '14 F10 +'16 LR Discovery
I love this set of blacklines just like I had on my Pre LCI E90...
Are amber turn signals available on these ??
I just love the Euro turn signals - combining both black line and amber turns.
Old 02-15-2014, 01:01 PM
spydrz's Avatar
Sandlapper Chapter
Yes they are the proper amber turn signals. And I also had them on my '06 330i!
*retired
Old 02-16-2014, 10:23 AM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
I share your disdain for red turn signals. For some reason, a lot of Americans prefer them. Multiple studies have shown the amber rear turn signals to be superior to red, in terms of recognition and safety.
Incidentally, my E90 LCI (2011 328i) wears the European tail lights, with amber turn signals. Our VW Passat also wears Euro tail lights with amber signals. I retrofitted both of those cars, due to my concern about visibility and safety.
Congratulations to your X1 for its new tail lights.
Alpinweiß
E46, E83, E90 (all with three pedals)
F25
BMW CCA member
Old 02-16-2014, 11:22 AM
ffchun ffchun is offline
Mein Auto: 2016 M-3
Turn Signal Lens
Nice.
These look great, is there a part number where I can get a pair ....
Old 02-16-2014, 11:23 AM
Mein Auto: 2016 M-3
Also, how much was each unit....
Old 02-17-2014, 11:56 AM
spydrz's Avatar
Sandlapper Chapter
I got the set from a German fleabay seller; price was "if you have to ask" level. Although for anyone who's replaced BMW lights, not too high, and free shipping from Berlin.
The set comes in one box with all four lamps. The part # doesn't seem to be available here, unlike the E90 Blacklines. However, it's 63 21 2 167 285.
Good luck!
*retired
Old 02-18-2014, 09:40 PM
Mein Auto: 2016 M-3
Okay, thanks for the time in sharing....
Old 02-19-2014, 01:54 PM
STE92VE's Avatar
STE92VE STE92VE is offline
STEVIL Empire
Mein Auto: 2007 E92 328i
I'm all for amber turn signals, but would rather have the red lens with an amber bulb: a la my 2002 Jetta. Is that something that's available?
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (RETIRED)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (RETIRED)
2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14
Old 02-19-2014, 04:58 PM
spydrz's Avatar
Sandlapper Chapter
^Not to my knowledge but someone with a ROW model will have to chime in.
*retired
Old 02-19-2014, 08:27 PM
The European tail lights for the E90 LCI are red, but flash yellow. I have them on my car.
http://www.ecstuning.com/BMW-E90-328...ghts/ES523220/
Here is an image of the European tail lights for the X1:
http://www.bmw.co.uk/en_GB/new-vehic...324e61cab67b77
Alpinweiß
F25
BMW CCA member
Old 02-20-2014, 11:02 AM
STE92VE's Avatar
STEVIL Empire
Did a little research on realoem.com and came up with the following part #'s for the Euro Taillights:
Rear light in the side panel, left: 63212990109
Rear light in the side panel, right: 63212990110
Longlife bulb 12V 21W: 63217160790
The USA part #'s are these:
Rear light in the side panel, left: 63212990111
Rear light in the side panel, right: 63212990112
Notice how the bulbs are the same which begs the question, is there an amber lens disguised as red in the Euro tails??
Old 02-28-2016, 10:17 AM
abs1nthe abs1nthe is offline
Mein Auto: BMW X1
Do you have some quick instructions on how to remove the fender rear tail light assembly? The plastic lens broke and I need to replace the entire assembly and thought i might also change the color of the turn signal. Thank you.
Old 02-29-2016, 01:17 PM
spydrz's Avatar
Sandlapper Chapter
I believe you just need to remove the inner access panel and then unbolt three or four nuts.
*retired
