E46 (1999 - 2006)
Old 11-09-2013, 04:46 PM
ahull's Avatar
ahull ahull is offline
Originally Posted by Gaza77 View Post
Ahull,
I don't know why, or if it should be worthy. I just started asking questions doing my research looking for answers to my no start problem.
I've had a lot of good help, however my issue seems to be stumping the group, including myself, so I get some help in areas, but nothing has been definitive in diagnosing and solving my problem.
I did start the tread or sticky. I apologize if I've disorganized or messed up the form some how.
Any and all help is greatly appreciated. I couldn't have come this far without all of your help.
Now, on to check the engine ground.
Cheers,
William
No worries, William. I think only admins can make sticky threads so my question was really for them. You're getting good help.... good chance you'll get it sorted here.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 11-09-2013, 06:41 PM
Mein Auto: '04 330Ci 6-speed
Update:
I checked all the grounds yesterday with except to the engine ground. I need to do that today because I need to get under the car and remove the protection plate.
For the future you can check the integrity of the engine ground strap from the top of the engine by measuring the resistance from the engine block anywhere to any bolt that makes good electrical contact with the chassis.
Naturally this reading should be close to zero ohms.
Old 11-11-2013, 06:53 PM
Lbert Lbert is offline
Mein Auto: 325i
I was able to access the starter from under car. As shown on attached picture, remove control arm bushing and swing it down to take out the starter. I used an extremely long 3/8 extension to reach the bolt. Perhaps later I will have the time to do a diy write up.
Old 11-24-2013, 01:18 AM
robinsonam1984 robinsonam1984 is offline
Mein Auto: 2001 BMW 330ci
Re: Starter Replacement DIY
Forgive me for i am just a poor girl who knows not very much about about cars. Im pretty sure my problem pertains to this thread. First off ive pretty much ruled out the bettery. On cold mornings i have a hard time getting her started. (2001 330ci) the engine turns over fine, not slow anything but wont start. Called my dad, he said to prime the fuel pump a few times before starting, and sure enough it starts up fine. She doesnt run rough at all, no check engine light, nothing. Now, on really cold mornings, below freezing, the same thing happens, except that after priming the fuel pump about 3 times, the engine starrs, sputters and dies. She will do that about three times before she starts and stays started. Then she purrs like a kitten. My dad thinks it could be moisture in the lines or fuel filter? He's unsure, and not a bimmer guy. I use top shelf, premium gas, and never let her go below a quarter tank. Only other thing is she's due for an oil change. Thanks for any feedback :o
Sent from my VS920 4G using BimmerApp mobile app
Old 11-24-2013, 03:28 AM
ahull's Avatar
Hey Robin, your problem is def not a starter. No big deal but to stay on topic, why dont you copy what you typed into a new thread and I and others will respond there?
Old 11-24-2013, 09:38 AM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
How many miles? With symptoms like that (and no other details) I'd start with a fuel filter and pump. If you have more than 100k miles, I'd chalk this up to E46 maintenance.
Also a possibility is leaking injectors, depressurizing the rail overnight. But those are more the exception and not the rule. I'd start with the filter and pump.
Old 11-24-2013, 10:31 AM
Theres almost 88k miles
Old 11-24-2013, 01:05 PM
Mein Auto: 325i
robinsonam1984,
Per your description of your no start issue it is weather related. What testing have you done that led you to eliminate the battery? Have you tried boosting or jump starting and the car will not start?
Old 11-24-2013, 04:52 PM
The battery was new in march, or so the guy at the dealerahip said, ive cleaned all the connections, as i had problems early on with the cables being corroded.
Old 11-24-2013, 09:13 PM
Mein Auto: 325i
I would not exclude the condition of the battery by what the dealership told you. You need to have the battery tested. At minimum, have a multimeter and get a voltage reading off the battery.
Another possibility is you may have a grounding issue with the cables.
Old 11-24-2013, 09:16 PM
The voltage was tested and is fine. I guess ill check out the grounding next. Thanks
Old 11-25-2013, 10:22 PM
Leaking injectors will have the strong smell of gas after it starts. And priming the pump three times would not be a cure for this defect.
Agree with the pump and filter.
Old 12-14-2013, 05:50 PM
Cold weather relay switch behind the glove box. Easy fix, cheapest bmw part ever
Old 02-03-2014, 07:51 PM
marvel0124 marvel0124 is offline
Mein Auto: 325 CI
Slow, intermittent or no starting
I had the same problem, changed out battery and starter same problem. Turns out there is a switch in the steering that was going bad. The switch connects to the key cylinder and allows voltage to run the starter. I took it off and replaced it, no issues after. BTW I took the switch apart and found corrosion on the contact points which leads me to believe were the cause of the intermittent starting problems. since i changed it out I have not had any problems, hope this helps.
Old 02-03-2014, 09:36 PM
Great reminder to mention that. Not uncommon.
Old 02-04-2014, 04:01 PM
Mein Auto: 325i
marvel0124, can you expand or perhaps do a step-by-step fix of the switch?
Old 02-04-2014, 10:11 PM
How do you know it's your switch?
Old 05-24-2014, 11:36 AM
biglouie69 biglouie69 is offline
Mein Auto: 2004 330xi
Must have tool for this job
I just finished a starter replacement on my wife's 2004 330xi. I did not lower the transmission. I removed the air intake components (both for engine and cabin) and took off the heater hoses. That gave me enough access to the bolts for the starter motor. The only reason that I had to remove the lower splash panels and the fuel filter cover was to fish the starter motor out of the bottom. I couldn't easily pull it out through the top. I probably spent more time getting the starter motor out of the engine bay than I did with the bolts holding it in place. But, the key is a gear wrench. Best with flexible head and at least 12" long. I bought this one in 8/10mm from my Snap-On dealer. Although it isn't a torx socket, the fit is good enough for the bolt to be removed without damage. Much better than dropping the transmission to access the bolt with a combination of extensions and universal swivels. Without this wrench, the job would be vastly more difficult. $60 well invested. It is not a Snap-On branded wrench. It is an EZRED NRM810 and about $30 online. I just couldn't wait for an online order.
http://www.amazon.com/Red-NRM810-Dou.../dp/B007QV5C0E
This is not as bad a job as some might make it seem. I probably whined about the location of the starter motor longer than it took me to replace it. _sl_
Name:	gear wrench.jpg
Last edited by biglouie69; 05-25-2014 at 11:01 AM. Reason: Correction to statement that I removed radiator hoses when they were the heater hoses at the firewall
Old 11-20-2014, 08:12 PM
az989 az989 is offline
Mein Auto: Is300
We just did this on a 325xi, we used about 3 ft of extension and a swivel socket and at E12 socket, took a while to measure up \.
Old 05-25-2015, 12:08 PM
Marys BMW Marys BMW is offline
Mein Auto: 325CI 2006
My grand daughter had the same problem with her Ford Taurus.She kept telling me her car was starting slowly and I couldn't find anything so ignored it. Then one day it died on her at work and I had to pay to have it towed home. A new starter fixed right up. The shaft on the old one was frozen so it must have been bad bearings. We bought our 2006 325Ci in January with 89000 miles on it and it turns over slower when starting than any other car I've owned so I'm wondering if I have the same problem.
Old 05-26-2015, 02:21 PM
catso's Avatar
catso catso is offline
catso
First thing you should do is check the battery and its terminals.
Don't be gormless; get some gorm!
![/I][/FONT]
Old 05-26-2015, 03:19 PM
No knowing for sure from here, but all signs point in the direction of getting a replacement.
But I'd check out your grounds front and rear before taking this big leap.
-*nga*-
