The X5 SAV Forum
Old 02-10-2014, 11:38 AM
cingersoll87 cingersoll87 is offline
Mein Auto: 2003 x5 3.0
p1353
I have a 03 x5 3.0 that keeps having a p1353 code. Misfire cylinder 6 with fuel cut off. I had a valve cover gasket leak so I replaced the gasket, plugs, coils, and camshaft position sensor (intake). The misfire is intermittent so I know the cylinder isn't dead. Can someone please give me some wisdom so I don't just keep throwing parts at it.
Old 02-10-2014, 04:13 PM
chatcher chatcher is offline
bmw addict
Mein Auto: e46 m3
If it is only ever one cylinder and you have already replaced the plug and coil I'd look for a plugged up/dirty injector.
current rides:
03 E46 M3
08 E70 4.8i X5
03 E85 2.5 Z4
05 E83 3.0 X5
03 350Z
12 Lincoln Navigator
03 rc51
08 F450 Dually
99 F350 Dually
RUNNING OUT OF GARAGE SPACE!!
Old 02-11-2014, 09:11 AM
I took it in to have it diagnosed and found out it has low compression in cylinder 6 FML. They said I need a new motor
Old 02-11-2014, 03:43 PM
bmw addict
Mein Auto: e46 m3
How many miles?. If it has low compression it should be a piston ring or valve seal each should be repairable get another opinion.
current rides:
03 E46 M3
08 E70 4.8i X5
03 E85 2.5 Z4
05 E83 3.0 X5
03 350Z
03 rc51
08 F450 Dually
99 F350 Dually
Old 02-11-2014, 04:21 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
low compression would be a piston ring in my opinion, fixable but you probally would want to rebuild the engine at that point.
2003 X5 3.0i
