Old 07-06-2013, 03:59 AM
Salmantheman Salmantheman is offline
Ms. AWesome ;)
Mein Auto: E66
Updates??????????
Old 07-06-2013, 04:26 AM
fsomuah fsomuah is offline
Mein Auto: bmw 745li
Nothing on my Idrive Works
Am still waiting for the seller to post the ASK UNIT he was talking abt the holidays and he needs to code it first and then post it....am still waiting for him
Old 07-13-2013, 10:03 AM
Wow my system is playing after installing the ASK UNIT....thanks for ur help....the only thing I need to do is to change the CDC
Old 07-13-2013, 10:45 AM
Ms. AWesome ;)
Mein Auto: E66
Why do you want to change your CDC ? and to what ? i just think CDC is just out dated and should be replaced with an OEM Ipod adapter...
have you got a facelift BMW?
-Hood Cable changed (thank you Keif),
-Idrive issue with Fm Module (thank you PAPER),
-Added Facelift ASK and MMI Dashsoft (Thank you ACE)
-Battery, Alternator, Compressor, Front Fan, Silly repainted, L7 Restored and the list goes on
Old 07-13-2013, 11:51 AM
Pls I don't know if u've experienced this before....there's a loud cracked sound coming from my right side speakers even if the music stop playing.....
Any advice on how to fix it please ....any little advice will help
Old 07-13-2013, 04:25 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Re: Nothing on my Idrive Works
Sounds like your L7 is going out ...
Old 07-14-2013, 07:35 AM
Mongooose Mongooose is offline
Mein Auto: 2006 750Li
Well the idrive display went dark in our 06 750li yesterday. We were driving back from a trip and had nav running, when we notice idrive display went out I still had nav running / updating in the tacometer gage. Radio still works fine and has sound coming out of all speakers, climate controls on dash appear to still be working fine as well. The display is black / blank and the Idrive control knob does not feel like its normal self.
I think it may have gone out while I was accelerating back onto the interstate after pulling to side, when I got almost to speed the last shift was a really hard shift, which the car had done a time or two at low gears prior to changing trans filter / fluid but has not done since (it was low on fluid).
I have checked fuses, none were blown. The lollipop in the glove boxes has a flashing light on one side. Also even after sitting overnight, radio comes on but no display.
Old 07-14-2013, 02:58 PM
I can't find my Bluetooth on my idrive ....it only shows pls connect ur phone but I can't find the Bluetooth on the idrive.
Old 07-14-2013, 09:06 PM
PAPER's Avatar
CRISP & CLEAN
your car does not have Bluetooth , Unless you have put in the BTUM
or upgraded your TCU .
Old 07-15-2013, 05:04 AM
How can I put in BTUM or upgrade the TCU..,,I would like to have the Bluetooth in my car.
Please advise
Old 02-10-2014, 10:06 PM
codyb20 codyb20 is offline
Mein Auto: BMW 750Li
Okay so I've had the exact same issues with my system. I've tried looping out the L7, SVS, and NAV on the Most loop. From my understanding there is about 11 devices all together so my question is WHERE ARE THE OTHERS LOCATED? Any info is appreciated guys
Old 02-12-2014, 03:17 AM
Ms. AWesome ;)
Mein Auto: E66
hi cody… the FM transmitor was my issue … i would suggest you to check the C pillar on the car .. and then go down the route of checking your ask unit, then your MMI
sorry i haven't been very active so please PM me if you have an issuer even after that
Old 02-15-2014, 12:02 PM
Thanks man. I'll be trying that out today
Old 05-27-2014, 02:46 PM
Wpalladino Wpalladino is offline
Mein Auto:
How do I take apart the loop for it to fit in the fiber optic modules in the trunk? It's to wide but I can see the 2 prongs inside it.
