Driver side Window - Bimmerfest - BMW Forums
Old 04-25-2013, 10:06 AM
jcharris jcharris is offline
Mein Auto: 2002 745I
Driver side Window
Good day to all, I have searched but no luck on finding a fix to myproblem. My driverside window will not come down, all the other windows work just fine. I stopped by my INDY and he wants to stiff me beacuse he has no competetion in this town, so he's just like the dealer when it comes to pricing. Ok, all the fuse are good to go and I pulled the door panel and everything looks fine, what other problems could this be, thanks?
2002 745I
Outrageous Daytona paint
Forgiato Rasoio
Drilled/Slotted aftermarket rotors
2006 Nissan Armada
Basic Silver
Gianna Wheels
JL Audio System/ Headrest monitors
Old 04-25-2013, 02:47 PM
KaileSvick KaileSvick is offline
Mein Auto: 2003 BMW 745Li
Not too sure, but possibly a bad switch
Old 04-25-2013, 08:25 PM
dvanlare dvanlare is offline
Mein Auto: '95 E31, '05 E66, '15 F02
My passenger side had same issue a few months ago. See if the courtesy light at the bottom of the door is dimming slightly when you activate the switch. In my case it was doing that so I suspected the motor was seized. I replaced just the motor (not the regulator) and it fixed the issue. I was able to replace the motor without completely removing the regulator which saved me a bunch of time. Part was about $150 IIRC.
Old 04-26-2013, 04:39 AM
Thanks for the input, i'm working on it today....
2002 745I
Forgiato Rasoio
2006 Nissan Armada
Basic Silver
Gianna Wheels
Old 05-05-2013, 08:26 AM
TakeItEasy TakeItEasy is offline
Mein Auto: E66 730Ld
Interesting, mine failed the other day, and noticed that the said light was dimming, so prepared myself for replacing the motor. However, after clearing errors in INPA and recharging the battery (which needed replacing), the following day, the window worked!
Old 02-15-2014, 11:04 AM
bmw750nupe bmw750nupe is offline
Mein Auto: 2007 750LI
Driver's window
Dvanlare was this hard to do? I just noticed today on my 2007 750LI the driver's window won't go down, and the light does dim when activating the switch. All other windows work from the driver control...even the express down works all but the driver's window.
Old 02-15-2014, 12:41 PM
The toughest part is removing all of the trim to gain access. Buy some plastic trim removal tools to make the job much easier and avoid damaging the trim. Many will replace the regulator and the motor together but I took a chance and just replaced the motor. I was able to loosen the screws to the regulator and gain enough access to the 3 screws that hold the motor and remove it without taking the regulator out. It saves a bit of time to not have to mess with disconnecting the window from the regulator and removing that.
Read through this thread as it has some documents from Keif documenting the removal process. Post 13 has the front regulator details. You don't have to release the door retainer and if you don't need to completely remove the regulator you don't need to remove the chrome window trim or mess with the window glass.
https://www.bimmerfest.com/forums/sh...d.php?t=447406
Old 01-26-2015, 04:31 PM
deemad deemad is offline
Mein Auto:
Questions.. Need to buy a driver side window regulator... Fresno, Ca.. Any suggestions???
Old 01-27-2015, 10:18 AM
1bad540's Avatar
1bad540 1bad540 is offline
try to re initialize the window, I think hold 10 sec up and 10 sec down. worth a shot.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 01-27-2015, 06:02 PM
OnlySkills's Avatar
OnlySkills OnlySkills is offline
Mein Auto: 745i
It's probably the regulator. They typically go bad on these cars. The part shouldn't be much, but labour is quite a bit if you don't do it yourself. GL!
__________________________________________________
BMW 745i - Titanium Silver - SOLD
'13 Ford Edge Limited Ecoboost - Platinum White, MFT Nav, 20" Chrome Premiums, Pano Roof
'13 Fusion Sport - Titanium Silver, Navi, 18" Colour-Matched Wheels, Paddle Shifters
Old 01-28-2015, 12:26 PM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
Re-Initialize Windows DIY here :
http://www.bimmerfest.com/forums/sho...d.php?t=394423
My BMW ACS7
