Old 02-15-2014, 10:15 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
DIY seat foam replacement
Have the seat apart, if you ever wondered what the drivers side massage worked, it's two bladders of fluid.
Old seat foam, pretty shot on the left side.
New seat foam, ready to install fans and sensors.
Old 02-15-2014, 10:32 AM
DMAX745i's Avatar
DMAX745i DMAX745i is offline
Mein Auto: 2013 750xi & 2002 745i
Always wondered what it looked like. Love the massagers
DMAX745i
MOPAULY's Avatar
Fans installed
Old 02-15-2014, 11:41 AM
vichugo vichugo is offline
Mein Auto: 2002 745i
I'm really impressed. Is it difficult to get the leather off the cushion so you can get at all this?
2002 745i toledo blue, shades, comfort seats, winter package, MTECv2 halos.
Old 02-15-2014, 11:46 AM
MOPAULY's Avatar
It's a little difficult, TIS will show you exactly what to do. The toughest part is removing the hog rings under the cover around the occupant mat, so that you don't damage it. other than that it's not so bad. I bought the seat foam about 3 years ago and am finally getting around to this, the foam was around $170 if I recall.
You do have to remove the seat from the car and it's quite heavy, something to keep in mind.
Old 02-15-2014, 12:28 PM
MOPAULY's Avatar
Cover refitted, ready for reassembly.
Old 02-15-2014, 01:02 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Did you use the same leather?
Old 02-15-2014, 01:03 PM
See-5 See-5 is offline
Mein Auto: E66 750li
I am looking forward to do this because my sport package seats are really harsh and not comfortable as Lexus LS460 at all.
Old 02-15-2014, 01:14 PM
MOPAULY's Avatar
All tidied up, looking smart, ready to go back in the car.
Old 02-15-2014, 01:18 PM
MOPAULY's Avatar
Better photo with the seams aligned. Yes, used the same leather, no need to replace it. Reused the occupant mat as well. A little bit of handiwork and some hogring pliers, and it's not to bad of a job.
Old 02-15-2014, 01:58 PM
MOPAULY's Avatar
Side bolster and cushion like new. Off to treat myself to some Drew estate cigars.
Old 02-15-2014, 03:40 PM
BimmerBrad7's Avatar
BimmerBrad7 BimmerBrad7 is offline
Mein Auto: 05 745 LI, 05 Acura RL
Looks like brand new nice job...been thinking about doing this as well
2005 BMW 745 LI Sapphire Black
22's, AC Schnitzer Kit, H&R Lowering Springs, Tinted tails and Signals, AC Schnitzer
Carbon Door Pillars, Cross Drilled and Slotted Rotors, Tuner Mod, Tinted Windshield,
30% Tint all the way around, and some other stuff I forgot.
Old 02-15-2014, 03:55 PM
DMAX745i's Avatar
I need a new back skin. Did u replace yours?? They look mint
DMAX745i
Old 02-15-2014, 04:03 PM
MOPAULY's Avatar
No covers replaced, just the lower foam. My car is very clean, the leather is in incredible shape.
Old 02-15-2014, 04:18 PM
DMAX745i's Avatar
My car is mint too, just from getting in/out ive burned through the leather in one little spot..
DMAX745i
Old 02-15-2014, 07:45 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
Very nice, you can have an upholstery shop replace sections of damaged leather or "redye" it to make it new again.
Drew Estate is very nice, I'm partial to the Acid Line over the Java's they have.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 02-15-2014, 09:26 PM
mws mws is offline
Mein Auto: 760Li, F250 V10, Ex 7.3L
nice! I've done this on a different car. in case anyone is wondering, hog-ring pliers and hog-rings are usually available at your hardware store. Hog rings come in various sizes, like pig, shoat, boar and such, like that. I have even found them in big city hardware stores.
also, for people asking about doing this, you should all look up leather car upholstery replacement on Youtube. there's hog rings, listing wires, springs. all sorts of stuff that is arcane to upholstery. its pretty simple, but hooking up upholstery is a discipline all to itself.
Old 02-16-2014, 05:44 AM
MOPAULY's Avatar
Acids are the best! hooked on the toast and earthiness.
for anyone curious, the new foam really makes a difference. I was looking forward to the new bolsters but didn't expect how much more comfy and firm the seat would be overall. A nice upgrade you can do in just a few hours in your garage.
Old 02-16-2014, 05:57 AM
DMAX745i's Avatar
:d:d:d
DMAX745i
Old 02-16-2014, 07:48 AM
mws mws is offline
you lost me with this comment...
oh, cigars.... for me, its home roasted coffee.
Old 02-01-2015, 09:57 AM
flash_n flash_n is offline
Mein Auto: 745Li
Thanks for your write up.
Just ordered up the foam, as my side bolster is toast.
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer, headlight vertical aim, VCGs
next up: P0492
Old 02-01-2015, 10:37 AM
1bad540's Avatar
1bad540 1bad540 is offline
Nice write up, any lights come on the dash from pulling the seats?
[SIGPIC]
e39 540i sport, acs type 2's,acs sper pdls,Euroclrs(sold)
e65 745i aw sport,21's aib's acspdls& rf splr(sold)
e46 328i Prem Aw18" 335spt whls(sold)
c5 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pana rf,nav,xenon,cldweather,20"4.6rims.(sold)
e65 750I aw, sport. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20"rennen forged,tune,exh,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
Old 02-03-2015, 07:57 PM
meangreen94z meangreen94z is offline
Mein Auto: 2004 BMW 745i sport
I did this as well, although I don't have climatized seats. The foam had split in several places and the bolster was collapsed. I replaced it before it ruined the leather.
Old 08-17-2015, 09:39 AM
MOPAULY's Avatar
no lights, no issues, worst part is how heavy the seat is to remove. Otherwise, like everything else on the car, assembly/disassembly is very straight forward.
