Old 02-15-2014, 12:00 PM
billydee1 billydee1 is offline
Mein Auto: 745Li
Was looking at my Nav system in the trunk of my car , does anyone recognize this wire
Old 02-15-2014, 01:56 PM
dvanlare dvanlare is offline
Mein Auto: '95 E31, '05 E66, '15 F02
Looks like Bluetooth antenna that connects to TCUM.
Old 02-15-2014, 02:13 PM
Mein Auto: 745Li
ok thanks but is it unhooked form anything important ?
Old 02-15-2014, 02:15 PM
Mein Auto: 745Li
ok thanks but is it unhooked form anything important that need to be reconnected
Old 02-15-2014, 02:49 PM
Do you have a Bluetooth TCUM? Are your phones pairing correctly?
Just a thought...If you don't have Bluetooth TCUM, that cable would indicate that someone installed at some point. The color indicates it is for the Bluetooth antenna. Did you just buy the car? Maybe previous owner installed upgraded TCUM but them removed the module before they sold it (and left the antenna wire)?
Old 02-15-2014, 03:25 PM
Mein Auto: 745Li
I found where the wire goes but there's already one plugged into the corresponding color code but the blue one is unplugged and there's no way it can connect with the black one in the way Click image for larger version
what does this mean ?
Old 02-15-2014, 07:08 PM
Mein Auto: 745Li
Can someone please help ?
Old 02-16-2014, 05:33 PM
Mein Auto: 745Li
Anyone please ?
Old 02-16-2014, 08:32 PM
mybmw408's Avatar
mybmw408 mybmw408 is offline
Mein Auto: BMW 750i
I will send you a pic of mine in 5 min
Old 02-16-2014, 08:36 PM
mybmw408's Avatar
Mein Auto: BMW 750i
Old 02-16-2014, 09:18 PM
mybmw408's,
Your car came with Bluetooth TCUM from the factory which isn't an exact match to what billydee1 has with his retrofit.
billydee1,
Your model year didn't initially have Bluetooth TCUM. It looks like you or previous owner has attempted to retrofit the car to Bluetooth TCUM. You never answered my question if the phones are pairing correctly. If they are then you are getting a strong enough signal with the antenna disconnected and you can leave it off. If you can't pair your phone then you need to get it connected. That 90 degree Fakra connector looks to be broken/tampered. Fakra connectors are keyed to ensure you don't put the connectors in the wrong place. You need to get the proper connector to allow the top one (black) to connect straight in (or allow it to rotate 90 degrees) and give room for the purple one to plug in below it.
Old 02-16-2014, 09:27 PM
mybmw408's Avatar
Mein Auto: BMW 750i
Yes, mine is factory
