Old 02-18-2014, 10:14 AM
KnudsonsM3 KnudsonsM3 is offline
Mein Auto: BMW: 525it, M3, 323i
DIY for Roof Rails?
Here's a great write up for individuals with roof bars already installed.
http://www.xoutpost.com/bmw-sav-foru...stall-diy.html
What I need to know is, has anyone without roof rails successfully installed roof rails?
Old 02-18-2014, 11:12 AM
ard ard is offline
Resident Curmudgeon
If you cannot figure it out from that post you have no business approaching the X5 with tools!
and BTW, there is a search button that would tell you people have installed rails.
Old 02-18-2014, 12:15 PM
If you READ the thread in it's entirety, you'd see that the OP in that thread said there was no way for people that didn't have these installed at the factory to do it. Hence the thread.
You should be a little easy on the assumption that I can't diy. I've personally done too many things on my e36 to mention and did a complete rear subframe fix on my e46.
Thanks for not helping.
Old 02-18-2014, 01:26 PM
http://realoem.com/bmw/showparts.do?...75&hg=51&fg=20
Looks to be around $622 in parts from ECS.
$562.80 from thebmwpartstore
Old 02-18-2014, 02:42 PM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
I am confused. Doesn't the DYI thread already have the answer to your question?
Hence ard's reply:
Old 02-18-2014, 02:59 PM
From all my searching he is the only one to say whether it could or couldn't be done. I am looking for someone else that may have put them in post factory.
Old 02-19-2014, 11:26 AM
bossboy302 bossboy302 is offline
Mein Auto: 2013 Ford F150
I've read the thread and looked at the photos.
Somebody correct me if I'm wrong, but the link appears to provide, in detail, instructions on how to install roof rails on an X5 that was not originally equipped with them.
The answer to the very question you asked.
Knudson, please re-read the linked thread.
I measured twice, cut three times, and it's still too short!
2012 X5 35d
2013 Ford F150
1967 911S
Old 02-19-2014, 01:54 PM
I highly doubt you looked at the pictures or read anything in the link. The creator of that thread had black rails from the factory and he wanted different ones.
If you look in his last pic you'll see the old roof rails.
Old 02-19-2014, 04:48 PM
No, actually I did read it.
I can't find that line by ADAMT, but I found this one:
No coding needed as nothing electrical is involved.
I doubt you would have to do any drilling at all. There are not that many cars that come with rails-delete option so it would make no sense for the factory to re-tool production line just to accommodate these select few. I think all trucks got holes pre-drilled and it is the rubber seal strip that is different.
My interpretation of this entry by the OP would suggest that the mounting holes are already in the car. If you peel the roof rubber insert up, you may find them. Then, you can follow his instructions and install your own rails. If you read them.
2012 X5 35d
2013 Ford F150
1967 911S
