Old 01-31-2014, 05:50 PM
wjhughes420384's Avatar
wjhughes420384 wjhughes420384 is offline
2009 F02
Mein Auto: 750li, XJ8
Air Suspension problems
my right rear Air Shock collapses when it gets real cold and the car looks like it has a flat and the battery is getting drained.
Has anyone else had problems with their air shocks?
2009 750Li - Space Grau Metallic, Camera pkg, Conv pkg, Driver Asst pkg, Lux Seat pkg, Lux rear seat pkg, Prem sound pkg, Sport pkg, HUD, Massaging rear seats, Smartphone integration, Sat radio, MTEC H8 4750K Halo lights
Old 01-31-2014, 10:56 PM
MCChuck's Avatar
MCChuck MCChuck is offline
Mein Auto: 2009 750Li
I had issue with my right rear shock. Car would always be about 1/2" lower on that side. It wasn't until I took photos after car was not driven for 2 weeks, showing a 3" drop, that the dealer took it seriously and wanted to tear down the suspension.
The issue can be the shock itself or the air lines supplying the shock or the auto leveler control module
This happened 2 months after the original warranty expired. It was finally decided that the shock was failing. And, guess what....CPO warranty does not cover the shock itself, only the controller and air lines. Since I presented the car on numerous occasions for this problem and along with a very heated conversation with my SA, it was goodwilled. ($1700 for shock and about 5 hours labor)
IIRC you have an extended warranty. They will most likely consider the shock a wear item. But you never know, maybe they will cover it for you.
Best of luck.
Old 02-01-2014, 11:02 AM
ImolaMMM's Avatar
ImolaMMM ImolaMMM is offline
Mein Auto: 2013 750 Li
My neighbor has the same problem with their Mercedes, I'm doubtful that it the exact same issue but the dead battery sounds familiar-
Airmatic sticking relay:
The relay which turns the airmatic suspension pump on may fail causing the pump to run continuously. This can result in failure of the pump motor or a dead battery as the pump motor will continue to run after the car is turned off. Also, Worn airmatic pump mount bushings can causes noises in the front axle while driving on bumpy roads or a buzzing noise while the pump is running.
Again, two different setups, but I hope this helps...
2013 750 Li Alpine White/Black|M-Sport Pkg|LED Lighting Pkg|Exec Pkg|Drivers Assist Pkg|760 Exhaust Tips|Painted Calipers|CQuartz Finest
2008 Toyota Sequoia Platinum--Arctic Frost Pearl/Red Rock
2006 750 Li-Retired
2006 330i-Retired
2002 M3-Retired
2000 323Ci-Retired
1991 M3-Retired
Old 02-01-2014, 02:12 PM
White94RX White94RX is offline
Mein Auto: E39 540
Best of luck.
By the way, CPO does cover the air springs. Its specifically stated in the CPO guidelines that mechanical springs aren't covered, but pneumatic springs are.
BMW Level 1 Master Certified
2001 BMW 540i
Old 02-01-2014, 05:44 PM
2009 F02
thanks guys, I was wondering about the air pump running the battery down. I will let you know what the dealer says Monday when I take it in.
Old 02-02-2014, 06:11 AM
MCChuck's Avatar
Yes, it does, if you've purchased a CPO car since 1/1/2014.
Old 02-02-2014, 08:01 AM
Mein Auto: E39 540
They were covered before that. They did release a new set of guidelines, but I've got the old guidelines too. They've always been covered far as I know
2001 BMW 540i
Old 02-15-2014, 09:26 AM
2009 F02
well this is one where an aftermarket warranty didn't work out too well for me, continental excludes shocks from it's list of covered parts. So this is on me. They had to order the strut, car going in Monday to replace it. The strut is over 2 grand itself, This is going to hurt.
Old 02-15-2014, 10:24 AM
MCChuck's Avatar
This is on getbmwparts.com. Maybe you should ask for some better pricing.
air spring W/AUTO LEVELING SYSTEM, 2009-12, 750Li, to 11/09 Right
MSRP/Core/Save/Online Price
$1,783.50/$0.00/$356.70/$1,426.80
Old 02-15-2014, 11:25 AM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
You won't beat this price. I exclusively use them for parts: thebmwpartsstore.com
If they don't want to match the price, then order yourself and pay them labor.
Old 02-15-2014, 11:54 AM
2009 F02
I should have asked you guys earlier, I already ordered the part from bmw, they just got it in
Old 02-15-2014, 12:09 PM
wjjklj's Avatar
Tell them to send it back or match the price. The quote I gave you is from The Bmw Store in Cincinnati, Ohio (a Bmw dealer). TheBmwpartsstore.com is their parts department. Can't hurt to ask.
Old 02-15-2014, 12:39 PM
ImolaMMM's Avatar
2006 750 Li-Retired
2006 330i-Retired
2002 M3-Retired
2000 323Ci-Retired
1991 M3-Retired
Old 02-15-2014, 10:10 PM
2009 F02
will let you know how I make out, I may just end up buying some points to cash in later, thanks for the ammo.
Old 02-19-2014, 08:01 PM
2009 F02
the dealer dropped the price of the strut to $1730 with my CCA discount, installation took it back over 2 grand, but now I am wondering if this strut problem could have been caused by the accident my wife had with the car. this is the wheel that got hit.
Old 02-20-2014, 01:55 AM
J750 J750 is offline
Mein Auto: 750Li
How badly was the wheel damaged? Have any pictures?
