Old 02-20-2014, 09:31 AM
SkiScubaSailDud's Avatar
SkiScubaSailDud SkiScubaSailDud is offline
Mein Auto: 2017 F26 X4 28i
Rattle repair
On my 2010 X5 35d I have a nice little rattle under the cargo area left vent shown here:
Has anyone seen this before? If so, what did you do to fix it? It appears to be under the vent, so if anyone can instruct me on how to remove the plastic cover or maybe the carpet panel adjacent to it so I can find what is rubbing.
Thanks in advance for any information.
Just my 2 cents worth...
Chuck
Old 02-20-2014, 09:53 AM
xx xx is offline
Mein Auto: E83 X3, F25 X3 and F15 X5
+1 on need instructions so that I can check mine too. I always thought mine is due to the cargo cover thing on the same left side.
(It rattles everywhere! The other day I placed some velcro in the "tool tray" area (under/around the screwdriver, oval tow hook and the L-shaped thing.)
E83 X3 | E70 X5 (sold) | F25 X3 | F15 X5
Old 02-20-2014, 11:58 AM
TinyRK's Avatar
TinyRK TinyRK is offline
Ja mei!
Mein Auto: X5
Read this:
http://www.xbimmers.com/forums/showthread.php?t=701368
Seems like the same issue and can help you figure it out.
BMWCCA Member# 481324
Old 02-21-2014, 11:19 AM
bigblack06's Avatar
bigblack06 bigblack06 is offline
Mein Auto: BMW X5
Lol I heard a noise 2 days ago and couldn't pin point where it was located just that was in the back, hope this helps.
BMW X5 2013 35i Premium Black Sapphire Black Nevada Leather Tech Package, Cold Weather Package, Convenience Package, Xenon Headlights, Automatic Highbeams, LED Fogs, LED Interior Lights
2014 Lexus GS 350 F-Sport:http://www.clublexus.com/forums/buil...or-spring.html
"Faster, faster, faster, until the thrill of speed overcomes the fear of death…" – Hunter Thompson
Old 02-24-2014, 12:37 PM
ahomata ahomata is offline
Mein Auto: X5 35D 2011
Originally Posted by TinyRK View Post
Read this:
Unbelievable, on the base of this I was able to eliminate the rattling in my car. The D latch of the tailgate really is loose, and for some reason it even looks like it's meant to be like that. The lower end of the latch moves just slightly, and by putting something (like two pieces of 1 mm thick plastic) in between the gap solved the problem. To really see inside how the latch is fastened, you would need to loosen all the covering plastics.
Old 02-24-2014, 02:01 PM
sirbikes sirbikes is offline
Mein Auto: 2011 X5 35d
Could be the plastic tabs on that piece - it's a single piece - that go into the metal frame. The tabs should be covered with felt tape. There are instructions online for how to do this. I'll try to find them.
My rattle actually turned out to be very close to your location which were the folding seat latches. They creaked until I put a bit of grease in the mechanism. Now it's totally silent.
Old 02-24-2014, 09:20 PM
JohnMN JohnMN is offline
Mein Auto: X5 35d, S4, V50 T5
Do you mean this?
http://www.justanswer.com/bmw/2drpe-...es-coming.html
Old 02-25-2014, 05:01 AM
Yes.
Old 02-25-2014, 01:33 PM
Singh97 Singh97 is offline
Mein Auto: 2011 BMW X5 35i
I will try this soon, tired of that annoying sound.
Old 02-25-2014, 04:37 PM
I still need to see the pictures to: "Remove the quarter glass vent trim (1) per Repair Instruction RA51 47 156"
SI B51 09 09
Chuck
Old 09-24-2014, 09:50 AM
Finally went to war with, and found this rattle. It was getting really annoying. I removed the D-Pillar cover, (just three snaps) and pulled the storage area cover. I then started feeling around to figure the next panel to remove. While doing this, I bumped a metal bracket that had some sort of control module (as it had a wired connection) attached to the bracket with a torx screw. And there was the noise, hallelujah.
A turn or so with a T-20 on the end of a socket to tighten that up, along with some preventative felt applied to the d-pillar cover, and voila, no more rattle!
My wife is so happy with me at the moment.
Chuck
