Old 02-16-2014, 02:45 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
F01/F02 Airfilter DIY
Mod Please place in DIY section.
1) Remove Engine cover. Simply pull up on it.
2) Loosen 8 T-25 screws around top of air filter housing.
3) Loosen clamp on hose going to air filter housing with a screw driver.
4) Lift off top of air filter housing. The top contains the air filter which is glued to a piece of hard black plastic pushed into the top housing. There is a spot at the corner to insert a flat screwdriver and pry it out.
5) After prying it out you will see a smaller charcoal filter which I don't think gets replaced as I could find no part number or mention of on realoem.
6) Put new filter in and reverse steps.
7) Filter part numbers are 13717577457 (Cylinders 1-4 Passenger Side) and 1377577458 (Cylinders 5-8 Drivers Side).
Cheapest place to purchase is the bmwpartsstore.com for $20.83 each.
Hope this helps. It's pretty easy once figuring it out.
ID:	423179Click image for larger version
ID:	423180Click image for larger version
ID:	423181Click image for larger version
ID:	423182Click image for larger version
ID:	423183Click image for larger version
ID:	423184Click image for larger version
Old 02-16-2014, 03:44 PM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
Charcoal filter should just be trashed. Only North American BMWs are equipped with them. Supposed to prevent some emissions during idle. Thanks for the pics.
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 02-16-2014, 04:08 PM
Snorlax's Avatar
Snorlax Snorlax is offline
Mein Auto: ///M7
Nice bro! Thanks!
Sent from your mom's iPhone
Old 02-16-2014, 04:48 PM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: F02 750Li
I would add one more thing.....reset the Engine Air Filter in the Service Menu. Totally optional though.
Old 02-16-2014, 04:55 PM
Snorlax's Avatar
Mein Auto: ///M7
Can u post instructions on this? Thanks.
Old 02-21-2014, 04:37 PM
hd750Li's Avatar
If you have the new BMW software called Rheingold which can be used for Diagnostic in F01/F02, you could reset hidden Service Menu items.
Old 02-22-2014, 12:13 AM
JacksonY JacksonY is offline
Mein Auto: 2014 BMW 740Li
and where do we get a copy of that?
Old 02-27-2014, 01:26 PM
wjjklj's Avatar
Where to buy Filters
Found these OEM replacements for $23.91 Each from www.rmeuropean.com. Free shipping if you spend $65. I bought the micro filters for 29.68 to get free shipping (part number 64119163329)
Part numbers are: 13717577457 (cylinders 1-4) Passenger side
13717577458 (cylinders 5-8) Driver's side
Old 03-05-2014, 08:49 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Attachment 423179Attachment 423180Attachment 423181Attachment 423182Attachment 423183Attachment 423184Attachment 423185
Wow.... All of that just to change these sh1ts out.
Guess I'll be ordering these tomorrow. Because I may as well have new ones on hand in case mine are dirty.
Thanks for the helpful info man!
Old 03-05-2014, 08:50 PM
TXSTYLE's Avatar
I too have read somewhere how these actually choke off additional power. So away they go when I do this swap.
Old 03-06-2014, 07:22 AM
wjjklj's Avatar
Yep I took the charcoal filters out. The tab holding them on actually broke off but it was flush so I'm not worried about it.
Old 03-06-2014, 04:52 PM
wjjklj's Avatar
The engine air filter and the cabin air filter does not come up in the condition based service menu on the F01/F02....at least not on the 2009. Anybody have this option on a newer model?
Old 05-27-2014, 02:11 PM
al7oot al7oot is offline
BiMMER4EVER
Mein Auto: 750Li F02
Spark plugs, micro filter and air filter doesn't come up in the F02. I too have a 2009 model but I also checked with the other model it's the same
Old 05-27-2014, 02:35 PM
knipper knipper is offline
Mein Auto: 750Li and M3
My 2009 just went in for rear brakes and the SA told me that it is calling for plugs with my next oil change interval. My microfilter was replaced per CBS data during my last visit. So the info is being stored somewhere since he read it off the key.
2015 750Li M-Sport - Imperial Blue / Ivory & Black
Old 12-19-2015, 09:04 AM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Thanks for this awesome post!
Does removing the charcoal filter reduce, increase or have no effect on fuel efficiency?
Adds power I suppose? Anyone notice any difference?
Thanks again!
Old 12-19-2015, 01:13 PM
hd750Li's Avatar
Thanks again!
You should feel like gaining 20+HP, less hesitation, and an increase of at least 1-4 MPG (depends on how you drive).
Old 12-19-2015, 02:45 PM
You've got to be kidding me, right!?
If not, holy ****ing ****!
What are the cons!?
Old 12-19-2015, 04:10 PM
hd750Li's Avatar
Cons? Perhaps air pollution...in this day and age, immorality!
No kidding! Removing that charcoal filter was always the first thing I did for every 750 that I owned. Only US cars have this filter. That's a concrete evidence that there should be no downside to the engine, only upside. More air, more power. This is the same principal for these combustion engines since the 60s.
Old 12-19-2015, 05:41 PM
Wow! Thanks!
Does this impact annual inspection?
Old 01-19-2016, 03:38 PM
adammcdowell adammcdowell is offline
Mein Auto:
I have the 2011 740LI, 6 cylinder, is there 1 fresh air filter?
Old 01-19-2016, 11:14 PM
paprmkr's Avatar
paprmkr paprmkr is offline
Mein Auto: 2010 BMW 750Li
no cheapest is $19.54 at bmwpartspros.com
Old 01-22-2016, 01:16 PM
DBLAZE's Avatar
DBLAZE DBLAZE is offline
Mein Auto: Alpine White F01 750i X
Just did this two weeks ago thanks to this DIY... It was pretty easy. Took about 15 mins or so...
BMW F01 Alpine White 750i xDrive; Oyster Interior
[BMS Stage 1 Tune | VRS Front Spoiler | AC Schnitzer Trunk & Roof Spoilers | AC Schnitzer Pedals/Footrest | 45% Tint]
BMW E63 Jet Black 645ci - Retired
BMW E46 Fern Green 323ci - Retired
Old 01-31-2016, 03:32 PM
Leftlane11 Leftlane11 is offline
Mein Auto: 2012 750Li
BMW dealer just quoted me $250 for this 3 days ago - how can they possibly get away with that price?
Thanks for the post - I'll gladly do it myself to save the money.
Old 01-31-2016, 10:21 PM
taylormade73's Avatar
taylormade73 taylormade73 is offline
Recovering Bimmer Addict
Mein Auto: 2012 750ix
I just did it last night thanks to this DIY...really easy but be careful of some of the wiring harness clips close to the filter housing...they are brittle! Does feel like it's changed the sound and performance slightly.
Old 02-01-2016, 06:08 PM
dvbimmerk dvbimmerk is offline
Mein Auto: 750Li M sport
I just did mine yesterday as well. When I removed them both sides of the housing were filled with sand and leaf particles. I vacuumed them out.
Also one of the rubber grommets that holds the housing in place was off apparently the dealer never put it back on during last service...so that's fixed as well.
2011 750Li X-Drive M Sport
Titanium Silver Metallic/Black Nappa/Ash Trim
Full LED Interior Lighting
LED Angel Eyes
RWS
