The radiator from HELL! - Bimmerfest - BMW Forums
Old 02-21-2014, 07:03 PM
alecela alecela is offline
Mein Auto: E70 X5 3.0si
The cooling system from HELL!
Hi all,
Here's my sober story:
Owned my 2008 X5 3.0Si for little over 3yrs now and with about 55k km driven and I'm just about to put in a new radiator for the FOURTH TIME!
Yes I'm having an indy doing the work but he always gives me back the replaced parts and the packaging so I can see that I've been using OEM parts.
So my question: is there something else causing the regular failure on the radiator? My family have owned various BMW's for decades so I'm a little shocked to see unreliability like this.
Any help/pointer appreciated. Tx.
Old 02-21-2014, 07:10 PM
serge1's Avatar
serge1 serge1 is offline
Mein Auto: 2011 BMW X5 35D
How exactly does the ratiator fail? Leak?
How often? What are the symptoms?
Old 02-21-2014, 08:34 PM
Yes they all started w/ leaks. I can't remember all the dates but fair to say the replacements lasted less than one year on average.
Old 02-21-2014, 09:19 PM
ard ard is offline
Resident Curmudgeon
Not sure about HK, but in the US the replaceent radiator has a 2 year warranty...your 2, 3 and 4th radiators would have been free!
Old 02-22-2014, 01:40 AM
Yes indeed the 2nd one & the coming ones are covered under warranty as the 1st one & 3rd one lasted only a few months!!!
So what gives?
Old 02-22-2014, 02:18 AM
CitizenOfDreams CitizenOfDreams is offline
Mein Auto: 1998 BMW 740i
Did they all leak in the same place? Maybe the radiator is stressed mechanically because of a bent mounting part or installation error?
Does the cooling system have excessive pressure? Too much coolant, head gasket leak?
Old 02-22-2014, 06:35 AM
tony(topaz,SMG)'s Avatar
tony(topaz,SMG) tony(topaz,SMG) is offline
Mein Auto: '11 335i,'88 M3, '15 X5,
I would replace the expansion tank cap at the same time. The cap is a sort of pressure release valve, so if it has failed, it might be allowing the pressure to get too high. As a practical not, I have always replaced the entire cooling system on my BMWs every 70K miles or so. That includes the radiator, expansion tank, water pump, and thermostat. It seems that all of those components tend to fail one after another, and you will have peace of mid for the next 70K miles.
Old 02-22-2014, 10:17 AM
ard ard is offline
Resident Curmudgeon
Maybe find a new Indy....
Old 02-22-2014, 11:24 AM
Rahulk Rahulk is offline
Mein Auto: E53 N62; E90 N52
Make sure he is using bmw fluid with distilled fluid... If you use water from a hose it will kill the radiator... Also make sure he doesn't use any air tools when fighting down the bolts, that will crack the radiator for sure! Before he returns the car to you make him do a 2 hour pressure test on the system... It should not leak at all... If it does.. Something's wrong... Clearly an installation error... Either installed wrong or something else not installed incorrectly is stressing it...
Old 02-24-2014, 08:10 AM
Well, the following parts related to radiator/cooling system has also been replaced:
coolant pump
coolant tank/reservoir
numerous radiator
hoses for radiator
As you can see, I do like to maintain my car in top condition but this radiator failures is definitely beyond my tolerances!!!
Old 02-24-2014, 09:58 PM
ard ard is offline
Resident Curmudgeon
coolant pump
numerous radiator
hoses for radiator
55k kms is 33k miles.
Replacing that many parts is NOT 'maintaining your car in top condition'..it is being screwed by your mechanic.
IMO
Old 09-24-2014, 09:45 AM
Well guess what? I replaced the radiator then (in Feb this year) and it started leaking again two days ago. Again, it lasted less than 1yr!!!! My mechanic actually asked me to take the car back to BMW dealer and see what the problem is. The real problem is that the bloody dealer here runs SUCH a great franchise here that they cannot take in the car for another week or so. So I'm turning to my fellow net wisdom here. Any clue?
Old 09-24-2014, 10:01 AM
henrycyao henrycyao is offline
Mein Auto: BMW X5 35d
Do you have a photo of previous leak? I assumed you examined the replaced unit.
2012 BMW X5 Vermilion Red Xdrive35d with Premium Package, 3rd Row Seats, and Adaptive Drive
Old 09-25-2014, 08:14 PM
I visually inspected the failed radiator but didn't notice much. My mechanic performed pressure test on them and noticed almost all of them were suffering leak toward the edge near the coolant intake pipe.
Old 09-25-2014, 08:25 PM
When you say expansion tank, are you referring to the tank/reservour that holds the coolant? If so, that has already been repalced once already...
Old 09-26-2014, 04:15 AM
Yes, the cap to the reservoir. Don't reuse the same cap. It might be allowing the pressure to get too high.
Old 09-26-2014, 09:49 AM
Ok, let me try it this time. Thanks again for the advice. Let's hope for better luck this time!
Old 09-28-2014, 08:55 PM
yeswecan yeswecan is offline
Mein Auto: Washington, dc
Well, I used to own 323i before I got the X5, the 323i got a radiator problem too, I keep changing the new radiator but the radiator will fail after around 5 months, turns out don't order cheap local parts or Ebay parts, they are cheap but made with hell, just pay and get a BMW radiator, it is expensive than local parts but trust me it will last for long
Old 12-07-2014, 07:06 PM
Let me re-iterate the problem:
For the last few years, I've been diligently checking the level of coolant/water in the morning BEFORE starting the car. On a few occasions, I've ran into situation that the water level is BELOW the minimum which manifested into various fixes that I've listed earlier. However, on most of the occasions, the floor are completely dry.
So the same problem happened again recently and I finally decided to try a new indy:
The diagnosis: Fan is not running at optimal condition (fan speed do not increase when the temp. is high!) hence the water temperature is running high. (I didnt' get the exact fault code nor managed to check the water temperature at that time!)
BUT the engine fan was REPLACED by BMW dealer back in March this year! Unfortunately I was travelling and didn't have access to my service history. Given that the car was down AND it was my daily driver, I let them replace it.
Sure enough a few weeks later, the problem returned. This time it's the radiator tank that's leaking!!! Sure enough the floor of my parking spot is still dry but I want to give the benefit of doubts to this new indy so I let them do it as well.
BUT on the morning AFTER I got the car back, I STILL had to top up 750ml of water to get the level to be above minimum!!! WTF!!!
I was furious and send the car straight back to the mechanics and demanded the exact fault code:
2E83: Electric coolant pump working at reduced power... (again my translation!)
So I was told that I need to replace the coolant pump which was ALREADY replaced 3 yrs & ~55,000 km ago!
What do you think guys? I got this new indy via a few personal recommendation w/ 1st hand experience. And I'm starting to run out of idea!!!
Old 02-25-2015, 06:41 PM
camaro camaro is offline
Mein Auto:
Old 03-08-2015, 08:50 AM
Mein Auto:
I had the same problem radiator leak on my 2008 x5 3.0si and My warranty expired.
You know what I did
I put CSF Aluminum aftermarket radiator two years ago still running good on problem and I did it myself and I'm NOT a professional mechanic. took me almost a whole day to do it myself
