Old 02-22-2014, 12:04 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is offline
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Lightbulb Just Changed out My In Cabin Micro Filters...
... What a PITA!!!
I mean do they have midgets finalizing the fitments of interior parts? You have to be a contortionist to fit all up under the dash and unscrew these tiny ass bolts (too many).
I mean if I had the body of my 8yr old son, I could easily have knocked it out in @ 30min instead I spent over an hour and a half jacking with it making sure everything was snug as a bug in a rug!
Here is the instructions I used for reference: http://blog.bavauto.com/wp-content/u...icrofilter.pdf
And yes... You will have to unbolt and lower the airbag. But I did not unplug it. Got the refills off of Amazon for $30: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Yes, I'm out of free maintenance. These were supposed to have been changed out when I took delivery and maybe they were, but I was surprised at how much debris was on them. Plus I have mad crazy allergies so whatever the recommended BMW time frame is, probably ain't soon enough for me.
Old 02-22-2014, 03:12 PM
bruno787 bruno787 is offline
Mein Auto: 740Li (F02)
there is no knee airbag on the passenger side, the one you lowered is just the plastic cover which houses the footwell lamp, and the connector was for the footwell bulb
15 Maserati Quattroporte GTS
10 740Li (gone)
11 Mini John Cooper Works
12 Range Rover Evoque Dynamic Si4
Old 02-22-2014, 04:30 PM
TXSTYLE's Avatar
Uhhm I don't think so. I need to verify that...
Bimmer App on HTC-One
Old 02-22-2014, 04:44 PM
SLS-BMW's Avatar
SLS-BMW SLS-BMW is offline
Mein Auto: F01 750i
My 2011 F01 has them on both sides.
Page 88
http://www.bmwusa.com/Standard/Conte...modelcode=1174
Old 02-22-2014, 06:05 PM
TXSTYLE's Avatar
Thumbs up
Page 88
Yep. Don't even know why I second guessed myself. Hell, I pulled the unit down myself and examined it. After a quick search:
The standard features of the BMW 750 i (F0) include 4.4L V-8 445hp engine twin turbo, 8-speed automatic transmission with overdrive, 4-wheel anti-lock brakes (ABS), integrated navigation system, side seat mounted airbags, curtain 1st and 2nd row overhead airbags, driver and passenger knee airbag, airbag occupancy sensor, automatic air conditioning, 19" aluminum wheels, cruise control, and an ABS and driveline traction control.
*edit* this is for the 2014 above but ALL F0 platform 7 Series come standard with Drivers and Passenger knee airbags and side curtain.
Old 02-23-2014, 04:49 AM
oh???? mine does not seem to have a passenger side knee airbag I have a Euro Version though....gonna double check but seems present with realoem.
i have cleaned my a/c filters 2x-3x over the past 4 years and i never remember removing an airbag module. it seems you removed the panel with 2 torx screws in Step 6 which you shouldnt, just pull the bottom black panel which houses the footwell lamps. You made an extra step with the airbag that wasnt needed.
10 740Li (gone)
Old 02-23-2014, 05:54 AM
kimg9582's Avatar
kimg9582 kimg9582 is offline
Mein Auto: 2011 740i
It's interesting that the instructions estimate the labor time to be only 15 minutes!
2011 740i
Old 02-23-2014, 06:49 AM
yes, i can do it in 15mins. OP may have taken an additional step which isnt required
10 740Li (gone)
Old 02-23-2014, 12:18 PM
TXSTYLE's Avatar
It could be optional on European models. Did not see any way to not remove the knee airbag. Oh well... It's done and I immediately noticed the fresh air. So for me, job well done!
Old 02-26-2014, 07:14 PM
djdelite djdelite is offline
Mein Auto: 745Li 2005
nice work an I love the rims on your car ....
Old 02-26-2014, 10:02 PM
TXSTYLE's Avatar
Thanks!
Vossen CV4 22".
Old 03-05-2014, 06:20 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
Just replaced mine as well. Have 23k on my 2009 750i and they were pretty dirty. The instructions included with my filters say to change every year or 10,000 miles.
These were a pain to change and I found the engine air filters easier to change. Both filters were way over complicated in my opinion.Click image for larger version
ID:	426505Click image for larger version
Old 03-05-2014, 07:07 PM
TXSTYLE's Avatar
^^ THANK YOU! That is EXACTLY what I was saying my friend.
PITA is putting it mildly. I mean being a 6 footer trying to torque my entire head and arms way the F under there to loosen too many tiny ass bolts sucks!
By the way... Casually glancing under hood, how in the heck do you change the Air Filters? Do I even want to know? The e65 were a snap and could be done in 5min! It's apparent I won't be having that luck here.
Old 03-05-2014, 07:09 PM
TXSTYLE's Avatar
How often does BMW change under the Maintenance Plan?
Old 03-05-2014, 07:58 PM
wjjklj's Avatar
See my post titled F01/F02 Air Filter DIY. I found the air filters easier than the cabin filters but neither is as easy as it should be. My air filters were so brittle that they crumbed. Way over engineered....there is a big black plastic surround that the filter is moulded to. Not sure what the BMW recommended maintenance is but all my filters needed changing. I installed the cabin filters with the flow arrows pointing toward the rear of the car although I'm not sure which direction is correct. My post has some pictures but if you did the cabin filter replacement, you can do the engine air filters. I paid about $23 each from RMEuropean. There is a left and right part number.
Old 10-29-2015, 05:37 PM
daders's Avatar
daders daders is offline
There is no spoon
Mein Auto: 2010 F07 550i, 2009 B8 A4
Bringing back up from the dead...trying to do this but the airbag seems to be attached from something in the center and I'm concerned about yanking on it. Is there a trick? Was yours free to drop when all the torx screws were undone? Any tips appreciated.
Never mind, just figured it out! Lift up to release from the tabs it is hanging on...getting it back will be challenging, all in the technique it appears.
There's no need to panic until it is time to panic.
Old 10-29-2015, 07:05 PM
paprmkr's Avatar
paprmkr paprmkr is offline
Mein Auto: 2010 BMW 750Li
mine has airbag. i saw it just before i disconnected it. yes it was a pain in the you know what.
what made it worse is the next day i took car for service and they said they were to replace my cabin filters part of maintenance. crap i should of waited. but my air had a musky odor. the old ones had lots of mud like and dust in them. smell went away. but i bought at dealer so paid $85
could of been free if i waited 24 hrs. oh well
Old 10-29-2015, 09:47 PM
TXSTYLE's Avatar
Just now seeing your post. Glad it worked out for you! How would you rate the "challenge level"?
Old 10-30-2015, 06:14 AM
texgeekboy's Avatar
texgeekboy texgeekboy is offline
Mein Auto: '14 750i, '15 535i
I didn't see an answer to this. I have this question as well. I'm sure I could do it, but with my skill set it would probably end up being an afternoon job and I'd lose my religion once or twice.
Old 10-30-2015, 06:19 AM
Fikus Fikus is offline
Mein Auto: BMW 750I
my advisor told me each 5 years,i used this
Old 10-30-2015, 10:45 AM
daders's Avatar
There is no spoon
Thus far it's been a total PITA. It seems our trim piece may be different as the knee airbag must be disconnected since the footwell trim piece runs from the front of the glove box to the carpet and actually is the support piece for the airbag via tabs on the front. I'll take some photos and post for comparison to your experience.
I was able to talk to the tech who does the work on our car (super nice fellow) and learned that as long as the ignition is not on and you let the car rest for a few minutes to achieve the "sleep" mode (as he called it - he specifically said a minute or two) you don't have to disconnect the battery to remove the airbag.
Old 10-30-2015, 10:53 AM
TXSTYLE's Avatar
I feel your pain. That sucks you have to disconnect it to. I remember this task like it was yesterday due to the toll it took on my back trying to get into position.
Old 10-30-2015, 12:20 PM
daders's Avatar
There is no spoon
I'm really surprised this piece wouldn't be the same due to the whole lean engineering push, particularly since the GT is based on the F01 wheelbase. Anywho, the footwell trim was attached via three clips directly below the glove box (green/blue arrows) and the air bag was supported via the tabs (red arrows) and there was no way to pull the footwell trim down to expose the cabin air filter housing without disconnecting the airbag.
And then that back left screw on the air filter housing is so close to the floor I almost lost it () because my screwdriver was too long...fortunately I found a second toolbox with a shorter handle for my torx screw.
I can see it taking only 15 min if you do these frequently and don't care if plastic gets bent or broken...but a first timer on their beloved BMW will definitely have an hour's worth of angst.
Old 02-06-2016, 09:47 AM
Leftlane11 Leftlane11 is offline
Mein Auto: 2012 750Li
I just did the engine air filters and the cabin air filter today thanks to these DIY posts.
It took me about 30 minutes for the engine air filters and about the same for the cabin filter. I bought everything online at www.oembimmerparts.com.
Wasn't too hard, and I'm not mechanically inclined. A few things to help:
For the engine air filters, the only thing I was unsure of was how to disconnect the wiring harness going into the cover, so I just left it attached. I also popped out the charcoal filters in the lid and did not replace them.
For the cabin filter, I lowered the knee air bag panel but left everything connected. To give me a little more room, I pulled it as far as I could toward the open passenger door and duct taped it against the upper console - at least it was out of my way. It also makes it easier if you move the seat as far a back as possible. I'm not a big guy and I still had to contort myself to get under there to see what the hell I was doing.
The filter housing has 4 screws and only one of them is somewhat hidden on the left side towards the driver. Once I got the cover off the two filters slid out and the two new ones went in - arrows for air flow pointing towards the rear of the car.
The only small issue I had was putting the screw back in for the carpeted trim piece against the center tunnel - it took a while to get it lined up and it still looks a bit off to me - maybe I didn't get a clip pushed in or something.
The dealer wanted $250 for the engine air filters and who knows what for the cabin filters. I spent $85 total for the parts and it took me an hour - worth it to me.
Kudos to the guys posting the DIYs!
