E34 (1989 - 1995)
Old 12-21-2013, 09:38 AM
rayf rayf is offline
Mein Auto: 1991 525 i BMW
Originally Posted by gussee View Post
hi i have a 1989 525i bmw the power lock,the windows,the sunroof,the seats and the radio stop working all together i checked the fuses but there fine can anyone help me out please
just fixed that prbliem on my 1991 525 i rt next to the battery there is a fusiable link open cover and check
Old 02-24-2014, 07:56 AM
Irishboy916 Irishboy916 is offline
Mein Auto:
Hi family I'm new to the BMW world only had my gorgeous 1995 525i for a few months!! I love my car only problem I see so far is the quickness from starting line,top end perfect what's the best way to add the zip I'm looking for!!
Old 03-05-2014, 12:32 AM
skyka skyka is offline
Mein Auto: 525i
brand new to BMW (ive owned vw/audi mostly) and I have numerous electrical issues (which im used to) that being said. its a manual and the fluid is BLACK and what ive read is to not change the fluid cause it destroys the trans. Im not sure if that true or not. the car has 270k on it and other than minor electrical issues like windows and a head light out it seems to be running strong. any advice to keep this running for another 100K? I feel like I got a good deal for 1200 and have hook ups on parts and what not, pretty much, whats are the defects mechanically and what should be the main thing to look for with engine issue?
Old 03-12-2014, 09:54 AM
lilpoultney lilpoultney is offline
Mein Auto: 525i
I'm also curious, any one with a list of do's and don't's with the e34?
Sent from my Huawei-U8665 using BimmerApp mobile app
Old 03-12-2014, 11:25 AM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
That depends on you sir, what ever you feel you want to do to your E34 feel free, we may not like it, but in the end it is your car. Every now and then we can give hints of things to buy, from where, and when to do certain things to prevent major disasters.
This all depends on the depth of your wallet as well when deciding what to do to your ride.
We have E34's from bone stock, BMR_LVR, to drag car in the making, imae34driver. And everything in between.
And they all have a personality and most all look good they way they are, or once the intention is explained even the more, ugly cars look good.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 08-22-2014, 10:45 PM
Charlygirl Charlygirl is offline
Mein Auto: 1989 bmw 535i
Originally Posted by robertobaggio20 View Post
Yes sir that will be included where appropriate. I was referring to the thread's topic in my earlier reply. Most of what i intend to describe will be decidedly conventional which i would pretty much now do with any used car that i buy, regardless of make and manufacturer. Of course a few things could be entirely specific to the E34 - i don't have that much experience with any other vehicle to say otherwise.
The post will serve as a useful reminder, will at least alert people to the demands of owning an older vehicle, and will be checklisted for easy reference. At least i hope it turns out that way. And with such an extensive buildup, I'm sure it will be a disappointment.
Would be greatly appreciated, just bought a 1989 535i ... tia
Charlygirl
Going through a full life cleanse: getting divorced, getting a new home, getting new cars after being t-boned
1988 Mercedes Benz 300 SE, W126, 185,000 km, Auto, i6
1989 BMW 535i, E34, ~375,000 km, Auto, M30, 3.5L
Old 01-05-2015, 04:17 AM
nnormmore nnormmore is offline
Mein Auto: bmw
pin out
Could you please supply me with pin out of connector next to the diagnostic plug the one that comes from computer I have put a M50 motor from a19 92 E34 525 in to a 1988 E34 525 and need wiring diagram what wires to wire onto 20 pin connector from 25 pin connector have swapped computer I have both cars complete if you could help I would appreciate it greatly thankyou Norm
Old 01-15-2015, 09:08 AM
talito21 talito21 is offline
Mein Auto:
Stomp test not working
Old 01-15-2015, 12:45 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
1. turn the key to start position (do not start car)
2. press the gas pedal to the floor and release 5 times
3. the check engine light should go out then begin to flash. The sequence of flashes is the code.( ie: 1 flash, pause, 2 flashes, pause, 2 flashes, pause, 2 flashes = 1222)
4. once you get the code repeat step 2 to retrieve the next code.
5. continue to repeat step 2 until 1444 or 1000 flashes. 1444 and 1000 means no codes or all codes clear
_______________________________________
Content Writer - FCPEURO
95 e34 525 5 spd S52 Swap...Sold
01 e38 740i msport (under restoration )
Old 01-15-2015, 02:58 PM
MeNoo's Avatar
MeNoo MeNoo is offline
Smuggled into the 'Fest
Mein Auto: 1990 BMW E34 525i
Some years don't have stomp test, right?
HELGA-90' 525i
Unnamed-98' 328i
Old 01-15-2015, 03:52 PM
TheEinstein's Avatar
TheEinstein TheEinstein is offline
Mein Auto: E34 540i
Just thought I'd add, my 95 540 does not respond to full release of the pedal. It responds to pressing and releasing the kick-down switch. IOW, pedal to floor up an inch, down, up, etc.... for the five times. Just wanted to put that out there too.
1995 E34 540ia
160,000 Miles
VIN# ...GF32404
Hellrot Red
Fuelly
My Basic Repair History (Edited 1/27/2015)
Ongoing comparison between two E34 540ia's
OBC4 Hidden Functions : Link
Old 01-15-2015, 06:47 PM
Nothin like an E34
Early 90 and earlier do not have a bulb, but one can be added and the test performed.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 01-15-2015, 06:56 PM
MeNoo's Avatar
Thanks.
HELGA-90' 525i
Unnamed-98' 328i
Old 01-27-2015, 11:46 PM
e34hartge e34hartge is offline
Mein Auto: 1991 535i hartge mod
nice
Old 01-29-2015, 06:27 PM
Update on the stomp test. Probably been stated already. Actually I forgot about it. The stomp test is US market specific.
Most e34s overseas can not do it.
This conversation was held recently on my latest blog article.
It was something I learned years ago but have neglected to remember since it never pertained to me.
That said if you do have a e34 or any OBDI car marketed outside the US.
If you can perform the stomp test, please post up your model, build date and geographical location.
If possible also include the origin to which your car rolled out the factory.
I want to try and log all the cars across the pond which are able to do it. (e32, e39, e38, and e36s as well if you got one)
The guess is that it's less than 20% of the overseas market were able to do stomp tests.
Old 02-02-2015, 12:50 AM
MPauls MPauls is offline
Mein Auto: E30
Hi guys, Maybe someone could answer me - what are parameters for fuel pump on m60/m62 4.0/4.4 engines? aprox. liters per hour and pressure? Need to buy one that is simmilar to this one that is in line, not - in tank. Mby some suggestions on this one too? Now looking on Mercedes w140 5.0 or 6.0 engine fuel pumps..
Old 04-30-2015, 09:01 AM
yungismael yungismael is offline
Banned
Send a message via ICQ to yungismael
Mein Auto:
So I drove my 1994 530i v8 3.0 BMW fast cause I was in a rush to get to somewhere and was just going really fast on the freeway, then I noticed smoke coming out of my hood, but my car wasn't over heating, then I get off the freeway check out see a bunch of fluid what looked like oil, so I check my oil, but I got plenty of it, so then I thought I just busted a hoes, so I try to make it back home and my car just starts jerking like I got a bad transmission, my transmission never had a problem though until all this liquid and steam started coming out from under my hood, so I think it's transmission fluid but who knows, any help guys ? Should I get transmission fluid, and try to find where it's leaking from ?? Anyone know what hoes it's connected too or by ??
Old 04-30-2015, 09:08 AM
Mein Auto: E34 540i
Completely wrong place, start a new thread where we can interrogate properly. "Sticky" threads (the ones at the top) are for pertinent and consistent information storage and archive.
1995 E34 540ia
160,000 Miles
VIN# ...GF32404
Hellrot Red
Fuelly
Old 06-24-2015, 05:32 PM
lxmbrgboy lxmbrgboy is offline
Mein Auto:
My 95 e34 530i built overseas is able to do stomp test easily.
Old 06-24-2015, 05:36 PM
Mein Auto:
My e34did same thing. It turned out the diaphragm in the engine crank case vent valve ( or oil separator valve as called by some) let go and this causes the symptoms described.
Old 12-09-2015, 09:17 PM
89525i 89525i is offline
Mein Auto: '89 e34
Throttle lag?
I've got an '89 525i, and Im a first time Bmw buyer, so please, patience. When I step on the throttle, it will have a little firmness to it, but there is no change in rpms until you push about 1/2 way down, then it slowly builds, this happens when you are starting from a dead stop. When you are at high speeds, or in neutral, and you slam on the gas, there is about a half second delay before anything happens... any thoughts on what to do? Or what is causing it? Also, side note, there is a hissing sound comming from the rear end, not tires, and im not sure what it is, it doenst sound like and exhaust leak...
Old 02-15-2016, 08:51 PM
Colorado Corey Colorado Corey is offline
I Like Biscuits
Mein Auto: I own 4 cars
So Im a first time caller, long time listener. I have a question for the OP.
I have 93 525, I was thinking about lifting it about 24" and putting 13" wheels on it so it would look like I had hydraulics. I was wondering if you like the look or if you think it would be just not enough,........
Sorry I couldnt resist. I read 4 pages of,......Well lets just say, you are very patient.
Great write up, and thank you. Please mods, delete this is needed.
Old 04-27-2016, 12:20 PM
thumper600's Avatar
thumper600 thumper600 is offline
Mein Auto: '95 540i M-Sport, 01 M5
Thank you Corey
Old 07-15-2016, 11:37 PM
irishgems irishgems is offline
Mein Auto: BMW 1993 bmw 525iT
If you have the time to share your history with the BMW 525iT wagon.As for me this is my first time at the circus?The situation we are currently faced with is a 1993 BMW 525iT wagon. This car is doing all it's required to be started?I have taken every step in this cars best interest,and it may not fit the bill as pretty,but the car was an amazing find! As I mentioned the car was a Barn type find? It was an estate sell and the owner was an old maid,and as it may seem,"GREED" was this little cars of nightmare! I was knocked out when the owner started the car with a starter spray,or what was thought to be starter spray? This cat sprays a brake dust cleaner in to the intake and started the 525iT. I was so blown away that the person selling the car was told to stop the engine at once or I'll walk away,and never discuss this matter again!Please correct me,but these car's never need to be tricked into a by pass in order to start them???At present the car will not start,but it was the Mass Air Flow Sensor Meter.I located a clone car but it is a sedan.This is not a factor as the engine is the E34 in line six,and this Salvage yard started this car,and it ran great.Now how ever the car is not starting after the replacing the entire Mass Air Flow Sensor Meter. We have began the slow process of running down the problem.We have began with the fuel pump providing the car with 84 octane,next we have taken the injectors out very carefully,and tested each one of them with no problems,also the firing is no problem? If any one has had this problems please provide me and my family with a known fix,or a attempt at running down this cars problem and fix with the motive of a repair that remains repaired! In my short history I have seen BMW owners fall apart when the words,Huston We Have A Problem"! No one with any brain activity knows the car we speak of is not the sticker price but the cost of repairs that come with these cars!This is a known fact as long as I can think back,and I am a 58 year old male.And to every one of the "Team Bimmer Fest" thank you for a response and with provided info about the 525iT wagon and it's problem with the "Mass Air Flow Sensor Meter" according to the computer info provided from the 1993 BMW 525iT E34 Wagon.As mentioned,all signs point to a long time or short time BMW owners who in fact do provide the work and service on there own cars. I want to save this car, it is a solid car with great features and the first owner was a very dedicated woman with the BMW 525iT and it being serviced and checked on regular basis.The car is a victim of not caring at all!An estate?The result is as usual,the things a person loves most is give away for the hopes of getting to the "CASH" part of the person who died with no family direct?Her niece/nephew was the winners of her hard efforts of saving to be cast to the side for the cash???In return the 1993 BMW 525iT with 111,654 was thew odometer reading and remains.The car was started by the nephew with a start spray?I had a valuable lesson to be learned?Never assume the owner of a BMW would know that "Brake Dust Cleaner"for starter spray is insane!! Once I noticed the spray it was obvious that the results of this would melt down in the cat converter. The new golden rule,never let a owner use any out side motor killer combined with a shot of stupid will finish off a women who loved and worked like a dog to have a car of this status in every part of our world. This is a great car,and this lady,a Southern Lady would never believe some one " A.K.A. The Nephew" would give her BMW 525iT wagon away for $500.00!! As a former child of the 60's and 70's allowed us to grow in this cars direction,later to be fueled by the infusion of these great cars into our great country. I know that you will have to pay there lord if you are openly guilty of a act such as to sell this car for 5 hundo's?Stupid dumb or any other word that makes you fell better about you because the cat that give us that car is sick!I know it may seem harsh,but what another person devotes there life to doing it the right way,ends up with every thing she loved was given away?So please help with any suggestions and facts to give this car the chance it deserves.I will remain it's owner with my two son's attention on there future ride.Thank every one and may god bless.
Old 10-19-2016, 10:15 PM
Jameskeeny Jameskeeny is offline
Mein Auto: 1995 530i Bmw e34
Stomp test
I have a 1995 530i BMW e34 an i tried the stomp test a dozen times an it won't work. Any help?
