E34 (1989 - 1995)
Old 02-20-2014, 10:40 PM
commandervp6 commandervp6 is offline
Mein Auto: 90 BMW 525i
Lack of power
Recently bought 90 BMW 525i with 277,000 miles that appears to have been well taken care of. I must admit I never really jumped on it until recently. The best way I can describe the power is a lack of power, no miss though. On a stretch of freeway, I did from a standing stop floor the accelerator and noticed it shifted at 4500, not redline and took a while to reach cruising speed. Also, the idle is starting a searching or fluctuation of a couple hundred rpm's. From what I have read here there are many avenues to pursue and have gotten confused. My mechanic smells raw fuel, I have not. Shall I start with battery, alternator, 02 sensor, plugs, cap, rotor, AFM (no idea what that is), temp sensor; or is there a common issue with these? Seafoam first?
Old 02-21-2014, 07:21 AM
Dionte Dionte is offline
Drive her like an ///M
Mein Auto: 1992 BMW 535i (manual)
Has the check engine light been on at all?
1992 535i 5-Speed
1984 533i 5-Speed
Douglasville, Georgia
Old 02-21-2014, 07:30 AM
Thanks for your reply
The light has only come on for a second or so, did the stomp test, but no codes are stored.
Old 02-21-2014, 07:45 AM
Does it come on at a certain RPM?
1992 535i 5-Speed
1984 533i 5-Speed
Old 02-21-2014, 08:06 AM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
Change the fuel filter. My 1995 525i had a 1997 date coded fuel filter that shop air pressure could barely blow through. This should be done first, as it is a basic function that many systems depend on to run properly. While under there, check for a fuel leak from some of the hoses...
"Herr Doktor will see you now..."
Old 02-21-2014, 09:33 AM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
A note on the stomp test.
Even if no codes are stored you will get the light flashing in a sequence telling you exactly that, does it flash in the sequence?
Also many people have the misconception that the OBC will tell the code onscreen, that is not how it happens. The Check Engine Light itself flashes indicating a code.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 02-21-2014, 10:28 AM
Mein Auto: BMW 525i
OBC...
I had some fun today and programmed a code in my OBC and it disabled the start function...
Old 02-21-2014, 09:53 PM
Issue resolved please read! Loss/Lack of power
The issue was the hose was "ajar" going to the Mass Air Flow! Sometimes, it's the easy fixes that make up for the p.i.t.a.'s! Thanks everyone for your time spent and advice/comments.
Old 02-22-2014, 07:07 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Glad it was so simple. As you can see by my sig, I'm a firm believer in the KISS principle
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-24-2014, 09:32 AM
Mein Auto: BMW 525i
My 525i is super quick...the 4.10 gear is great. Too bad they don't make a 4.30!!!
