Xenon headlight not dipping - Bimmerfest - BMW Forums
Old 02-22-2014, 05:52 PM
zimba zimba is offline
Mein Auto: BMW x3
My X3's near side xenon headlight does not always dip fully. If I hit a bump in the road it will jump to the dipped position. What is causing the mechanism to jam? Any answers please.
Zimba
Old 02-23-2014, 02:29 PM
bmwmsport11 bmwmsport11 is offline
BMW FTW!
Mein Auto: 2006 BMW 330XI
When you first start up the car the DRLs should adjust itself. Park close to a wall and do this when it's somewhat dark outside. Both should level themselvs, if one doesn't, then I'm guessing you may have a sensor problem.
Old 02-27-2014, 02:55 AM
Mein Auto: BMW x3
Headlights adjust automatically on startup, even if one is on full beam. It is just the nearside one that will not always dip.
Old 02-27-2014, 10:07 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
Investigate the positing sensors that attach to the suspension for damage.
Old 02-27-2014, 11:07 AM
Mein Auto: BMW x3
Smile
I think I have solved the problem. A guy on the Audi site had a similar situation with his xenon's. The lens which pivots between high and dipped beam was touching the glass in front. By pulling the light assembly back it seems to have freed the movement of the lens thus allowing the light to dip. Thanks for the online help.
