2008 X3 liftgate will not open - Bimmerfest - BMW Forums
Old 02-27-2014, 10:32 AM
Nicearthur32 Nicearthur32 is offline
Mein Auto: 2008 X3
Question 2008 X3 liftgate will not open
Hi all,
I did a search for this issue and could not find a problem similar to mine.
I have a 2008 X3 whose battery died and needed to be replaced. When the battery was replaced the terminals were put on the wrong ends and it blew some fuses. Took the car to the dealer and they took care of the issue, however, when I got the car back the rear liftgate would not open. The button on the door handle doesn't seem to do anything. I did notice that when I attempted to start the car with the wrong terminals in the rear wiper blade went off and was moving slowly.
I thought it was just a blown fuse that could be easily replaced but I can't find where the fuse for the liftgate is for the life of me.
I know it was a bone head move to put the cables on the wrong terminals... Hope it's not an expensive fix.
Help!
-Art
Old 02-27-2014, 11:00 AM
Mein Auto: 2004 X3 2.5i
Originally Posted by Nicearthur32 View Post
...... The button on the door handle doesn't seem to do anything.
You have tried using the key remote to unlock the hatch?
If that doesn't do anything either, you will have to crawl into the cargo area and find the emergency release lever - not easy.
See: http://www.bimmerfest.com/forums/sho...99&postcount=1
Old 02-27-2014, 11:08 AM
Mein Auto: 2008 X3
No, that doesn't work either....
I saw how to open it manually but how do I remedy the problem? I really hope it's just a fuse.
Thanks for your reply!
-Art
Old 02-27-2014, 02:51 PM
As it is an electro-mechanical latch that makes it hard to troubleshoot.
If all the other central locking functions are working, and the license plate lights work, I can't see it being a blown fuse protecting just that switch/latch.
If the license plate lights are out, do a search on "grip strip". See: http://www.bimmerfest.com/forums/sho...d.php?t=725740
But I would really expect your problem to be fixed just by manually releasing the latch the one time with the hard-to-find emergency release lever.
Old 02-28-2014, 10:05 AM
joylove joylove is offline
Mein Auto: 08 e83 LCI
I would suspect the module that controls the rear worker and trunk release may have a blown protection diode.
Old 02-28-2014, 07:58 PM
Totte Totte is offline
Mein Auto: E83 X3 2.5si (2009)
Maybe it is the GM5 module? More info here: http://www.bmwgm5.com/
2008 x3, liftgate, tailgate, x3, x3 liftgate, x3 tailgate
