Is there an auxiliary plugin in the 06? - Bimmerfest - BMW Forums
Old 03-10-2014, 04:43 PM
WVpaid4it WVpaid4it is offline
Mein Auto:
I would love to listen to my pandora through my stereo but can't find the auxiliary plug if there is one. It doesn't connect through my BT either.
Old 03-10-2014, 05:28 PM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
07 was the first year to add aux-in. None stream BT(too new of tech for the E85/86). You can easily add an aux-in or you can get the new Soundplicity system from Bavsound which gives you BT streaming capability/aux in etc.
Old 03-13-2014, 06:00 AM
funkle funkle is offline
Bimmerless
Mein Auto: Z4 M Coupe
Any idea how this compares with the Audiovox MediaBridge?
Old 03-13-2014, 10:57 PM
I do not. I have the OEM iPOD integration and it is ok but has a hiss in my car. Many here do not like the DICE type units but this is the newest version.
Old 03-15-2014, 09:59 AM
Bimmerless
So it seems that the Bavsound Soundplicity is the same as the Audiovox MediaBridge, which was the Dice. Most of the negative reviews of the Dice seem to be from several years ago. Perhaps they have it sorted. Amazon is filled with negative comments about the BT sound quality. But what people fail to realize, is that this is really a limitation of the Bluetooth standard (which simply doesn't have the bandwidth required), not the fault of the MediaBridge. If you want the best sound, you need to go with a wired connection, or maybe something like this
Old 03-16-2014, 08:08 PM
carolinaz carolinaz is offline
Mein Auto: '98 M Roadster
Aux in
If you don't need the ability to control the iPod or iPhone you can add a the Aux In jack to plugs into the factory head unit. I have a 06 MZ4 and the Aux In works fine. Only thing I've into was that you can't charge the iPod or iPhone and listen to the iPhone or iPod.
Adapter is a simple 20-30 minute install. I bought adapter from getbmwparts.com around $80.
Good Luck, Paul
