Old 02-23-2014, 11:27 PM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Folding side mirrors
Hi Guys, on my 04 525i E60, I don't have side folding mirrors. Is it possible to do a DIY on it and make it work to fold and unfold when locked/unlocked? Any DIY guide and cost estimate?
Also, I read somewhere, that the side mirror will twist down when the car is put into R, is that true. Mine does not do it, maybe Australia did not have that option.
Old 02-24-2014, 03:21 AM
wcr3d wcr3d is online now
Mein Auto: 2013 535iX M Sport
If yours has that option, you put the mirror selector switch on passenger. Only the passenger mirror will dip. As far as your other question, hou should do a search, I'm sure it has been done.
Old 02-24-2014, 03:22 AM
Old 02-24-2014, 10:28 AM
etnav382 etnav382 is offline
Mein Auto: 06 550i
For folding mirrors, you need to have mirrors that have the folding motor and also have the vehicle option added so the car knows that it has the mirrors. This will allow you to fold the mirrors by holding down the lock button, at least this was how my car was. Then I bought a new window switch that came with the fold button and now I can fold whenever I want and the mirrors auto unfold when I hit 30 mph. Hope that helps.
Old 02-24-2014, 09:25 PM
ilicboris ilicboris is offline
Mein Auto: 2004 545i
Are you sure you can't fold them manually? My 2004 545i doesn't have a switch on the door but I can fold the mirrors in manually. Found that out by accident, thought I broke the mirror when I first did it!
Old 02-24-2014, 10:34 PM
kskane's Avatar
From DownUnder
I can fold them manually. But want find out how much will it cost to do motorised folding mirrors?
Sent from my Droid bug
Old 02-24-2014, 11:42 PM
Mein Auto: 06 550i
It depends on how much they are going for used or new for a pre 9/05 car, plus coding and whether or not you want the button. I do believe that whatever mirrors you get would have to be European since no pre-lci in the states came with folding mirrors except M5s.
Old 02-24-2014, 11:47 PM
kskane's Avatar
From DownUnder
Thanks, anyone here know what built option is for folding mirrors and the one where the mirror tilts down on Reverse.
Is there any DIY on this or am the only one thinking about this
Old 02-24-2014, 11:49 PM
Mein Auto: 06 550i
You mean a diy for changing the mirrors? I did one over at 5series.net. Just search for my name in the diy section.
Old 03-22-2014, 12:59 AM
kskane's Avatar
From DownUnder
So for the mirrors to dip/tilt down when the gear selector is put into R is a feature that can be programmed or just requires a built option to be added to the VO or needs extra hardware to be installed? My side mirrors do not tilt on the E60 2004.
I understand the folding side mirrors inwards require the motorised mirror which I don't have.
Old 03-22-2014, 10:12 PM
It may be just a coding thing. I haven't actually seen one without it.
Old 03-22-2014, 11:08 PM
I think it's a coding issue. I don't see why you would need anything extra to make it tilt down when it goes to R since you can tilt them down yourself with the door controls.
It's interesting to see the options and features that were standard that different parts of the world got.
Old 03-23-2014, 01:38 AM
kskane's Avatar
From DownUnder
True, just for a bit of code some countries have to pay the $tealer. Anyway, does anyone know what code or option needs to be changed/added.
Sent from my Android Bug
Old 03-24-2014, 07:17 AM
kskane's Avatar
From DownUnder
Searched a bit more and my built information has the following option;
"S431A INNENSPIEGEL,AUTOMATISCH ABBLENDEND Interior mirror with automatic-dip"
Does that mean my side mirror should auto-dip? If yes, then I have tried the button position on left and right and it still does not work.
Old 03-24-2014, 08:24 PM
kskane's Avatar
From DownUnder
Okay, searched a bit and found the option that needs to be in the VO is $430. I added the $430 to both CAS and LMA module on my E60, but the external side mirrors still do not AUTO DIP (I tried with the side mirror switch on either side i.e. driver and passenger). What am I missing to get the external side mirrors to AUTO DIP?
Old 03-25-2014, 08:48 PM
tpaxadpom tpaxadpom is offline
Mein Auto: 550i
Look here: https://docs.google.com/spreadsheet/...CNPs2ucN#gid=0
Looks like you need a car Sept 05 or newer.
Old 03-28-2014, 03:37 AM
kskane's Avatar
From DownUnder
Now isn't that a pity mine is 2004 . But what is strange is, that if I cam adjust my mirror in all directions, by can't the flip work. That needs extra hardware, very bizzare.
Old 03-28-2014, 09:31 AM
paulsk66 paulsk66 is offline
Mein Auto: E60
I have an 04 525i and it works fine
Old 03-28-2014, 12:26 PM
camaroguy camaroguy is offline
Mein Auto: '07 550i Sport, '07 X3
Auto-Dip is no the same function as the tilt while in reverse. BMW"s have had that tilting mirror in reverse mode FOR EVER but only on cars with memory seat option (I do not know if all e60's have memory seats, the 5ers in the past didn't always have it). The Auto-Dip feature is the electro chromatic dimmer that happens at night when bright lights hit the mirror.
Old 03-28-2014, 09:38 PM
kskane's Avatar
From DownUnder
Paul, does your '04 525i has memory seats, mine does not.
Thanks for the explanation, that makes sense not to use the tilt/dip in a mixed up fashion . So based on that since I don't have memory seats, I guess it won't work.
Old 03-28-2014, 10:47 PM
My car is a January 2004 build and has the tilt-down mirror and the dimming mirrors as well. Might be a standard feature for 545i?
Old 03-29-2014, 02:59 AM
Mein Auto: E60
Yes I have memory seats
