Old 03-20-2014, 04:43 AM
Chig1245 Chig1245 is offline
Mein Auto: 528i
Vibration while Idiling and driving
My 2008 528i vibrates while idling and presently has done so while driving.....Can anyone tell me why this is happening?
Old 03-20-2014, 04:48 AM
jeremypcrook jeremypcrook is offline
Mein Auto: 2010 528xi
Could be the Exhaust.
There is a SIB that goes over and makes changes to hertz of the exhaust frequency.
This may be your issue? I believe it's what I am hearing, it's really faint.
Here is what another user posted and his dealer's fix/comments:
"Service Bulletin 18 02 08
Customer may complain of a slight vibration and/or droning noise when the vehicle is idling in park, neutral, drive and reverse when engine is at operating temperature.
CAUSE
Insufficient vibration dampening of the exhaust system.
PROCEDURE
1.Verify the complaint. Vibration/droning is most prevalent when engine is at operating temperature.
2.Remove the lower bracket for the exhaust system. If droning/vibration is gone, proceed to step three. If vibration/droning still exists with the lower bracket removed; continue troubleshooting exhaust/driveline for other causes or conditions
3.Remove complete bracket assembly and replace it with the bracket (1) PN 18 20 7 521 346 using two new ASA bolts (PN 07 12 9 905 417. Tighten to 21Nm.
Install front pipe bracket (1) PN 18 20 7 521 347 with four rubber bushings (2) (PN 18 20 7 546 579) to the new 346 bracket with two ASA bolts (PN 07 12 9 904 559) and two nuts (PN 07 12 9 904 580). Tighten down to 21Nm
After performing this procedure the vehicle will exhibit the same amount of normal driveline vibration as a comparably equipped E60 with a M54 or N52 engine."
Now what follows is the exact wording from the invoice of what the dealer did to repair my car:
"Insufficient vibration dampening of the exhaust system. As per service bulletin 18 02 08, verified vibration, removed lower bracket from exhaust system, vibration no longer present, removed and replaced complete exhaust bracket assembly and replaced exhaust vibration dampener, test drove vehicle OK. Defect Code: 18 11 00 39 00 Labor op: 18 99 000"
CURRENT: 2010 528xi
RETIRED: 2000 328I
RETIRED: 2004 530I
RETIRED: 2000 328I
RETIRED: 1985 325I
Old 03-20-2014, 04:49 PM
Jashley73's Avatar
Jashley73 Jashley73 is offline
Mein Auto: 08' 528i, 89 325i
Would this be metal-clanging sound that comes and goes when idling?
My wife's car will do this on the rare occasion...
Old 03-20-2014, 05:17 PM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
You may want to read the idle vibration thread below. And contribute if the problem is same.
Old 03-20-2014, 05:27 PM
Jashley73's Avatar
I don't believe that's the issue with hers. It's an 08' 528i auto by the way...
This sounds like two pieces of sheet metal banging gently together when parked and idling. It only happens on the rare occasion, and usually for a short time. No vibrations of any kind can be felt, so I doubt it's motor mounts. I believe it may happen more in the hot summer temps when the A/C is cycling. It's done this since we bought the car 3 years ago with 50k on the clock. (Coming up on 100k now...) To be honest, it's not much of an issue - I just read the thread title and was interested.
Old 03-23-2014, 12:52 AM
kskane's Avatar
From DownUnder
Sorry I meant to direct my post @OP.
In your case is that clamping noise is like a cricket noise that usually happen at cold start?
Sent from my Android Bug
Old 03-23-2014, 05:17 AM
Jashley73's Avatar
Nope. Sounds like sheet metal rattling. Probably the exhaust brackets referenced earlier.
