Replacing struts? - Bimmerfest - BMW Forums
Old 03-23-2014, 05:43 AM
Sumfuncomet's Avatar
Sumfuncomet Sumfuncomet is offline
Mein Auto: 2007 530xit, 2014 TDI
Replacing struts?
Hi all, I am thinking of replacing my struts with the KW V3 coilovers. When do must folks replace struts? I am at 76k miles on my 535xi, driven on mostly crappy roads here in Maine. The car feels a little clunky compared to last year, my mechanic says all suspension pieces are good, we did replace a tie rod end and a rear ball joint last month.
What about suspension bushings? Is that an expensive swap out? Thanks every body!
2008 535xi. 6MT,Cobb tune. ER FMIC ER charge pipe with Tial BOV,,R1 Concepts drilled rotors. Beyern mesh staggered wheels 18", Continental DW. M5tech rear bumper, Umnitza quad exhaust. Injen intake. KW V3 coilovers. USN Veteran USS Robert H. McCard DD822, USS Butte AE27
Old 03-24-2014, 04:50 PM
One hundred views and not a single bit of advice................c'mon guys!
Old 03-24-2014, 05:29 PM
ilicboris ilicboris is offline
Mein Auto: 2004 545i
Yeah I'm curious about this issue as well. My car rides like crap, in my opinion, because the roads here are pretty crappy. I'm not sure where to start with replacing parts. My indie says the suspension doesn't show much wear on it (123k now, not sure what previous owner replaced) but the suspension just clunks and makes noise and the ride is kinda choppy. I was thinking on starting with control arm bushings too.
Old 03-24-2014, 05:30 PM
srschang srschang is offline
Mein Auto: 528xi
123,000 miles on my 528xi, original struts. Still seems to ride & handle fine. I wouldn't waste the money.
Old 03-25-2014, 08:07 AM
gixman gixman is offline
Mein Auto: 2008 BMW 535xi
Pitch has doen the KW V3 upgrade. http://www.n54tech.com/forums/showth...ghlight=V3%27s
2008 535xi
Performance: PTF Custom Tune - Jake, AR Design Catless DP's, ER Intercooler, ER Charge Pipe, Forged Motor sports DV's, BMS DCI, Wedge Sport Flash/Coding
Suspension: KW V3's, UR Strut Tower Brace, UR Lower Strut Bar, M5 Pull Rods, RD Sport Sway Bars
Exterior: VMR VB3's 19's with Conti DSW’s, MTech front bumper, HID fog lights, Umnitza ICE LITE Angel Eyes, Clear LED Side Markers, Osram Xenon D1S 6000k headlights, OEM Gloss Black Kidney Grills
Old 03-25-2014, 08:38 AM
jager911 jager911 is offline
Mein Auto: Porsche 911, BMW 540
I have 88k miles in my 550 and my shocks are definitely toast with a floaty ride and replacing soon. IMO, shocks and struts wear out gradually where you may get used to poor handling and not notice it unless you drive aggressively. There isn't a specific mileage to use for replacement, it depends on how the car was used. I did shocks/struts and most of the bushings using new control arms in 540 around 100-120k miles. If you're keeping the car, I'd do shocks/struts and only change bushings/control arms when needed as it gets expensive. I did front wheel bearings at same time (125k) as the labor was common although they were not bad.
07 550i Titan Gray/black Dakota leather/anthracite bamboo/6MT/Sport/CWP/Logic 7/Comfort Access/Active Steering/NAV
'00 540i 6MT/Sport 255k+ original clutch!
'74 911 Carrera Orange- for track
'95 911 Midnight Blue
'02 Yukon
Gray - tow vehicle
Old 03-25-2014, 09:20 AM
pjinca pjinca is offline
USAF Pararescue Veteran
Mein Auto: 2008 550i
On my previous 530, I got H&R springs @ 50k miles. After that the stock struts lasted about 3 months, so I switched to coilovers. Struts are a wear item, and when you will need to replace them will depend on your driving and the condition of the roads in your area. Someone in NYC, for example, would probably need to replace them quicker than I do in SoCal where the roads are smoother.
2014 535i - MSport, HUD, NAV, Prem, Surround View, Driver Assist
2008 550i (R.I.P.)
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-25-2014, 03:03 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z4 3.0, 535i
Are you doing the work yourself? I have purchased the control arms, wishbones and tie rod ends but have not replaced yet. I am going to replace shocks with Sachs OEMs. I want to do all the work at once.
There are a few parts that I am not sure but I am considering replacement:
1. Shock mounts on all 4 corners
2. The coil springs
I am 204K on original shocks and coils, but has been mostly flat Florida roads.
Old 03-25-2014, 04:22 PM
2. The coil springs
I have replaced shocks/struts with coilovers on about 3 dozen E60s now. Front shocks are easy to unbolt, HOWEVER, if you have sport pkg - disconnect the sway bar end links before removing the strut. You have to push down fairly hard on the suspension and the endlinks will pop out and need replacing if not disconnected first. The rears are only harder because I have really large hands and it's a pain to get to the top bolts of the shock since they are located under the parcel shelf in the back (about 2.5 inches of access), just remember to remove the foam cover over the bolts without destroying it, you will need to put it back.
The coil springs are over the shocks/struts all around. If you are replacing the shocks/struts without replacing the springs I would suggest replacing the washers and nuts and the bump stops - for peace of mind.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 03-25-2014, 04:26 PM
camaroguy camaroguy is offline
Mein Auto: '07 550i Sport, '07 X3
I am also looking at doing the struts soon on my 07 550 sport. I will likely be doing shocks/springs/bumpstops/upper strut mounts on all four corners with OEM. I have 103k on the clock and can tell the suspension is a little tired, though it still feels ok.
I am undecided if I am going to stick with the "Sport" parts, or upgrade to the "MSport" parts. From everything I can tell on RealOEM, the only differences are the struts/springs/bumpstops.
As others have said, the time the struts will last is very subjective and depends on a lot of variables. Every other BMW I have owned in my life needed front struts by 100k easily.
Old 03-25-2014, 05:38 PM
There are DIYs on how to replace struts/shocks on our cars in other forums. For example: go to 5series.net and in the DIY section search for Rizbel, he's a member that posted a great DIY with pics on how to change them. Good luck, it really isn't that hard.
2008 550i (R.I.P.)
2006 Jeep SRT-8
Old 03-26-2014, 12:43 PM
I want to thank everyone for taking the time to provide some thoughtful responses.....I have decided to go with the KW V3 setup, I wanted to lower the car slightly anyway and I like the idea of adjustable rebound and compression. The reviews have been top notch on these units......except the price!,!!
Old 05-07-2014, 05:26 PM
J3willia J3willia is offline
Mein Auto: 2009 535i xDrive
I realize this is and old thread. Has anyone done a DIY on replacing struts on a 535xdrive. Bentley manual calls out for removal of the front axel from the carrier housing. I was wondering if this is a big deal or not.
Old 05-26-2015, 07:31 AM
eagle sailor eagle sailor is offline
Mein Auto: 2004 545i sport
any suggestion for a replacement strut I have the sport suspension dealer just did an alignment and stated that I have a bit of a slouching problem suggested struts and springs but I've always thought unless springs are broken they don't need to be replaced suggestions?
