Wet cabin AIR FILTERS after a car wash? - Bimmerfest - BMW Forums
Old 03-23-2014, 07:08 PM
Player5 Player5 is offline
Mein Auto: 2005 BMW 530i
After a car wash, I realized that my cabin air filters were wet (wanted to clean the inside of them).
Has anyone experienced this and is it okay them to be little wet?
2005 530i - Black/Black - mods done - K&N filter, M5 trunk spoiler, M5 Roof spoiler, LED license plate light, LED interior lights, LED Angel Eyes, Black matte front grills, 20" wheels, drilled & slotted rotors, vinly on side skirts, Black/Carbon BMW emblems in front & back, smoked side markers, smoked taillights
Old 03-23-2014, 09:01 PM
wiSes wiSes is offline
Mein Auto: 2007 bmw 530i
When you use the a/c it'll smell like wet dog, just fyi.
2007 BMW 530i
Modifications:
Muffler Delete (ITS TOO LOUD!! changing soon)
Old 03-23-2014, 09:22 PM
H F H F is offline
Mein Auto: 2005 545i
If your drains are slow to flow the water out , I suspect that they are getting , or they are clogged . Which will explain the cabin filter being wet .
If you remove the plastic fender well splash guard . Look under the cabin filter the u will see a drain exit . Pour water into the plastic piece at the bottom of the hood shock . On the ends of each filter the plastic piece has 5 holes that's where u pour water into . The water should exit immediately out the drain . If. It's slow if stopped up . Remove the rubber piece off the drain hose , then take out the cabin filters clean out the tray if you have stuff in there like leaves and dirt .
Get some weed wacker wire and stick it into up the drain hose from the fender well, and clean it out , then Blow it with a tire inflater Test it again , water will flow out that drain .
That should take care of the problem .
Old 03-24-2014, 10:38 AM
Thanks man, will definitely try that.
