Help plz x5 not starting asking for a code - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 03-18-2014, 06:05 PM
Tucker1108 Tucker1108 is offline
Mein Auto: Bmw x5
Hi pls my 2001 bmw x5 will not start it is asking me for a 4 dig code witch I don't have
Old 03-19-2014, 02:30 AM
BMW_E53_OWNER BMW_E53_OWNER is offline
Mein Auto: BMW E53 4.4i
I had such a problem with dashboard.
Dashboard was asking me code. (but engine was starting)
When I put key to start engine, timer started countdown on LCD of Audio.
After countdown was finished dashboard restored
Old 03-19-2014, 10:39 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
What number did you enter into (your MID?) or on your (Nav screen?)? If you are getting the anti-theft code...the only way that comes up is if you entered one (or someone else did) or if you're trying to start someone's vehicle which entered a code to prevent others from starting the vehicle. (sorry I have to go there but this is your 1st post and we don't know anything about you other than you're inquiring about how to overcome a possible anti-theft feature...so yes, some of us are conscious of this and are not sure giving instructions on how to overcome this feature should be doled out without speculation).
If you have an owners manual...it explains how this feature works (actually it's either in your MID or Nav owners manual...which we don't know which set-up you have).
For instance, if you have the MID...see the info below...again, the 4 digit "CODE" is not static...it is a number that was entered by you...and must be remembered because you will need to reenter the number you used to activate the feature:
If you have Navigation monitor...then see the instructions below:
Q {BMW CCA Member #191509}
(SOLD)
Old 03-19-2014, 01:10 PM
Mein Auto: Bmw x5
Hi I an asking because it it the first time it has happen to me and any one I asked do not no how to fix it I bough the car second hand and have contacted the last owner and he did not put a code in it
Old 03-19-2014, 02:56 PM
Mein Auto: Bmw x5
I have tried the reset Batty out for 5 mins and the key in pos 1 for ten mins and pos 2 the clock will not count down it just stays on 9,59
Old 03-20-2014, 10:41 AM
QSilver7's Avatar
Please identify which set-up you have. Do you have the MID or do you have the Nav?
(SOLD)
Old 03-20-2014, 03:50 PM
Mein Auto: Bmw x5
It is the nav
Old 03-20-2014, 10:38 PM
QSilver7's Avatar
Ahhhh,you have the nav...and you definitely had the ignition in position 1 (not position 2)....and couldn't get the countdown?
And you also tried the default code for the NAV (0123)?
If the above fails...you may have to hookup to diagnostic equipment and communicate with the IKE/OBC.
(SOLD)
Old 03-21-2014, 02:58 PM
Mein Auto: Bmw x5
Hi had a guy out to day from bmw and put it on his computer and it was giving no faults anyone any other info that could help me out can get it to count down at all
Old 03-23-2014, 03:43 PM
Mein Auto: Bmw x5
Hi could you give me some more info plz as I had a guy out and he had his computer and it was not giveing any faults he played around for about an hour and said he would get back to me
Old 03-24-2014, 12:08 PM
afletch16 afletch16 is offline
Mein Auto:
Same thing happened to my 2003 x5.. Didn't start try the code 0000 or 1234 they are the default codes. 0000 worked for me
Old 03-24-2014, 12:16 PM
Mein Auto: Bmw x5
[QUOTE=afletch16;8231778]Same thing happened to my 2003 x5.. Didn't start try the code 0000 or 1234 they are the default codes. 0000 worked for me
Sent from BimmerApp mobile app[/QU
I tryed them mate and the clock will not count down just stuck on 9,59
Old 03-26-2014, 02:09 PM
QSilver7's Avatar
[QUOTE=Tucker1108;8231804]
Look at your fuse index (front & rear) and look for any that are for the instrument cluster. Try removing them (one at a time) then try to start the vehicle. Perhaps you can isolate the fuse that is controlling the code.
Report back what happens.
(SOLD)
Old 03-26-2014, 02:28 PM
Mein Auto: Bmw x5
Smile
Thank you for your help yes I got it to a bmw work shop and he reset the cluster he told me and am back up and running thank you for your help
Old 03-26-2014, 08:53 PM
QSilver7's Avatar
Glad you got her going, and thanks for posting back your resolution.
(SOLD)
