2004 X5 3.0i front turn signal bulb replacement - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 12-09-2013, 03:41 PM
GrumpyOldCodger GrumpyOldCodger is offline
Send a message via ICQ to GrumpyOldCodger
Mein Auto: 2004 BMW X5 3.0i
My first post, so go easy on me...have been following the forum for a long time and thought I should join.
Here is my issue. Driver's side turn signal bulb needs to be replaced. I watched the videos listed on another post but they don't show/cover the 2004 model with the stupid protruding headlight cover washer jets. Anyway, undid the screws, didn't lose them, but the headlight will not slide out. The bottom part of the plastic lens will not fit through the opening. Not sure if the bumper was ever "whacked" and is slightly out of kilter, but I don't think so.
Do I need to take off the bumper to get the headlight assembly out? Surely no engineer in their right mind would design the bulb replacement to require that step...
Any thoughts? I'll see if removing the entire air filter box might allow me access.
Thanks!
Old 03-25-2014, 08:07 AM
seeskan seeskan is offline
Mein Auto: 05 X5 4.4/05 330CIC
Unfortunately the German engineers do. Yes you have to remove the bumper and then the light assembly in order to change the turn signal bulb.
Old 03-25-2014, 11:35 AM
tmvE39/E53/Z32's Avatar
A write-up as your guide.
http://www.xoutpost.com/bmw-sav-foru...tructions.html
Old 03-28-2014, 03:28 AM
x6cx3 x6cx3 is offline
Mein Auto: BMW X5
I changed the light bulb on my 2001 x5 without removing the bumper. First remove the plastic strips underneath the head lights, with a screw driver, then remove the screws behind the headlamp. I remember that one screw is pretty well hidden. It may be frustrating first time but after doing it a few time will be easy. On the left side remove the air filter box, will give more room. My bmw has the headlight washer.
Old 03-28-2014, 05:59 AM
Zulu95's Avatar
Zulu95 Zulu95 is offline
Mein Auto: 2001 X5 3.0L
x6cx3 - 2004 have a different front end from 2001.
OP If you read the link above you'll see in post #13 that it is not possible to remove the headlight unit completely in the face-lift models WITHOUT removing the bumper. Before trying anything go buy a load of masking tape and double tape bumper/headlight washers then see if you can finagle the bulb into the turn signal housing. If it were me I'd be putting LED's in there on both sides to make sure I never had to do it again.
http://www.bimmian.com/WeissLicht-LE...for-BMW-E53-X5
Just another example of BMW making sure their $tealers make lots of money.
Old 03-28-2014, 08:42 AM
1bad540's Avatar
1bad540 1bad540 is offline
No need to remove the bumpr, take the 4 screws holding the headlight in and pull the headlight forward, your not going to have a whole lot of access but its enough to twist out the bulb holder and swap a new bulb in.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
