Old 03-28-2014, 01:42 PM
dismoi2 dismoi2 is offline
Mein Auto: BMW Z3
Z3 won't start
Hello everyone,
So, I was driving my Z3 and the engine light came on. no problem...car was still going. I parked it in the garage, and the next day it wouldn't start. the starter doesn't crank. all it does is a "stuunk" noise. battery is fine, lights are on but a little dim. I know it can be a lot of different things that causes the problem, but was wondering if anyone experienced the same scenario.
I am not mechanically inclined so any help would be great.
Old 03-28-2014, 01:56 PM
Bob2.8 Bob2.8 is offline
Mein Auto: 1997 2.8
That sounds like a low battery or poor connection. If the lights are dim I would check the battery connections. You say the battery is fine, have you checked the voltage? Do you know what caused the engine light to come on?
Old 03-28-2014, 11:46 PM
Mein Auto: BMW Z3
Well, I have one of those battery station that you plug in to charge, and when charged, you can clamp it to the car battery and that allows the car to start using the station as battery. But you are right, I should jump start it from another car to be more sure. I'll try that tomorrow.
I don't know what caused the engine light to come on. I was driving normally when it went on.
I'll post the result of the jump start tomorrow. Thanks for your help.
Old 03-29-2014, 05:43 PM
Mein Auto: BMW Z3
ok, I tried to jump start the car with another car, and still the same. The starter doesn't crank. just noise "chtounk, chtounk, chtounk. any idea?
Old 03-30-2014, 05:50 AM
Mein Auto: 1997 2.8
Does it only make the sound once when you turn the key to start? Since you got a check engine light I'm also wondering what is going on there. Do the lights go dim when you try to crank? This could be a bad connection, bad starter or possibly a "stuck" engine. You could put a wrench on the crank pulley to try turning the engine to see if it's free, or try push starting whichever is easier. I'm only thinking of that because of the check engine light. Do you have a volt meter you could use to check the voltage at the starter?
A common problem is the battery cable connections in the cable itself, if they have green corrosion around the ends there may be a bad connection in the cable.
