The X5 SAV Forum
Old 03-21-2014, 11:24 AM
NicC NicC is offline
2004 E53 3.0d Sport
Mein Auto: E53 X5
E53 Rear Washer Problem
Hi All!
Glad to be a part of the community! My 2004 E53 rear washer doesn't pump any fluid. I can hear a noise when I press the washer stalk forward and the wiper moves in conjunction but no fluid appears. Is this a broken pump? The nozzle seems to be clear of any blockage.
I would really appreciate any ideas or suggestions.
Thanks team!
Old 03-26-2014, 07:58 AM
seeskan seeskan is offline
Mein Auto: 05 X5 4.4/05 330CIC
Originally Posted by NicC View Post
Hi All!
Thanks team!
Swap the rear window washer pump with your good wind shield pump for trouble shooting. If it works then it is a bad pump.
Old 03-26-2014, 02:41 PM
2004 E53 3.0d Sport
Mein Auto: E53 X5
Hi, thanks for the response, I've bought a new pump bit can't work out which of the 2 pumps on the fluid resivoir the rear pump is. Do you know which one it is?
Old 03-26-2014, 03:00 PM
Cool
Hi
Your head lamp washer pump(if you have one) is larger than the other two you can tell. The other two (wind shield and rear window pump are identical. Pull the electric plug in one of them. And try your wind shield washer, if it works then you have disconnected the rear pump. If it doesn't, the rear pump is the other pump. Confused?!:
Old 03-28-2014, 08:48 AM
1bad540's Avatar
1bad540 1bad540 is offline
both of mine had a slight leak in them and I found meyle replacements on ebay for under 20 each, swapped them both.
[SIGPIC]
e39 540i sprt, acs type 2's,acs pdls,clrs(sold)
e65 745i sprt,21's aib's acspdls, rf splr(sold)
e46 328i 18" 335spt whls(sold)
c5vette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav(sold)
e53 X5 3.0, pna rf,nav,xnon,cldwthr,20"4.6rims.(sold)
e65 750I aw, sprt. 21's,acs pdls,acs rfsplr,mtecs,8k hid(sold)
Srt10 VIPER, 19-20" forged,tune,corsa ex,intake.
w221 S550 amg,dia white,5%3m tint.20"s63rims,lwrd
e70 3.5 aw.mtec, powdr blk whls.
e46 M3vert,6spd,19"HRE,bbk,ext,intke
Old 03-28-2014, 11:38 AM
Scott ZHP's Avatar
We want the Lion!
The pumps themselves were leaking? Can you describe the leak? Was teh outlet cracked or something? My E46 has a leak in the washer system somewhere and it's driving me nuts. The tank isnt cracked, the pump grommet is new, but it still leaks.
Old 03-28-2014, 01:29 PM
The pump has a small rectangular "weeping hole" on its body. When it wears out internally it would leak out of that hole. Time to replace.
Old 03-28-2014, 09:22 PM
Rahulk Rahulk is offline
Mein Auto: E53 N62; E90 N52
I got the same issue.. I replaced the pumps and get nothing....
Old 03-31-2014, 01:34 PM
2004 E53 3.0d Sport
Mein Auto: E53 X5
Disconnected the pumps one by one to ensure I had the right pump and once identified the correct pump replaced it with a new pump (12 eBay) and now works although it doesn't "mist" spray like the front but at least it now works, saved me a few quid on garage bills I reckon!
