Old 03-17-2014, 02:50 PM
rmurwin rmurwin is offline
Mein Auto: 1997 1.9 Roadster
Z3 Clutch Slave Cylinder
Hi everyone,
New Z3 owner here, it's a 1997 1.9 Liter; I owned it for about 6 hours before I found the first problem that I have to fix on it.
The clutch slave cylinder (OUTPUT CYLINDER CLUTCH) is leaking quite badly. So much that the clutch doesn't disengage any more.
Here is my question: Rebuild kit or entire slave cylinder, which is the better choice?
Thanks in advance.
Old 03-17-2014, 02:56 PM
BeemerMikeTX's Avatar
BeemerMikeTX BeemerMikeTX is offline
Mein Auto: Z3 3.0i Roadster, K1300S
Originally Posted by rmurwin View Post
Hi everyone,
Thanks in advance.
From realoem, a new clutch slave cylinder is about $83.00. Hmmmm . . . a new one for $83, or rebuild a 17-year-old one with a repair kit that costs $41. It would be a pretty quick decision for me (new one).
Mike White
"That's right, you're not from Texas, but Texas wants you anyway." -LL
2001 Z3 3.0i Roadster (Topaz Blue Metallic, 5-speed manual, Sport Package, CD radio, heated seats and mirrors, non-power top via special order)
"Beemer" is for my BMW motorcycles - '13 K1300S, '95 R1100RS, '88 K75S, '75 R90S (gone, but not forgotten).
Old 03-17-2014, 03:05 PM
Right. I get that. I was thinking similar things... I found it on realoem also, but it doesn't look like they sell parts... where do festers like to buy their parts from?
Old 03-17-2014, 03:14 PM
Look at the bottom of the realoem parts diagram that has the clutch slave cylinder. You will see the rebuild (repair) kit, for $41.
Mike White
Old 03-17-2014, 03:34 PM
Bob2.8 Bob2.8 is online now
Mein Auto: 1997 2.8
Get the part # and check some of the site sponsors,
for example here a replacement for mine is $36.95
http://www.bavauto.com/shop.asp
Old 03-17-2014, 05:03 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
There are a few other sources for OEM parts here: http://www.bimmerfest.com/forums/sho...d.php?t=681393
This is also the perfect time for a new stainless steel clutch line and Clutch Delay Valve (CDV) delete, if so equipped.
Also, be sure to search here on how to bleed the slave cylinder. It must be done correctly before completing the installation.
Old 03-17-2014, 05:13 PM
Thanks for the pointers. I'll do a search to find out what you mean.
Old 03-17-2014, 05:19 PM
vintage42's Avatar
BMW CCA 1405
The PN is 21 52 1 159 045. Also available from ECSTuning.com for a little more. But ECST shows that at that price, the part is made by febi, a very reputable aftermarket mfr, rather than OE:
http://www.ecstuning.com/Search/Site..._52_1_159_045/
http://www.febi.com/febius/home.html
Old 03-17-2014, 05:24 PM
vintage42's Avatar
BMW CCA 1405
This...
http://forums.bimmerforums.com/forum...4#post27417074
Old 03-17-2014, 06:02 PM
Or slightly more complete, this: http://www.bimmerfest.com/forums/sho...d.php?t=614294
Old 03-18-2014, 06:37 AM
Thanks for all the good advice; I'll apply your collective wisdom to my situation and let you know how it works out.
Old 04-01-2014, 01:07 PM
I installed the slave cylinder and while bleeding it discovered that something else was wrong; the piston/shaft wasn't contacting anything apparently and it came completely out of the cylinder. It dropped into the housing... So I put it on the trailer and took it to my mechanic. He managed to fish the piston and the thing the piston is supposed to push on out of the housing and got it fixed up and working for me. Unfortunately he also told me that it has a bad wheel bearing on the right-rear (that's what that noise is?), so I won't get it back until tomorrow.
So here is my question for you guys now: when you take the slave cylinder out, is there another part you have to be aware of and remove at the same time (or at least make sure it stays in place before you put the new slave back in)? Basically, how did I screw it up?
Old 04-01-2014, 02:03 PM
vintage42's Avatar
BMW CCA 1405
... when you take the slave cylinder out, is there another part you have to be aware of and remove at the same time... Basically, how did I screw it up?...
It has happened before. This thread says you just need to be sure the slave's pin seats on the lever inside the bell housing.
http://forums.bimmerforums.com/forum...Clutch-Install
Old 04-01-2014, 06:14 PM
Dale K Dale K is offline
Mein Auto: '00 M Coupe
Correct. If you're installing the slave, and there isn't noticeable (quite a few pounds of force) resistance (push back) to getting it seated on the mounting bolts, you're doing it wrong. If that pin/rod is going into dead air space instead of being seated in the detent on the lever arm, it's going to shoot out of the cylinder on the first application of the clutch.
output cylinder, slave, slave cylinder, z3
