Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 04-09-2014, 08:45 PM
brocklanders brocklanders is offline
Mein Auto: e90 325
rear sway
Has anyone replaced the rear sway. I'm thinking I should be able to retro the 1m sway does anyone know if it swaps right in. I looked at the eibach and I think that's a better choice but I'm kind of thinking staying with bmw parts would be better. Also with the eibachs I don't know if they come with endlinks, the rears are as pathetic as the bar.
Old 04-10-2014, 08:37 AM
4ocious 4ocious is offline
Mein Auto: 2011 135I MS 6MT, 2006 X3
I'm interested too. Do you think changing the rear sway bar will improve the handling and will it be noticeable? I recently installed the Cusco front strut brace which made a very slight handling improvement. I'm slowly setting my car up for the track and changing the rear sway bar may be a good idea, or not.
Current:
11 BMW 135i Grey/Blk Cpe/M-Sport/6MT/BMW Perf. Mods/Cusco Brace/K&N's/All OEM Options/PPK ECU
10 Porsche Cayenne GTS/Design Ed 3 (1/100)/K&N's/2nd Cat Delete/425hp
06 BMW X3, Bluewater/Tan/K&N's/XM (Wife's)
Old 04-10-2014, 09:03 AM
Mein Auto: e90 325
My opinion is the bushings and sways should be the first thing anyone does to this vehicle. If you are tracking I would be cautious with the rear suspension, there isn't any sort of limited slip and you don't want to go too stiff in the back it may end up hindering lap times. I think the 1m bar is too big if you don't have a limited slip, this is why I like the eibach over 1m, it is a huge difference over stock and keeps the same front to back bias. In your case I would get a limited slip first then new bushings and sways, and maybe springs and shocks. You should also think about brake pads and steel lines.
Old 04-11-2014, 07:39 AM
Great feedback, thanks, I'll look into the LSD first.
Current:
