E34 (1989 - 1995)
Old 11-06-2011, 07:55 PM
south26 south26 is online now
Mein Auto: 535i 1989
replace front end what a differnce
Well I replaced the front end on the car I got last month and OH MY GOD, I have never seen so much old ****. There were control arms on there that had pins. Even my e28 did not have those when I got it and it was also in bad shape. Most of the rubber covering the joints was gone. I found out very quickly why there was 2 inches of play in the steering.(which made it kind of scary to drive in weather.) Even without a front end alignment she is better to drive ( I will be getting one on Tuesday.)
So now the next step is to find out where the brake fluid is leaking. The brakes are great, but I have to keep adding fluid so I am thinking the seal on the master is bad.
Andy
Old 11-06-2011, 09:53 PM
JC540I's Avatar
JC540I JC540I is offline
Mein Auto: 95' 540ia-orient Blue
Good to hear, i noticed an enormous difference when i did mine, jsut got to finish up all mounts and other bushings.
"Straight roads are for fast cars, turns are for fast drivers." -Colin McRae
Owned/own:
1995 M3-cosmos black(E36)
1998 528I-schwartz black(E39)
1999 328IS-steel blue(E36)
1995 540IA-orient blue(E34) 5/6 speed swap soon.
Old 11-07-2011, 03:36 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
Same here. In fact i have two cars that are mechanically and structurally identical, the schnitzer has all brand new oem struts linkages etc you name it, while the other one is rooted. It really makes a huge difference doesnt it, you can definately tell
E30 above Sold
Last updated 2nd January 2014
Old 11-07-2011, 09:15 AM
JC540I's Avatar
Do the rears also (pitman arms and sway bar links) it makes the car feel almost brand new and much stiffer. loving it!
Owned/own:
Old 11-07-2011, 06:30 PM
Wink
I did replaced the dogbones,, how are the the rear sway bars to replace? on the e28 they are a bitch.
Andy
Old 11-07-2011, 07:40 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
Sway bar links are about the same hassle as the dog bones (pretty easy and straightforward). Make sure you have plenty of dish soap available though!
Sent from my Droid Incredible
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 11-07-2011, 09:01 PM
pitman arms....
At the risk of coming our stupid, my understanding is they are only on solid rear axel cars? I must admit i havent been under my e34 much yet.
E30 above Sold
Old 11-07-2011, 10:06 PM
JC540I's Avatar
"Rear Trailing Arm Link"pitman arms as noted on FCPgroton and on some other sites i have seen..I just call them dog bones unless i am posting,usually
Owned/own:
Old 11-07-2011, 11:08 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
It's referred to a pitman arm, because just like the function of a pitman arm in the front steering system, the link acts as a cam that imparts steering leverage.
In the case of the E34 trailing arm, they control toe under braking and acceleration. A semi-trailing arm geometry method they gleaned from Porsche.
Good food, good people, good times.
Old 11-08-2011, 01:03 AM
hope the OP doesnt mind going off topic...
is it part 10 in this image? http://realoem.com/bmw/showparts.do?...19&hg=33&fg=30
E30 above Sold
Old 11-08-2011, 09:14 AM
Radian's Avatar
Part 10 in that image is a truss for the rear subframe.
The Pitman arms, a.k.a. dog bones, are Part 6 in this image:
http://realoem.com/bmw/showparts.do?...21&hg=33&fg=30
Old 04-10-2014, 12:11 AM
staskz staskz is offline
Mein Auto: E34
In the front there are 2 idler arms and 1 pitman, correct?
Old 04-10-2014, 12:20 PM
Mein Auto: E34
Can someone confirm above question? Or is it one of each?
Old 04-10-2014, 06:34 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is offline
Nothin like an E34
Mein Auto: 95 540i B/B
http://www.bmwe34.net/E34main/Mainte...ering_link.htm
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
