1991 BMW 325i auto swap to 1994 BMW 325i manual - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 05-04-2014, 09:23 PM
Amory.martinez Amory.martinez is offline
Mein Auto: 2001 bmw 325i
Exclamation 1991 BMW 325i auto swap to 1994 BMW 325i manual
Please help fellow bimmer drivers. Swapped to 1994 engine and manual trans . not running now. Did I miss something with the auto electrical.s. I hooked up engine harness and nothing no click no power to ignition and fuel. Please help much appreciated
Old 05-04-2014, 09:34 PM
Please help send a link something please went in unprepared need help
Old 05-06-2014, 03:24 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
What do you mean you hooked up the the harness ? Are you using the ECU from the 94' ,is it getting power , did you hook up the neutral safety switch.
Old 05-06-2014, 09:45 AM
Hey you builder sorry I don't make sense. Yes the ecu is hooked up and grounded out is from the 94. As well as the engine harness for the 94 is hooked up. And is getting power. I know this because I take the ground off the ecu and engine has battery voltage. I think that's weird though should be the other way around. And I'm stuck at the neutral safety switch. I don't under stand people saying ground it out. I tried to put the two wires together. Nothing just brake lights stay on. I grounded both wires and it just pops a fuse.
