Eta Spinning tires - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 05-07-2014, 12:09 PM
wallyg wallyg is offline
Mein Auto: Jetta
Eta Spinning tires
Can a 1987 325e be able to spin the tires atleast a little bit?
I have a 1987 325e with a sssquid chip and 3.25 LSD and I cannot spin the tires at all, is this normal?
I know the e stands for economy and I'm not trying to be a drift king
Old 05-07-2014, 03:59 PM
astroboy424's Avatar
astroboy424 astroboy424 is offline
@antwannnnnn
Mein Auto: 1986 325 "eta"
I don't think you can with a lsd I have the same and I spin tires easily. I can literally drift by turning and piping the clutch
"OH YOU KNOW.. CAUSE THUNDER COMES AFTER LIGHTNING,
KA-CHOW KACHOW KACHOW" -MCQUEEN
|OO=[||][||]=OO|
/____ALPINA____\
Old 05-07-2014, 04:52 PM
downhiller's Avatar
livin large
youre not doin it right. the motor has the torque to do it and this could be signs of a worn clutch too.
Old 05-07-2014, 06:27 PM
hornhospital's Avatar
D'oh, You Kids!
This ^
Quotes to live by:
BMW-CCA #441426
Old 05-27-2014, 08:54 PM
woodenbmw's Avatar
woodenbmw woodenbmw is offline
Mein Auto: 1987 BMW 325
What if you have an automatic transmission ?
1987 325e sedan automatic
Old 05-28-2014, 04:44 AM
downhiller's Avatar
livin large
youre screwed. cant brake stall it due to disc rears and youd basically have to neutral drop it which can break some stuff on these older cars
Old 05-28-2014, 06:05 AM
woodenbmw's Avatar
I guess I'll have to stick to power slides.
Old 05-28-2014, 06:27 AM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Ah, to be young again...
Old 05-28-2014, 12:32 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Why are you trying to spin the wheels?
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
Old 05-28-2014, 01:24 PM
woodenbmw's Avatar
Just to see if I can. I've done it with all of the cars I've owned
Old 05-28-2014, 01:27 PM
B1MM3R's Avatar
Jesse Moon Bayne
You realize unless your car is set-up to be abused, then it's easy to brake things right?
Jesse
2007 328i DD
Old 05-28-2014, 03:50 PM
woodenbmw's Avatar
Yup. I enjoy fixing my car, it gives me an opportunity to get under the car and really appreciate and understand the working parts better. Now if only I could wrap my head the electronic systems...
Old 05-28-2014, 04:39 PM
downhiller's Avatar
livin large
plenty of books and a multimeter will help you alot
Old 05-28-2014, 05:12 PM
woodenbmw's Avatar
I've had my multi meter for years and I still haven't figured it all out lol. It just took me three weeks to figure out I had a blown fuse :what:
Old 05-28-2014, 07:25 PM
downhiller's Avatar
livin large
a test light works great for that.
Old 05-28-2014, 07:32 PM
woodenbmw's Avatar
Now you tell me lol
Old 05-28-2014, 11:25 PM
FieryDawn FieryDawn is offline
Mein Auto: 1998 SF5 Turbo Forester
do it a standstill holding the brakes :P i did it once, (in a holden) rooted the brake pads tometal, and the discs too small :P
why not get one of those electric valves for the brake line?
1989 325i m-sport coupe
rolling chassis - with factory weight reduction (rust) :P
1990 318i
5 speed manual
Old 05-29-2014, 04:15 AM
downhiller's Avatar
livin large
Eta Spinning tires
thought maybe you had one in your tool box
a standstill? its called a brake stand. and i havnt seen a electric servo to cut fluid to brakes. only trans locks for drag
Old 05-30-2014, 01:12 AM
we call them standstills i saw a servo one a couple days on a car buying/selling page im part of, was relatively cheap from memory
1990 318i
5 speed manual
Old 05-30-2014, 04:57 AM
downhiller's Avatar
livin large
you could do a trans lock and a high stall torque converter.
