E30 (1982 - 1993)
Old 05-08-2014, 03:35 AM
nickabluh nickabluh is offline
Mein Auto: E30 318i
Need water pipe connector dont wanna order online
1991 318i e30
Whatsup guys, so one of the inlets that connects to a heater core hose on my water pipe connector snaped off and most of the coolant my motor was holding exited through the whole so im in need of a new water pipe connector. i found them on ebay for about $15 but i really don't want my order cause im hanging out with this girl this weekend and im definantley trying to be driving my dirty 30. does anyone know if i can get that part at an autozone or anything shops? and is that the correct name for the piece?
Name:	water pipe connector.jpg
Old 05-08-2014, 03:41 AM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: Two 1987 325i, 430K, 211K
Pick n Pull. Lot of E30s in the boneyards in the Bay Area.
I'm guessing that won't be at the mainstream auto parts stores.
All New Parts in Berkeley could probably UPS you one that would get there by Friday:
510 - 548 - 8748
Tell him Carl sent you.
Old 05-08-2014, 04:22 AM
downhiller's Avatar
livin large
heres what you do. order the part online. bypass the heater core for now, its a little bit of tight squeezing but that way you can still drive the car and go fondle your woman
Old 05-08-2014, 05:51 AM
Mein Auto: E30 318i
thanks guys, carl ill definantley call first thing in the morning and see what they can do for me!
Old 05-08-2014, 06:14 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
Man up and buy a new one.
Most running problems on BMW are caused by the plastic cooling system components becoming brittle and cracking thru repeated heat cycles.
The economy of installing a used, brittle 100k + mile old replacement makes no sense.
m
Old 05-08-2014, 06:59 AM
cmac2012's Avatar
Renaissance Dude
His prices are very good, all OEM parts. Located in Berkeley FWIW.
Old 05-08-2014, 07:19 AM
Mein Auto: E30 318i
7pilot man up and buy a new one? i never said i was looking for a used part.
Old 05-08-2014, 08:13 AM
cmac2012's Avatar
Renaissance Dude
You didn't, he might have been shooting my boneyard idea down and with this part he has a point. Some parts are perfect from boneyards, but if this is nylon or plastic of some sort as I suspect, new is best.
