E30 (1982 - 1993)
Old 10-27-2012, 05:29 PM
garagistic's Avatar
garagistic garagistic is offline
Mein Auto: e30
Lightbulb E30, E36 and Z3 powersteering delete blocks
Came out with a power steering delete block. No ghetto hose loops or complete block offs like other routes already on the market.
http://store.garagistic.com/ocart/power_steering_delete
The details:
Many track e30, e36 and z3 run with no powersteering to get a better "feel" for what the car is doing. However, many people are needing to ghetto rig a hose on the factory banjo fittings or worse yet, they are using plug systems that do no allow for fluid/air to get from one side of the rack to the other. This often results in blown seals and a higher rate of steering effort.
Our steering aluminum block are made of high quality aluminum and feature a side pathway that connects the two banjo fitting holes to make sure that fluid/air can easily pass between them.
They can be purchased from here:
Old 02-07-2013, 11:55 AM
garagistic's Avatar
Mein Auto: e30
Got many in stock ready to ship
Old 04-19-2013, 11:00 PM
garagistic's Avatar
Mein Auto: e30
3 left in stock.
Old 05-24-2013, 12:17 PM
garagistic's Avatar
Mein Auto: e30
Out of stock. More available tommrow.
Old 06-08-2013, 12:21 AM
garagistic's Avatar
Mein Auto: e30
6 in stock!
Old 08-07-2013, 01:27 PM
garagistic's Avatar
Mein Auto: e30
In stock and ready to ship!
Old 08-17-2013, 01:18 PM
garagistic's Avatar
Mein Auto: e30
Tracking numbers sent. THank you.
Old 09-18-2013, 02:05 AM
garagistic's Avatar
Mein Auto: e30
Running a special on these this month!
Old 09-18-2013, 09:18 PM
logantv logantv is offline
Mein Auto: 1990 325is m20/260
About how much does it affect steering effort at low speeds if full power steering is 10 and just cutting the power steering belt is 0?
Old 09-19-2013, 03:27 PM
garagistic's Avatar
Mein Auto: e30
It will be like 1-2. Increased effort at parking lot speeds but not unbearable. Pros are: weight savings, high speed stability, one less item to fail (or leak) track side, and increased road "feel".
Best way to know if your going to like it is to disconnect the power steering belt and give it a shot.
Old 10-26-2013, 02:49 PM
garagistic's Avatar
Mein Auto: e30
3 left in stock!
Old 11-22-2013, 12:21 PM
garagistic's Avatar
Mein Auto: e30
All loaded up again!
Old 02-03-2014, 03:02 PM
garagistic's Avatar
Mein Auto: e30
Still in stock!
Old 05-08-2014, 07:53 PM
garagistic's Avatar
Mein Auto: e30
Tons in stock!
Old 11-29-2014, 03:09 AM
garagistic's Avatar
Mein Auto: e30
Tracking numbers sent!
Old 07-22-2015, 08:49 PM
vaquerotr vaquerotr is offline
Mein Auto: 1993 328is "Gretchen"
can i install this without having to remove the steering rack?
e30 power steering delete
