E30 (1982 - 1993)
Old 05-08-2014, 09:54 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
e30 m3 eibach's on non m questions.
I just bought a used bilstein shock and eibach spring set off of an e30 m3. The springs are 2017.101 and 2017.002. Front specs 1.3'' drop on m3, rear .8'' on m3. Will the drop on my e30 325e be the same drop it did on the e30 m3 or will it lower my car more? Anyone have these on a non m? Pics would be great. If these are going to drop my car about 2'' then im open to trade them for a standard eibach or h&r spring set.
Thanks ahead of time.
JB
ID:	438287   Click image for larger version
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2007 328i DD
Old 05-08-2014, 12:51 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
It shouldn't make any difference, Jesse. The springs are going in a car that weighs almost the same as an M3, and weight is what shoves the springs down. The drop should be the same.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 05-08-2014, 01:18 PM
B1MM3R's Avatar
Jesse Moon Bayne
Cool Ken, thanks.
Jesse
2007 328i DD
Old 05-10-2014, 11:25 AM
BigBoy740il's Avatar
BigBoy740il BigBoy740il is offline
Mein Auto: 1989 E30; 2000 E38; GS350
B1MM3R
You need to measure the diameter of the front struts cartridges as there are two different sizes. The non sport models had a 1.5in whereas the sport models had an insert size closer to 2in.
Big Boyz with Bad Toyz
Big Boyz with Bad Toyz.
Old 06-10-2014, 08:20 AM
B1MM3R's Avatar
Jesse Moon Bayne
I ended up selling them b/c the drop was going to be too much. I picked up a set of bavauto springs! Thanks.
Jesse
2007 328i DD
