Old 05-15-2014, 08:21 PM
djstrachan's Avatar
djstrachan djstrachan is offline
Mein Auto: 2004 325i ZSP
CA emergency!
Finally got up the nerve to replace the CAs. I've done the CABs before so seemed like a similar task.
Got the inner BJ nut about 90% off and it started spinning. Tried penetrating oil, jack under BJ to put pressure on the joint, jamming a pickle fork in between arm and frame...nothing. It won't budge just gets harder to turn with pressure on the joint but nut and bolt turn together. THere's about 1/8 of an inch of bolt above the nut. .
I went at it from above with an impact gun but no luck.
What a mess!!
"It is little use listening to other people as they will either be agreeing with you or saying stupid stuff" - Dogbert
I'm not a pessimist. At some point the world sh!ts on everybody. Pretending it ain't sh!t makes you an idiot, not an optimist.
2004 325i - Sport package - 5MT- clears - CDV mod - M3 gauge faces w/silver gauge rings & red needles - SS exhaust tips - strut tower brace - Hotchkis anti-sway bars -50% tint - shadow grills - roof spoiler - silver CF trim
Old 05-15-2014, 09:18 PM
racin366 racin366 is offline
Mein Auto: 04 325ci
Try tightening it back down and inspecting the threads, the top part may be burred, rolled, etc. It may also make it easier to remove with the impact gun if you start from it being tightened down.
Old 05-15-2014, 09:25 PM
Fast Bob's Avatar
Keeping it surreal
In a worst-case scenario, put a nut splitter on that mofo....
The road goes ever onward....
(R.I.P. Jever)
Old 05-15-2014, 09:41 PM
djstrachan's Avatar
Tried that. Just spins. Nut is stuck near the top of the bolt. Need to find a way to "freeze" the BJ so I can get it to budge.
Old 05-15-2014, 09:43 PM
djstrachan's Avatar
That's be nice but can't see how I could get that into that cramped space.
I may be able to pry the arm away from the cross frame enough to use a grinder with a cutting wheel and cut it off. What ya think?
