Old 05-14-2014, 01:42 PM
Benoit Benoit is offline
Mein Auto: 2009 bmw 328i
Jump start
I have an 09 328i lately I had to jump start my car Sunday may 11 and again Today Wednesday may 14. Twice in a week don't seem Normal. There is a recall on the battery cable under dash it was taken care of six months ago. Is there a chance might need new battery soon if so what battery you recommend thanks .
Old 05-14-2014, 02:12 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Measure the battery voltage and the alternator
voltage . If you are letting the car sit for long periods of time
or not driving very far a battery tender is suggested for
use with these cars as they are battery hogs.
Any of the major brand battery that matchs or exceeds the specs are fine.
Do not use battery backup when changing especially through the OBD port as it
will blow the fuse for the OBD and instrument cluster.(Fuse 58 or 74 depending on the car)
I have a Interstate MTP49/H8.
Old 05-14-2014, 02:19 PM
DSXMachina's Avatar
Bimmerdex 7.4!
What he said. It is not rare for a five year old battery to fail depending on its history.
Old 05-14-2014, 02:22 PM
Thanks the car don't sit I'm constantly in it. I just stop the car for a few minuets and twich had to get a jump. Also fail to mention I was using an iPhone car charger
Old 05-15-2014, 12:55 PM
AndrewHA AndrewHA is offline
Mein Auto: BMW 335xi Coupe
make sure you register the battery or it will go flop
Old 05-15-2014, 02:16 PM
Thanks how do you register battery
Old 05-15-2014, 03:47 PM
You have to go to a dealer... or find someone who has the right tools
Old 05-15-2014, 03:59 PM
Thanks again
Old 05-15-2014, 04:08 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
5 years old battery fail can be very normal
I replaced mine after 6 years and 25,000km
Non OEM is not that expensive $250 OEM vs $130 non OEM battery BUT YOU MUST get the battery registered by a car electrician (about $50) or weird warning lights may come up
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 05-15-2014, 04:21 PM
Thanks I just saw a you tube video on how to replace the battery: However; the guy said didn't need to register. Why would he say that ?
Old 05-15-2014, 04:48 PM
You don't HAVE to register it, but the car will charge it incorrectly and kill it much quicker than if you would.
Old 05-15-2014, 04:51 PM
Thanks that's why I like Bimmerfest you get a better answer than a you tube video
Old 05-15-2014, 06:33 PM
SilverX3's Avatar
you don't have to at your own risk
Many electronic parts of E9x are very voltage sensitive (eg. ABS Module, electronic steering wheel lock etc.) and not registering you risk these parts to play up and the car may not deliver correct voltage to these parts
Job - Captain
MY11.5 X1 Xdrive25i
Old 05-15-2014, 08:33 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Now look, Benoit, if your'e going to do it, do it right: View & Do
Always register a new battery - even if identical replacement, new battery charges somewhat differently than worn out unit. You can do it, or Indy can do it, or - oink! - dealer can do it.
Old 05-16-2014, 07:32 AM
fdriller9 fdriller9 is offline
Mein Auto: '06 AW 330xi
Battery registration is NOT about power delivery. It's about extending battery life.
When you register a battery, it logs mileage, resets the charging profile, and stores a reference at 80% charge.
The car actively monitors the battery's condition via the IBS sensor. Based on readings from this sensor, the DME will vary idle and alternator output so the battery can recover quickly from a discharge. It also prevents over charging the battery.
When the engine is running, the alternator is supplying the majority of the current all the modules in the car need. It's also supplying over 12 volts so current consumption should actually go down when the engine is running vs when it's off. The sole purpose of the battery is to supply power with the engine off and to start the engine. Other than that, it doesn't do much.
Unless you were having issues when you took the old battery out, you shouldn't have too many problems without registering.
However, with that being said, it's always recommended to register the battery to extend it's performance and life.
| LCI Msport Conversion | Exotic Tuning Front Lip | H&R Coilovers | M3 Subframe Bushings | Custom Polyurethane Shore A90 Tension Strut Bushings | E93 M3 23.6mm Rear Sway Bar | UUC Front Sway Bar | Custom Heim Joint Rear Control Arms | Apex ARC-8 | Dunlop Direzza ZII Star Spec | Modified Dinan Cold Air Intake | aFe Oiled Drop-in Filter | Custom Hand-Made LED Angel Eyes | Alpine MRP-M500 | Custom LED Reverse Lights | OEM Blacklines | BMW Performance Trunk Spoiler |
